Old 03-12-2012, 08:04 AM   #1
druggrepp
My Ride: 325ci 2001
driveline vibration...
2001 325ci 5spd, 215k miles
I have owned 9 BMWs and I know what failing driveshaft vibe feels like.
This one is wierd though..
It only vibrates in 4th gear and sometimes when letting off gas in 5th.
At hiway speeds, it is smooth as a new one.
I have inspected it on a lift and guibo is not thrashed, and no obvious slack in ujoints in neutral.
Any ideas?
Update:: I heard driveshaft squeaking when backing up, so I ordered a driveshaft.
I will let you know of fix.
UPDATE: I got used drive shaft off ebay 110k miles cost $139 with shipping, $150 to get it installed.
That was it... rear ujoint was loose as a goose with only 217k miles on it, go figure.
Zero vibrations at any speed, aaahhh
druggrepp is offline   Reply With Quote
Old 03-12-2012, 10:22 AM   #2
Elvin123
My Ride: 328i
Did you check the center support bearing?
Elvin123 is offline   Reply With Quote
Old 05-01-2012, 08:59 PM   #3
mattfarrington
My Ride: 04 325xi
I get what seems to be the same issue, I was told to check the Rear Differential Bushing?
http://forum.e46fanatics.com/showthr...128&highlight=
mattfarrington is offline   Reply With Quote
