Sponsored by BimmerWorld
Old 10-18-2012, 09:04 PM   #1
bmwcanman
My Ride: 2004 330ci m-sport
Is Bentley manual wrong on ZHP rear stabilizer bar size?
Yes, I searched the forums and found confirmation of the FRONT being 24mm (or there abouts....23.88mm or so per BMW....also confirmed it in the Bentley manual)
However, Bentley 99 - 05 manual says the REAR is 19mm while the consensus on the forum and BimmerWiki is the REAR is 18 mm.
Can anyone confirm from experience the Bentley manual is incorrect on the size of the REAR?
bmwcanman is offline   Reply With Quote
Old 10-26-2012, 04:01 PM   #2
ian02
My Ride: 05 325ci
Here's what I show....
E46 330 ZHP Coupe + Sedan
33 55 1 094 545 up to 04/2001 19mm
33 55 1 095 758 from 04/2001 18mm
E46 330 ZHP Conv
33 55 1 095 758 18mm Standard suspension only
33 55 6 751 267 20mm Sports suspension or M Sports II
What I assume happened is Bentley made 2 versions of this book, the first came out in '01. Maybe when they researched that portion of the book the measurement was accurate? When they redid the E46 book to include '02-'06 models I'm guessing they only looked at those models and just kept the old info and assumed it was still valid? Just a guess.
Just curious, where are you in the manual that even shows that?
ian02 is offline   Reply With Quote
Old 10-27-2012, 02:56 PM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
Don't know what's in the Bentley. My stock rear bar is 18 mm. M Sport II is not the same as ZHP.
Old 10-27-2012, 03:21 PM   #4
ian02
My Ride: 05 325ci
You are correct, I misspoke earlier. They do show as two different option listings.
Old 10-30-2012, 06:12 PM   #5
bmwcanman
I have an e-copy version, but it is in a table under General 300-1 in the Rear Suspension section. I don't know how to cut and paste into a comment box.
