Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 260 votes, 4.99 average. Display Modes
Old 04-13-2012, 11:59 AM   #321
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
yeah, that would do it!.....ill keep that in mind if I see any USB related issues with anyone else.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 04-13-2012, 12:17 PM   #322
R75
My Ride: Rover 75
Originally Posted by diemair View Post
You misundersood me
I've already unpackt the archive. I want to do some work on the ROM as well, but i can not get the ubi.img file extracted. Unyaffs reports an error.
Ohh
http://forum.xda-developers.com/showthread.php?t=609090
Rover 75 CDTi (BMW pretender)
R75 is offline   Reply With Quote
Old 04-13-2012, 03:53 PM   #323
madmid04
My Ride: 320D E46 (2005)
Originally Posted by ro.sniper View Post
FAT16 or FAT32?
Cheers!
FAT16, mate.
madmid04 is offline   Reply With Quote
Old 04-13-2012, 04:06 PM   #324
Cretster
My Ride: E90 320D
Good idea Jeff.
To expand a little about that pin/plug, what I found when checking it out is that pushing a usb device/cable into it would generally push that pin in, which would then stay recessed usually, but not every time.
To improve the connection I used a teeny screwdriver to unclip the pin from its 'captured' position so on end is freed, then bend it a tiny bit and push back in so it stays put. This has made the connection much more robust, and things seem to work fine.
What I just can't understand though is how wifi always worked fine but bluetooth never would. A loost USB pin on the pigtail doesn't really explain that because USB is 2 pins for power and 2 for signal as I understand. Whichever pin was loose would affect any item plugged in the same way.
Whatever though - it's now working, but I'm just waiting for it to stop again.
Something is a bit unstable with the dynavin anyway though. Often it doesn't turn on by itself (ie you leave it on when turning the ignition off and leaving the car, and it should restart when you stick the key back in).
We're getting there though....
Cretster is offline   Reply With Quote
Old 04-13-2012, 05:33 PM   #325
ro.sniper
My Ride: VW Jetta
Originally Posted by Cretster View Post
Good idea Jeff.
The WiFi usb plug board was probably a few fractions bigger than the Bluetooth one essentially barely making connections. I have seen this before on other devices. I fixed a few usb plus with a paper-clip that i made into a ping grabber with some needle nose pliers.
Cheers,
Razvan
ro.sniper is offline   Reply With Quote
Old 04-13-2012, 06:38 PM   #326
ro.sniper
My Ride: VW Jetta
Originally Posted by madmid04 View Post
FAT16, mate.
Thank you sir!
Old 04-13-2012, 08:13 PM   #327
ro.sniper
My Ride: VW Jetta
I' ve used the SD which came with the Dynavin. I did not format it.
Flashing worked, but the Android wold not boot after flashing the R1.221 ROM
I've flashed the R1.1 ROM then which worked as well. This ROM is booting fine.
Any luck with 1.221? I tried 3 different SD cards and flashing works okay but no booting.
Old 04-14-2012, 03:46 AM   #328
Cretster
My Ride: E90 320D
Cheers,
Razvan
Oh yeah, that's really obvious now you mentioned it!
Good point mate - I think you're probably right.
Old 04-14-2012, 04:04 AM   #329
Cretster
My Ride: E90 320D
On another note, I've just been searching in vain through this thread looking for the posts about which OBD bluetooth dongles people have bought.
Must be doing something dumb when I'm looking for those posts as I can't find them.
Want to get one ordered but some of the ones I've been looking at on ebay are a bit sketchy about whether they'll work with my car or not.
Can someone possibly point me in the right direction please for tried and tested ones?
Old 04-14-2012, 06:08 AM   #330
madmid04
A miracle happened this morning!
After countless failed bluetooth attempts in Android I had pretty much given up on this, and assumed it was something to do with the E9x units somehow.
I've also noticed something weird when it comes to connecting the bluetooth USB dongle. It looks like the bluebooth works fine when I connect it via a USB HUB, and not directly to the GPS USB connector on the Dynavin.
My guess is it might be related to either power issues or USB ID on the android.
My current setup for making bluetooth and torque working on the D99.
USB HUB:
Cheep Belkin USB HUB with no additional power ($5)
Bluetooth USB dongle:
Cheep Belkin USB dongle ($5)
OBD II BT adapter:
Borrowed from a friend. Costs about $40 from ebay.
I've also encountered some issues when I started the Torque app for unknown reasons (closing unexpectable).
If anyone have any clues why, please let me know.
Torque crashes:
Old 04-14-2012, 08:42 AM   #331
diemair
My Ride: BMW E46 330xd
Hi I m using a cheap one i got from e-bay.
Here is a link t an current ofer for it:
http://www.ebay.de/itm/ELM327-OBD-2-...item20c4b0b35a
It workes fine with my BMW.
I've used it before with my mobile telefone.using torque. First with a HTC HD2 and now with a HTC SensationXL.
I also tested it with the Dynavin. It also was fine there. It was posting this one page above.
cu
diemair is offline   Reply With Quote
Old 04-14-2012, 10:43 AM   #332
Cretster
My Ride: E90 320D
Thanks mate - have ordered one now.
Cheers!
Old 04-16-2012, 11:03 AM   #333
DeadWinter
My Ride: E46 320D 2000
I ordered a BT kit with a OBD Mini and BT dongle, but the supplier said it is still awaiting delivery from the manufacturer, so I requested to cancel the order.
Yesterday I order this one: http://www.ebay.com/itm/320832449271...L:3160&vxp=mtr
Stated to work with Android and Torque is suggested so that should do the job. Also it a lot cheaper than the previous one I ordered. About half the price.
When I receive it I'll share my findings.
DeadWinter is offline   Reply With Quote
Old 04-17-2012, 06:41 AM   #334
diemair
Today I made some progress with the 3G modem. I was trying a O2 SIM card with it and was able to connect to the internet. I could read messages here in the forum, getting a route with google navigation and was able to load the play store.
Here are two videos from the test:
Old 04-17-2012, 10:28 AM   #335
ro.sniper
My Ride: VW Jetta
Could anyone shed some light on installing 1.221? I got a card another card formatted (thanks Jeff!) and was able to load up to the screen where it says to pull the card and reboot but after this nothing... just a blank screen. This is on a D99 unit.
Any help would be greatly appreciated.
Cheers,
Raz
Old 04-17-2012, 10:40 AM   #336
diemair
Cheers,
Raz
From me too. I've the same problems.
Therefore i tryed the Baldr-v2.3.0.6 ROM, which is also Gingerbread, but this did not work too. After flashing the android is starting - at the first start with touchscreen calibartion - but it seems that it does not respond to the touchscreen. It gets stuk there. At the next boot it starts with a look screen, wich can't be unlocked because of the touchscreen issue.
I got it here
Old 04-17-2012, 02:09 PM   #337
madmid04
I got it here
jneumann still got some problems getting Gingerbread on Dynavin (screen calibration). See this section for more info diemair.
Old 04-18-2012, 10:09 AM   #338
///polov
My Ride: ///M3
Who can help, how i can reflashing dynavin, after flashing all bi right but some time later i clik reset when battery low and now i see all mod but when i go to navi i see black screen and hear radio and thats all.
I put all files in the flash but nothing happens ... please help
///polov is offline   Reply With Quote
Old 04-18-2012, 12:31 PM   #339
m3evolution
My Ride: M3
It appears that the Dynavin D99 boots up the Android side a little different from my D90. I was fixing the volume problem my friend was having on the radio side of his D99 and flashed R1221 to the Android side. I noticed the same problem some of the members here have reported with the blank black screen. The D99 is a bit picky / sensitive about the way you power on the unit so if you having the blank screen bug you will have to play around with the way you power on the unit.
- Before flashing any of my ROM make sure you are using a sd card that you know for sure is formatted correctly and is able to flash the stock Dynavin ROM without any problems.
- After flashing a new ROM make sure to take out all sdcards, disconnect all wifi, and bluetooth adapters.
- Power off the Dynavin and wait 1 minute before powering back on. This is needed for the Android side to power down and clear out RAM.
- When powering on tap the power button (Do not hold down the power button for more than 1 second)
- First boot after flashing a new ROM should take no more than 5-10 minutes.
- After successfully booting into Android you can reattach all wifi bluetooth and sdcards and use normally.
If you are still having problems with the blank screen
- First thing to check after powering on is to check if your wifi dongle is getting power and the led light is on. Some of the black blank screen could be the Android side is not even powered on while the radio side is on and working normally. If this happens power off wait 1 minute and power back on by tapping the power button.
Rom and Password are available for download now at: http://m3evolution.webs.com
All version of my ROM is strictly for personal use and not to be commercially distributed.
Best way to contact me is at: m3evolution@gmail.com
Do not PM
Beer via Paypal:
m3evolution is offline   Reply With Quote
Old 04-18-2012, 06:13 PM   #340
Cretster
My Ride: E90 320D
Yep - have this a few times myself. Not so much after flashing a rom, but just every now and then when I boot it up I just get a blank screen in Android. Rebooting always solves it, but it's a bit annoying.
I just got my ELM327 OBD2 device anyway. Just about to test it with the dynavin but I couldn't get it to show on any of the OBD apps I downloaded for my iPhone or ipad for some reason.
Even in the bluetooth settings on the iphone it wouldn't detect the OBD dongle which is a bit worrying. No instructions with it either, just a disc with some non android apps, some of which include keygens with them, the cheeky sods!!!
Will try it now and see if I can get it to speak to dynavin.....
Only thing disappointing so far is this ELM 327 dongle is pretty big, and I can't imagine I'll be able to just leave it plugged in like I'd planned on doing. Will have to live in the glovebox and just plug it in when I need it I guess.
*edit* works perfectly with Torque, although I'm not sure what the optimal settings are.
Like it though.
One thing I'm unsure of though with OBD dongle, is it has a red LED lit all the time its plugged in from what I can see. Even after I took the key out the LED was on.
Does this mean that even apart from likely kicking it when I get in & out of the car it'd be a bad idea having it plugged in all the time?
Ie, specifically does it draw power all the time it's plugged in??!
