Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 260 votes, 4.99 average. Display Modes
Old 04-18-2012, 07:43 PM   #341
jrgutierr
My Ride: 325i
Originally Posted by Cretster View Post
Yep - have this a few times myself. Not so much after flashing a rom, but just every now and then when I boot it up I just get a blank screen in Android. Rebooting always solves it, but it's a bit annoying.
I just got my ELM327 OBD2 device anyway. Just about to test it with the dynavin but I couldn't get it to show on any of the OBD apps I downloaded for my iPhone or ipad for some reason.
Even in the bluetooth settings on the iphone it wouldn't detect the OBD dongle which is a bit worrying. No instructions with it either, just a disc with some non android apps, some of which include keygens with them, the cheeky sods!!!
Will try it now and see if I can get it to speak to dynavin.....
Only thing disappointing so far is this ELM 327 dongle is pretty big, and I can't imagine I'll be able to just leave it plugged in like I'd planned on doing. Will have to live in the glovebox and just plug it in when I need it I guess.
*edit* works perfectly with Torque, although I'm not sure what the optimal settings are.
Like it though.
One thing I'm unsure of though with OBD dongle, is it has a red LED lit all the time its plugged in from what I can see. Even after I took the key out the LED was on.
Does this mean that even apart from likely kicking it when I get in & out of the car it'd be a bad idea having it plugged in all the time?
Ie, specifically does it draw power all the time it's plugged in??!
I was thinking of using an extension cable so I can tuck the dongle somewhere else. I also got the ELM 327 and it's pretty big. I've kicked it off a few times. But it does work well. I'm pretty sure that red LED draws very little power. I saw one on amazon.com that looks promising. Here is the link:
http://www.amazon.com/OBD-II-Female-...4795905&sr=8-2
jrgutierr is offline   Reply With Quote
Old 04-18-2012, 07:54 PM   #342
Cretster
My Ride: E90 320D
Good idea! Do you think it'd be possible to have it mostly hidden though when permanently installed?
Re' power, it's not so much the LED itself that I'm concerned about but if that is able to be on then it's also possible that the whole unit is drawing a fair bit of power.
Might be the case that the LED goes off after the key has been removed for a while but I didn't have long to hang around and wait to find out.
Would be nice to be able to leave it always plugged in and just be able to fire up Torque when I like, or even have it run by default in Android through Tasker or the like, but not if it potentially means a flat battery at some point!!
Any other decent OBD2 apps out there for Android that people would recommend?
Either way - so glad to have it working at last.
Cretster is offline   Reply With Quote
Old 04-19-2012, 02:48 AM   #343
diemair
My Ride: BMW E46 330xd
Would be nice to be able to leave it always plugged in and just be able to fire up Torque....
As i reported i'm using this ODB Dongle for almost one year now. I had it plugged in permanently for a long time (it just cane off when I kicked it off), because the Temperature Gauge on my car was broken and i was looking on ebay for a a new one for a while. It did not seem to bother the batterie at all.
CU
Edit: P.S. This extention cable looks nice. Maybe I'll try it out.
diemair is offline   Reply With Quote
Old 04-19-2012, 03:16 AM   #344
al-djazair
My Ride: E46 E34 E30
Obd2
Hi all,
did anybody test this IBus to USB adapter ?
It can connect the IBus wire (white wire in Dynavin cable) directly to the USB port.
A driver for Android is available.
No need to connect a dongle or a cable to OBD2 port.
'01 E46 330xi
'94 E34 525i
'87 E30 325iX
2 x '86 E30 323i sold for parts
al-djazair is offline   Reply With Quote
Old 04-19-2012, 04:30 AM   #345
al-djazair
Originally Posted by al-djazair View Post
Hi all,
I found that Torque App is compatible with this OBD2 to USB adapter. It use the same driver. So may be ...
'01 E46 330xi
'94 E34 525i
'87 E30 325iX
Old 04-19-2012, 06:52 AM   #346
Cretster
My Ride: E90 320D
[QUOTE=diemair;14308483]As i reported i'm using this ODB Dongle for almost one year now. I had it plugged in permanently for a long time (it just cane off when I kicked it off), because the Temperature Gauge on my car was broken and i was looking on ebay for a a new one for a while. It did not seem to bother the batterie at all.
CU
QUOTE]
Very handy to know that, thanks! Did you ever have to leave the car several days without running the engine?
I may get one of those cables, although I can't picture offhand whether the angled end or straight end would plug in the OBD socket. Hopefully the angled end or else it'll still protrude!
Is there an easy space to access where the cable and dongle can be tucked out of the way? Mine is E90 so it might be different to you guys anyway I guess.
Old 04-19-2012, 07:54 AM   #347
listermint
My Ride: E46 M3 '02
Would it not be simpler to just remove the OBD connector from its clips and leave it and the OBD permanently behind the cover (no kicking) no protruding
listermint is offline   Reply With Quote
Old 04-19-2012, 08:30 AM   #348
R75
My Ride: Rover 75
Excuse me gentlemen, but we seem to be Miles off topic in here.
Rover 75 CDTi (BMW pretender)
R75 is offline   Reply With Quote
Old 04-19-2012, 10:26 AM   #349
diemair
Originally Posted by m3evolution View Post
It appears that the Dynavin D99 boots up the Android side a little different from my D90. ......
- First boot after flashing a new ROM should take no more than 5-10 minutes.
- After successfully booting into Android you can reattach all wifi bluetooth and sdcards and use normally.
If you are still having problems with the blank screen
- First thing to check after powering on is to check if your wifi dongle is getting power and the led light is on. Some of the black blank screen could be the Android side is not even powered on while the radio side is on and working normally. If this happens power off wait 1 minute and power back on by tapping the power button.
I did all of these stepes. Without success. Finally i even was waiting over night before i was resatrting the Dynavin after flashing - did not helo.
I always us the sd card wich cane with the dynavin. I tryed to flash with files i had unpacked with winzip, winrar on a win7 system and i also tryed it with fioles i unpacked with unrar on a linux debian system.
Always the same result - black screen after reboot.
Do u have any suggestions?
CU
Old 04-19-2012, 10:37 AM   #350
m3evolution
My Ride: M3
Another member has reported the same issue with R1221 but when flashing R122 Android booted up normally.
CU
Rom and Password are available for download now at: http://m3evolution.webs.com
All version of my ROM is strictly for personal use and not to be commercially distributed.
Best way to contact me is at: m3evolution@gmail.com
Do not PM
Beer via Paypal:
m3evolution is offline   Reply With Quote
Old 04-19-2012, 02:35 PM   #351
ro.sniper
My Ride: VW Jetta
I was having issues with 1.221 but 1.22 is all good
I'm going to try some more with 1.221 on the weekend.
ro.sniper is offline   Reply With Quote
Old 04-20-2012, 01:20 AM   #352
diemair
I dont have the R 1.22. I just have the R1.221. Can u send me a downloadlink and passwor for the R1.22
Old 04-20-2012, 01:42 AM   #353
diemair
Yesterday o got my new active usb hub (EXSYS EX1184HMV). It is very handy, because it can be directly connectet to the 12V of the car with a t-block where two cables (12v and GND) can be connected to.
The hub has a metal case which has wholes so it can be fixed with screws.
Here is a link to it
I have now the WIFI dingle, a Bluetooth Dongle and a 32GB USB stick connectet to it. All three are working fine and get reconnected after booting automatically. I got the power for the hub from the radio, so it has power, when the radio gets turned on.
Old 04-20-2012, 08:58 AM   #354
m3evolution
My Ride: M3
pm sent
Do not PM
Beer via Paypal:
Old 04-21-2012, 02:52 AM   #355
quang88
My Ride: 330CIC
m3evolution, wish i saw your thread earlier, great work! i just donated, look forward to trying ur ROM out
quang88 is offline   Reply With Quote
Old 04-23-2012, 08:14 AM   #356
ro.sniper
My Ride: VW Jetta
Tested and working
Hub: http://www.belkin.com/IWCatProductPa...duct_Id=608492
BT Adapter: http://www.belkin.com/IWCatProductPa...duct_Id=398674
OBDII: Generic ELM327 1.5 BT
I bought the Belkin hub for 14.99 and the BT dongle for 4.99. I have not tried anything else, they just worked right out of the box. I paired the BT dongle to the OBD II BT port and it works perfectly.
Any suggestions on getting TORQUE gauges to update quickly? I have removed a lot of the dials and that seems to speed things up.
Cheers,
Razvan
Old 04-23-2012, 10:24 AM   #357
CTRob
My Ride: Alpine white e39
Al-djazair just want to make sure I get this right... are you saying that instead of needing a bluetooth adaptor and a bluetooth ODBII unit that this cable will connect directly to the D99 (through the USB GPS cable/hub) and allow Torque to read the car directly?
This sounds a lot more streamlined than the bluetooth method, can this be confirmed?
CTRob is offline   Reply With Quote
Old 04-23-2012, 11:46 AM   #358
al-djazair
Hi CTRob,
you're right.
That's what I hope, but I'm not sure. I'd like to have some infos before ordering it. I think that M3Evolution have one (see this post).
'01 E46 330xi
'94 E34 525i
'87 E30 325iX
Old 04-23-2012, 11:48 AM   #359
mistapony
My Ride: volvo v70r
You need a BT adaptor. Notice this OBDII: Generic ELM327 1.5 BT which is required.
mistapony is offline   Reply With Quote
Old 04-23-2012, 12:56 PM   #360
CTRob
what are you referencing?
