Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 03-14-2012, 09:27 AM   #21
BaDiNfLuEnCe
My Ride: 04 m3, 06 jeep srt8
Originally Posted by mike@maximumpsi View Post
That car doesn't have the welds in the trunk reinforced. Once those welds separate, the mounts flex and tear badly. If the plates are welded underneath but the trunk welding is still damaged, the entire floor just keeps getting hammered. We have been highly suggesting everyone that has the reinforcement done at our shop to have the trunk reinforcement done in addition to the four mounts underneath the car. We have seen a few cars that were even worse than this. One was not salvageable because the welding labor would have been cost prohibitive. one of the worst cars that we repaired had the entire diff dragging on the ground with all four mounts completely torn out of the body.
I guess ill have to get the trunk done with you guys now to... Scary thoughts of this happening... But first i just need to fix my input shaft seal leaking for the time being... Kind of strapped for cash
shes finally here
[/IMG][/URL]
BaDiNfLuEnCe is offline   Reply With Quote
Old 03-14-2012, 12:24 PM   #22
Estoril-E46
My Ride: M3
Originally Posted by 02PRUV View Post
I went through this years ago. Brace it right so it never happens again
Something like this is the only fairly certain fix. Even with the "reinforcements" in the end it's just one little block held together at the two points of sheet metal, only afterward it's spaced over a little more area, but that increase is barely anything at the top.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 03-14-2012, 12:30 PM   #23
Custom3
My Ride: HellRot 330CI
if this ever happened to my car i think a would cry, especially since my motor is pretty much stock.
Old 03-14-2012, 01:29 PM   #24
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
None of the subframe reinforcement kits on the market today reinforce the floor itself. This is a known problem with BMW E46 models and as the cars get up there in mileage and in power we will see continual problems. We are going to do a special reinforcement on the drag car to keep the rear end from literally tearing off.
We have also fixed some E46's that have come to us with that type of damage. It takes a lot more reinforcement.
Chris.
HPF Chris is offline   Reply With Quote
Old 03-14-2012, 01:51 PM   #25
Bdave
My Ride: M3 HPF Stage 3
The installation of my HPF subframe plates cost me almost 2k in labor because I told my welder to go way beyond the standard installation instructions. He went over all that trunk stitching and a lot more other areas too. I have to dig the photos out. They are buried somewhere.
I told him to go "crazy" for the overkill. I winced at the bill, but now the sting is well taken out of all the money I paid. . I didnt know. How could I? I just had this strong suspicion that the standard installation just would not be good enough for MY purposes. Now, I see it is not good enough for some other's as well. Oh, boy! My condolences to BattaM3
I am now wondering if I still need to do even MORE. I am showing the pics in this thread to my welder.
Bdave is offline   Reply With Quote
Old 03-14-2012, 01:58 PM   #26
basar13
My Ride: Z4M, R8, 525xd, STI
Here are some other options ...
basar13 is offline   Reply With Quote
Old 03-14-2012, 02:13 PM   #27
DenaliXTC
My Ride: S/C M3, 745i, X5M
Send a message via AIM to DenaliXTC
Im super happy I went to you guys to have this work done!! :thumb up:
I highly recommend MAX PSI to anyone!
Active Autowerkes Gen 7 Stage 2 | Evosport | Vorsteiner | DPE | Supersprint | Rogue Eng.
Brembo 6pot 355/4pot 345 | Dinan 3.91 | HKS | HPF | Custom GTR | Radar Mirror | Leatherz | Beemer Evolution
LSB/Cinn M3 490 RWHP superflow dyno
2014 335 X-Drive M Performance OEM+
2011 X5 M White/Blk Vorsteiner
2007 M5 Dinan S3 5.8L Stroker+
DenaliXTC is offline   Reply With Quote
Old 03-14-2012, 02:43 PM   #28
lab rat
My Ride: '02 330iT
So if I understand it right, when you reinforce the subframe mount points it just moves the highest stress point outside to the trunk floor edge?
I'm just about to buy the HPF reinforcement kit but I'm nowhere near turbo M3 power levels so I hope I'll be ok.
Because sleeper
Old 03-14-2012, 02:53 PM   #29
Snik
Snik's Avatar
My Ride: IR M3 Vert.
that looks serious right there.
Do you ride a sportbike?
Old 03-14-2012, 02:56 PM   #30
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Would a rear strut bar be helpful? Just curious.
Jim
Jim Murphy is offline   Reply With Quote
Old 03-14-2012, 02:59 PM   #31
Snik
Snik's Avatar
this is what i asked before. If this kind of failure is exclusive to boosted M cars with ridiculous power. I cant imagine a regular ass car doing that much damage.
Old 03-14-2012, 03:21 PM   #32
TxZHP04
My Ride: ESS TS2+ ZHP
Jim
By itself, not at all. A shock tower bar does nothing to redistribute the subframe loads.
Old 03-14-2012, 03:46 PM   #33
Evil Twin Rob
My Ride: 2004 M3
Rear subframe failures have been a problem for a long time. Obviously, the higher hp cars will be more prone to failure, but this is a far too common occurrence even in bone stock M3's. If you just commute back and forth to work, you're probably fine. If you like to find the twisty roads on the weekend, and drive it like it was meant to be driven, you may want to be pro-active and do some type of reinforcement.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 03-14-2012, 04:03 PM   #34
Snik
Snik's Avatar
that failure where it rips out the entire floor. You guys have seen that on a unboosted car?
again we all understand that our cars have floor failure, but ive NEVER seen anything that insane.
Thats not your typical floor failure. Thats about what i call "fukin extreme"
Old 03-14-2012, 04:35 PM   #35
JohnBlaze
My Ride: Black Sunshine
imagine how those people that glued in their reinforcement kits will feel when they see this.
this is terrible
JohnBlaze is offline   Reply With Quote
Old 03-14-2012, 05:02 PM   #36
basar13
I have bought solid subframe bushings but i didnt install due to fear of subframe failure. I am waiting for the reinforcement.
I will reinforce it like crazy and have no doubt about it ever... This will of course add weight to the car but at least it on rear and relatively low.
My car...
I will do reinforcement like this but i wont weld them to towers but to the tubes that are welded to chassis..
Like this hopefully (Excuse me for very poor illustration)
Old 03-14-2012, 07:57 PM   #37
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I was about to order the TMS reinforcement kit, but not now. Now I'll be doing it exactly like this.
SUMMIT POINT WV 1:24:229 SCCA
Old 03-14-2012, 08:17 PM   #38
m3 guy
My Ride: 2001 e46 m3
For my reinforcement I followed this thread:
http://www.m3forum.net/m3forum/showthread.php?t=86017
Maybe it will help you guys out. Here is the only pic I have of it:
*2001 E46 M3 Oxford Green Metallic II-Cinnamon*
*AST*Work*VRS*UUC*RE*Apex*Scorza*SS*Brembo*
m3 guy is offline   Reply With Quote
Old 03-14-2012, 11:10 PM   #39
wrecklessfool
My Ride: is paid off
This is what I'm getting. Just got word it will arrive early next week. I'll be installing it with my new clutch and M3 rear end swap during the first week of April. Anyone in the Hampton Roads area of VA is welcome to check it out once complete.
I had the designer of this remove the "X" brace in the center, but the design is otherwise unchanged. It's made by a small company out of Cali called Mason Engineering.
wrecklessfool is offline   Reply With Quote
Old 03-14-2012, 11:22 PM   #40
Bdave
this is terrible
I actually considered having that done...for about 2 seconds. I ended up spending a fortune on far more welding that usual. Now I am so glad. Glue...what was I even thinking? I know they have space age epoxies out there, but this is not a situation for that.
