Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.95 average. Display Modes
Old 03-19-2012, 06:48 PM   #141
Commanderwiggin
My Ride: 900rwhp Turbo M3
Looking very forward to you driving your car bro!
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 03-19-2012, 06:52 PM   #142
02PRUV
My Ride: E46 M3 Turbo
Here is part of a dyno comparision article that I was talking about in your other point about your dead engine when I said I would be careful about tuning on a DJ and then going and smashing it on the strip or circuit:
You can optimize tuning for a DJ dyno and make big numbers - and you can tune the engine to make the best power under load on a load bearing dyno and blow off the big DJ dyno numbers. Can a tuner cheat and make a load bearing dyno read higher? The only way that could happen is in a Sweep Test - Sweep Tests are the least reliable of all tests, period. There is NO question about that. Since the Rotating Mass is a variable in a Sweep Test (NOT a Steady State Test!), the actual inertia factor entered affects the final HP figure - Tell the software that the vehicle has a lot of rotating mass to accelerate, and the HP number increases. (torque, rpm, acceleration rate and mass are the factors) - just like DJ dyno ignoring the difference in mass of all cars - So - true HP, again - Steady State Test - No acceleration, mass makes no difference, anymore. Torque, RPM and dyne parasitics. Period. True. Can you make a Steady State Test read higher? Really hard to do - The software will NOT take data unless speed and load are completely stable - eliminating cheating. As far as atmospheric conditions making a +/- 10% difference? Unless you REALLY mess with the barometric pressure (and you can look at every atmospheric factor on the test report sheet - it's hard coded to display - and not an option), it is simply, absolutely impossible to do without obvious evidence. Are final tuning optimal dyno settings different on an Inertia dyno vs. a load bearing dyno? For many reasons, final tune settings are different - and, since most load bearing dyno's will do both , there is a choice of tests - from a DJ style Sweep Test to Steady State. Having a choice of those types of tests to do and seeing what the results on the track are, most tuners will choose the Steady State Test over a Sweep Test. Without a doubt - the Steady State test Mode is the most consistently superior method of tuning - anybody who has the capability to do it will echo that sentiment - it's only an arguable point with those who can't do it properly. One of the reasons why the load bearing dyno will provide settings that work better in the real world is that combustion chamber temperatures are more in line with the actual operating temperatures that the engine.
I thought you would be interested in the last sentence. And it explains what I was getting at.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 03-19-2012, 08:14 PM   #143
SlideFox
My Ride: A Bucket w/ 4-Wheels
This has what to do with Marcus's build?
SlideFox is offline   Reply With Quote
Old 03-19-2012, 08:21 PM   #144
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
About as much as the tune had to do with my motor blowing.
Old 03-19-2012, 09:11 PM   #145
pimpn04coupe
pimpn04coupe's Avatar
My Ride: some hooptie
Good luck to you and your build!
pimpn04coupe is offline   Reply With Quote
Old 03-19-2012, 09:25 PM   #146
Commanderwiggin
It's all in the hips...er sleeves!
Old 03-19-2012, 09:47 PM   #147
Britisham
My Ride: '01 E46 M3 Sil/Imola
Kinda wish there was some pictures in the new build thread....just sayin. Glad things are moving quick so far.
HPF Stage 2.5 #10
Britisham is offline   Reply With Quote
Old 03-19-2012, 09:59 PM   #148
nnacpil
My Ride: 2006 BMW M3
Good luck on your build, Marcus. I'm pulling for you to make it to MFEST.
BTW, I would name it "the final stage", but we all know that it won't be the last stage haha.
2006 BMW lllM3 SilverGrayMetallic/Cinnamon/Apex Arc-8
llHPF/ProEFI Stage 2.25 w/6766
SOLD!!!!!!!!!!!
nnacpil is offline   Reply With Quote
Old 03-20-2012, 01:23 AM   #149
Tchleung
My Ride: 02 M3
Hope ya make it to MFest!!!
Off topic, but oddly enough, #5...
http://forum.e46fanatics.com/showthread.php?t=910512
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 03-20-2012, 01:29 AM   #150
funkboy316
My Ride: 2003 M3 vert
the compression and leak down of my car is fine its a built boosted motor and its within specs.........stop speculating. the car runs flawlessly, its only being sold due to a divorce
Everyone wants to have a hero engine, but don't believe all the hype you hear about 2 percent leakage engines. No cylinder seals perfectly, especially if the engine is nitroused, supercharged, or turbocharged where the top and second rings are set with wide ring endgaps. Even for normally aspirated engines, respectable leakage numbers would be anywhere from 8 to 12 percent with a variation between cylinders of 5 to 6 percent, but it's possible the variation could be as high as 10 percent.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 03-20-2012, 01:56 AM   #151
MarcusLSB
We discovered what occurred this morning when we brought the motor to another machine shop. Lets just say Funky's wouldn't likely be affected by the problem mine had.
I'm sure your car is fine.
Old 03-20-2012, 02:04 AM   #152
funkboy316
thanks marcus, look forward to your build. stage "what the F**k just passed me?"
Old 03-20-2012, 02:22 AM   #153
Hobbit382
My Ride: 99-328i 00-323i
WTF you can't just leave us hanging like that... Spill the beans marcus
Hobbit382 is offline   Reply With Quote
Old 03-20-2012, 02:31 AM   #154
MarcusLSB
I'm not trying to stir the pot. :\
Old 03-20-2012, 02:46 AM   #155
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
cd330 is offline   Reply With Quote
Old 03-20-2012, 02:54 AM   #156
e4604
Banned
My Ride: ...
C'mon put them beans in the pot and stir it, its bound to come out sooner or later
e4604 is offline   Reply With Quote
Old 03-20-2012, 06:25 AM   #157
Rockyminator
My Ride: :)
Yeah I want to know what was wrong too. I have a built motor and one day want to go proefi for their traction control and e85. Just wondering if I will be affected in the same way. Spill the beans!
HPF Stage 2.5 BMW M3
Rockyminator is offline   Reply With Quote
Old 03-20-2012, 06:46 AM   #158
Forcefed M3
My Ride: HPF Stage 2.75
Interesting.
Forcefed M3 is offline   Reply With Quote
Old 03-20-2012, 10:55 AM   #159
Hobbit382
pots already been stirred, shaken and blown the f up. If proefi didn't cause the damage then post the results and clear their name for anyone who doubted (probably not a lot) and in the same sense if hpf didn't cause it then they have the same right. It just causes way more conspiracy theories if you don't, especially now that its at Saads. I just think that with so many people involved in this and the attention it has gotten it would be unfair for everyone that helped out to be left in the dark.
P.S. maybe you can make a video of it....
Old 03-20-2012, 12:13 PM   #160
MaverickM3
My Ride: gets badge
Funky doesn't have a sleeved block but we do... So what's up Marcus?
MaverickM3 is offline   Reply With Quote
