Old 03-15-2012, 11:07 AM   #1
citrusjohn
My Ride: White 330ci.
Why does my car whine like a lil' b****h
Hey everyone,
When I start my 330ci up in the morning, I hear this whine coming from under the car. I originally thought it was coming from the engine bay somewhere, but no, it's sort of coming from the rear axle / anywhere under the car. It whines, then starts to rumble, then car dies along due to the RPM drop (have to start a few times before it constantly runs). I originally thought it was the serpentine belt slipping, or some bearing in the alternator or cooling pump. But this is definitely not coming from the engine bay. The whine is intermittent and only happens when cold. Again, it's not a constant whine. It's like my car is crying when its cold.
Could this be transmission related? Or is it really coming from under the hood and you think it's something else? Open to any suggestions (no SEL light on either)
Thanks!
citrusjohn is offline   Reply With Quote
Old 03-15-2012, 11:12 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Probably your fuel pump is toast and also the filter.
Old 03-15-2012, 11:15 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
+1 but you sound unsure from whence the sound is coming...so try using a hose/stethoscope to isolate it.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-15-2012, 11:19 AM   #4
citrusjohn
Thanks for your help! The more i think about it, the more the fuel pump makes since. Is there anyway to confirm that it is the pump?
Old 03-15-2012, 11:28 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Have someone else turn the key to position and see if you hear the pump prime. Then have them start it.
Old 03-15-2012, 11:40 AM   #6
My Ride: Lexus
Or while your car is running, simply go to the back seat and put your ear to the rear passenger seat bottom. Do you hear a whine?
Old 03-15-2012, 12:08 PM   #7
jdstrickland
My Ride: '94 325iC & '00 323i
The fuel pump lives under the back seat. You said the noise is the belts/pulleys, but they are nowhere near the back seat.
BEFORE you do ANYTHING, you have to decide where the noise is coming from. Try opening the hood before you start the car. This helps to isolate the source as being the front of the car or not. Given your first post, I cannot figure out how anybody would arrive at the fuel pump as the problem because any noise from the pump would not make you consider belts and pulleys as the source.
One process that happens on a cold start, and never happens at other times, and comes from the same area as the belts and pulleys, is the Secondary Air Pump.
The SAP is a pump that lives at the front of the engine on the right hand side (as viewed from the driver seat). It is used on a cold start to force additional air into the exhaust stream to help the CAT do its job before it comes up to temp so that it can do its job by itself. The SAP runs for about 2 minutes, then stops. The bearings in the pump are known to fail, and the pump becomes very noisey when this happpens. The pump is noisey anyway, but the bearings make it worse.
Old 03-15-2012, 01:16 PM   #8
citrusjohn
Well, I know it's the fuel pump. Why? In stuck along side of the road. It made 40 miles before it dies out. 2 miles from home. It's totally shot now. If I prime it, it's only enhogg for it to start.
Old 03-15-2012, 01:26 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well here lies a complication. If you had 40 miles left on the OBC then your fuel level sensor is inaccurate, not the pump. The sensor is on the left side and costs $90. Go run a bottle of 20oz Chevron Techron
Old 03-15-2012, 02:53 PM   #10
citrusjohn
Fuel level sensor inaccurate? But I hear the pump "not working and whining".
Old 03-15-2012, 02:53 PM   #11
citrusjohn
The OBC says I still have 90 miles or so.
Old 03-15-2012, 02:55 PM   #12
SamDoe1
My Ride: 4cyl of fury
He made it 40 miles before it pooped out, not 40 miles left on the OBC. OP, your fuel pump is done for. Replace it and your fuel filter.
Old 03-15-2012, 03:16 PM   #13
citrusjohn
Do I need to replace the fuel filter if I just replaced it 8k miles ago?
Old 03-15-2012, 03:17 PM   #14
My Ride: Lexus
Come on, JD. We all know the idler bearings and fuel pump belt are under the back seat!
Old 03-15-2012, 04:07 PM   #15
SamDoe1
Then no, didn't realize you replaced it so recently. Run a bottle of Techron through a full tank for good measure then.
Old 03-16-2012, 07:11 AM   #16
SpoonerDee
My Ride: 2005 E46
Originally Posted by BMWCruisn View Post
unless you have an SULEV... then the whole tanks gets replaced at a cost around $8k.
Which is covered by BMW NA unless you're past the 11 year 130,000 warranty (or whatever the exact numbers are).
SpoonerDee is offline   Reply With Quote
Old 12-07-2012, 03:36 AM   #17
eRock79
My Ride: '02 330Cic 5sp Man
Hey OP, sorry to drudge this up out of the depths, but was it your fuel pump and filter? My car has recently started to whine on cold mornings. Sometimes it sounds like it's from the engine compartment and other times it sounds like its in the cabin.
Cheers,
Erik
Are you waiting on me?
"Yeah, Thai Dishes is one of my dad's restaurants."
"Really? What kind of food do they serve?"
"Uhm...Thai."
'02 330Ci 5sp Vert**310 South Bay Bimmers Meet**310SBB Facebook**562 Meet
eRock79 is offline   Reply With Quote
Old 12-07-2012, 08:23 AM   #18
choxor
My Ride: JDM
Just like the OP was told, you need to isolate where the sound is coming from first.
Old 12-07-2012, 01:40 PM   #19
eRock79
Thanks bud. I was more-or-less interested in what he found was his problem. I'm gonna go through troubleshooting to pinpoint my problem. Sometimes it's just handy to know what others have experienced just in case. In my opinion anyway.
Cheers,
Erik
"Uhm...Thai."
