Old 03-16-2012, 02:25 PM   #1
RHAGGS
My Ride: BMW E 46 2000 323I
Angry Too much fuel consumption
MY E 46 IS ONLY GETTING 16 MPG
CHANGED EVERYTHING ?
AND I GOT A CODE 149 STORED IN SYSTEM
RPM IDLE IS ROUGH
RHAGGS is offline   Reply With Quote
Old 09-14-2012, 03:19 AM   #2
Brucio325cic
My Ride: 2005 325ci Cabrio
Man...did U get any response or ideas how to fix this. I got 13.3 MPG city!! and the RPM Rufff Idle...
Ive changed my Fuel Filter... I changed my Valve Cover gasket.... I changed all My Intake Rubber Hoses.... and Still!!
Any input would be Highly highly Appreciated. THX
Brucio325cic is offline   Reply With Quote
Old 09-14-2012, 06:27 AM   #3
Dippinwandy
My Ride: 325i
Im getting 14.4 city mpg
Dippinwandy is offline   Reply With Quote
Old 09-16-2012, 03:41 AM   #4
Bandit4077
My Ride: 330i SuperVeloce
fellas, this isn't good, you should check your DISA o ring. get the code boffins on this.
Some say, that inside his helmet, there is another helmet. All we know is...
Check out my interior: http://forum.e46fanatics.com/showthread.php?t=1055263
Bandit4077 is offline   Reply With Quote
Old 09-16-2012, 12:42 PM   #5
daves325in2012
My Ride: 2004 330cic
thermostat stuck open, VANOS, FUEL FILTER all come to mind
check option 5 on the hidden OBDII menu and see what its telling you you should be getting, then calculate what you are actually getting. that will tell you how far off your tuning is usually
TRICK: dividing the hidden ODBII menu's nummber (ie 96 = 9.6) by 235
235(DIVIDED BY)9.6 = MPG
Driving in Clearwater FL, i just got 25mpg ON US19 (congested highway) using 93 octane ethanol free, doing conservative, but not slow driving skills. thats pretty damn good i would only get 22 on shell vpower w/ 10% ethanol before
Ran through a whole tank of it and then divided out miles and gallons.
my ODBII otion 5 said i got 27, but its always reads about 2MPG higher than what I actually get
USE Premium gas too, that will improve miles by 2MPG avg and make the car run smoother.
The ethanol free, however, made the miles go up ANOTHER 2mpg from shell v power 93 w./ 10% ethanol
daves325in2012 is offline   Reply With Quote
Old 10-04-2012, 04:32 PM   #6
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
RPM IDLE IS ROUGH
Might be from one of those resister in a box performance chips. maybe PO installed it. I would try the thermostat.
aahmed2016 is offline   Reply With Quote
