Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 03-20-2012, 08:49 PM   #1
1hot325
My Ride: Bmw 325i
Hooking up a sub woofer
What is the best way to hook up a sub and amp on a stock deck of a 2004 BMW 325i
1hot325 is offline   Reply With Quote
Old 03-20-2012, 09:01 PM   #2
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Line output converter from stock subs. Wire up amp. Done.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 03-20-2012, 09:03 PM   #3
Sanchjer
My Ride: 323i e46 SOLD!
That is if he has stock subs. He may not have the harmon kardon system. In that case a line output convertor would have to be taped to one of the rear deck lid speakers.
Sent from my PG86100 using Bimmer App
Sanchjer is offline   Reply With Quote
Old 03-20-2012, 09:05 PM   #4
Kleen330
My Ride: 330Ci
one of these
http://www.ebay.com/itm/ADJUSTABLE-L...ht_1484wt_1270
and amp wire kit done
Kleen330 is offline   Reply With Quote
Old 03-20-2012, 10:06 PM   #5
nonseqtur
My Ride: '04 TiAg 330i
Stupid question: I have the Harman Kardon speakers; does this mean I have (or should have) a subwoofer? Where?
nonseqtur is offline   Reply With Quote
Old 03-20-2012, 10:10 PM   #6
Brinkley
My Ride: 99 328i, 07 z4 3.0
a line output adapter is what I used. Tap the rear deck speakers, and the remote wire on the stock amp (taps can be got at radioshack, very easy to work with) wire amp to batt and ground, perhaps add a capacitor, I simply used a standard sub box with 2 10s, fits in trunk fairly nicely. I also added fuse in the power line, and used a box that can be easily removed if I need trunk space or to put on spare tire. There are many ways to go on this, but truly it's not that hard, I wish I'd done it a long time ago.
Brinkley is offline   Reply With Quote
Old 03-20-2012, 10:10 PM   #7
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
you do. in your trunk. if you have a coupe its one black box w 2 6x9s under the rear deck. if its a sedan its two individual 6x9s side to side under rear deck
G-Hots is offline   Reply With Quote
Old 03-20-2012, 10:12 PM   #8
UserBlade1
Banned User
My Ride: M3
yupp
UserBlade1 is offline   Reply With Quote
Old 03-21-2012, 12:13 AM   #9
trj
My Ride: 325Ci
Don't you guys think its better to tap into the wiring harness before the factory amp? Because it is a cleaner signal than the one that is already processed by the factory amp and going to the sub amp.
Thats what I'd do if I was adding a sub in my harman Kardon.
Old 03-21-2012, 12:31 AM   #10
white46
My Ride: e46 323ci
even without H/K, I would prefer tap it to pre-amp wire.
white46 is offline   Reply With Quote
Old 03-21-2012, 07:59 AM   #11
Brinkley
Probably would have been better to tap pre amp and run directly to amplifier now that you point it out, with less wiring to do as well. But in my case, it's done and sounds good.
Old 03-21-2012, 09:53 AM   #12
1hot325
My Ride: Bmw 325i
I like the idea of tapping in to the head unit speaker outputs to convert to RCA with a line level adapter how do I know if I have the HK system? My car is a sport package, does that mean anything?
Old 03-21-2012, 10:07 AM   #13
trj
My Ride: 325Ci
HK audio is an standalone upgrade/option. Some cars with premium and sports package come with HK audio as standard.
However, there will be harman kardon labels on the speaker grills on the doors and also a little ambience button(which has a speaker symbol) on the center console next to your DSC button. If the button is not there then you do not have HK.
Also, tapping into the pre amp signals is the best way to get the clean signal. Some amps do take direct input from our factory headset, therefore eliminating the need of RCA converters. So check your new amp to see if it can handle the input.
Old 03-21-2012, 12:55 PM   #14
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
If you're amp has a high level input you can tap into post-amp wires AND eliminate the need for a remote wire.
But one great benefit of the remote wire is that I ran mine up to my center console and installed a kill switch for the sub. If i leave the switch on, the sub amp only receives power and turns on when the head unit is on. If I turn the switch off, the sub amp will not turn on whether or not the head unit is on. This is nice because I can leave the switch on at all times and know that it will shut off with the radio and not drain power when the vehicle is off
drumbum624 is offline   Reply With Quote
Old 03-21-2012, 06:53 PM   #15
1hot325
My Ride: Bmw 325i
Great advice thanks
Old 03-21-2012, 09:59 PM   #16
K'KamE46
My Ride: 323
Any pictures of installation guys? Im a lil dumb to any of this. But I am looking forward to install my own sub and amp. And yes, I do have harmon kardon sound system also...
Recently I just purchase an adjustable line level converter, but have no idea of where to begin...
Help....:sly:
Sent from my HTC Glacier using Bimmer App
IN PROGRESS....
B&G SPRING I ANGEL EYES I M3 REP F. BUMPER I E90 RIMS I
AEM COLD AIR INTAKE I
K'KamE46 is offline   Reply With Quote
Old 03-24-2012, 08:09 AM   #17
1hot325
My Ride: Bmw 325i
Here is a dumb question where is the battery in the 325? I thought it was under the passenger seat in the back but it was not.
Old 03-24-2012, 08:11 AM   #18
E46_330i_Stud
Trunk. The fuel pump and tank is under that rear seats
Old 03-24-2012, 10:08 AM   #19
Stinger9
My Ride: '04 330Ci
Hey, you can look up this kind of stuff!
Go to the DIY section and look up lots of stuff to get yourself a real education. Pictures too!
Sounds like you're interested in learning!
Old 03-24-2012, 10:28 AM   #20
Sanchjer
It's under the black cover on the passenger side. Lift up the rear carpet and then un-due the plastic tabs and pull the cover off and there's your battery.
