New Precision 6466 Turbocharger - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 02-20-2014, 04:58 AM   #41
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by Commanderwiggin View Post
Nice! I'm not familiar with the TFX cylinder pressure equipment
You mean you've forgotten about it; I've been openly advocating it's use for years.
http://forum.e46fanatics.com/showthr...x#post11622115
http://forum.e46fanatics.com/showthr...x#post12869462
http://forum.e46fanatics.com/showthr...x#post13595166
http://forum.e46fanatics.com/showthr...x#post13906914
Old 02-20-2014, 05:58 AM   #42
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Haha nice, whats the cost like for one of these setups?
Old 02-20-2014, 08:33 AM   #43
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Approximately $3500 for the logging system, and about $1100-1300 per sensor. So figure $6k for a system that watches intake port pressure, cylinder pressure, and exhaust port pressure in real-time. Add more logging for multiple cylinders, and a couple more sensors and you're easily at $10k.
The only down side is how much you need to cut up a cylinder head to install this stuff.
Old 02-26-2014, 09:43 AM   #44
Reid@SP
Regional Sponsor
Reid@SP's Avatar
My Ride: Toyota Supra
Send a message via AIM to Reid@SP Send a message via Yahoo to Reid@SP
Originally Posted by mike@maximumpsi View Post
Maybe I worded that wrong. I am aware of the larger divided housings flowing similar to a smaller A/R open housing from when we changed from an open manifold to a divided. We have tested every 66mm open and divided turbine housing that Precision makes on my car and the built motor car!
I know you are aware Mike. I was just clarifying for the rest of the class!
Sound Performance
Shop (630) 893-5002
Cell (847) 363-3139
reid@spracingonline.com
**PLEASE DO NOT PM ME!! Please email me for inquiries/communicaton**
Reid@SP is offline   Reply With Quote
Old 04-11-2014, 01:56 AM   #45
dragosid
My Ride: HPF 2.5 M3
...so we will begin to lean on the built motor car shortly. It is an absolute beast on the street. Right now it is in the low 600whp range on pump gas.
Any more updates on this?
I'm thinking if dropping the turbo from 6766 .81 A/R undivided to say a 6466 1.00 undivided would render me similar results on the current setup (all in the name of an even earlier powerband)
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 04-11-2014, 10:35 AM   #46
Reid@SP
Regional Sponsor
Reid@SP's Avatar
Changing to the 6466 will yield some spool time increase if all else is kept the same. The divided 1.00 A/R is slightly larger than the undivided .81 A/R so there will be a slight change in spool time there in the other direction.
If you're going to crank up the boost, you'll take advantage of the 6466 Gen2 CEA in terms of power output (let's say over 25psi). However, the 6766 Gen1 CEA will be a bit more efficient in the lower boost levels (say under 20-25psi). I can't give an exact boost level where one will be better than the other as boost is relative to the supporting mods and motor characteristics but those give you a rough idea.
Reid
Sound Performance
Shop (630) 893-5002
Cell (847) 363-3139
Old 04-11-2014, 05:02 PM   #47
dragosid
My Ride: HPF 2.5 M3
Originally Posted by Reid@SP View Post
... If you're going to crank up the boost, you'll take advantage of the 6466 Gen2 CEA in terms of power output (let's say over 25psi). However, the 6766 Gen1 CEA will be a bit more efficient in the lower boost levels (say under 20-25psi)....
Reid
Thanks Reid. Anthony should chime in here... not sure if my setup is good for over 25 PSI.
As for the A/R, I got inspiration from your previous post
To properly compare the A/R of an undivided and a divided housing, you have the equal the playing field. A quick way to do this is to subtract .11 from the divided A/R to give you a rough equivalent of an undivided manifold.
Example: Take the turbine housings available for any PTE 66mm turbine wheel (6266, 6466, 6766). Then take the T4 divided 1.00 A/R as our example. The equivalent correction (again, by roughly subtracting .11) would put that 1.00 divided A/R to an equivalent .89 undivided A/R. The equivalency makes it more relatable to the T4 undivided.81 A/R.
However I'm assuming If I'm targeting the same power levels with the 64 I should order a bigger (say .96) than .81 A/R that's with my current 67.
Also was wondering why they have the Gen2 on most smaller turbos but not the 67.
Old 04-11-2014, 05:20 PM   #48
Reid@SP
Regional Sponsor
Reid@SP's Avatar
The turbine wheels are the same between the 6466 and 6766 so I would keep it the same unless you have a reason to need a divided turbine housing.
Sound Performance
Shop (630) 893-5002
Cell (847) 363-3139
Old 04-12-2014, 04:08 AM   #49
E85head
My Ride: E46 M3
Is there a gen1 and gen2 of the 6466?
E85head is offline   Reply With Quote
Old 04-12-2014, 05:41 AM   #50
dragosid
My Ride: HPF 2.5 M3
I don't really need a divided housing but just want to move the power band to the left even more hence my downgrade thoughts. But since I wanna maintain the power levels I was thinking I need a bigger A/R with the slightly smaller turbine.
Old 04-12-2014, 05:45 AM   #51
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
Reid , do you have any info on 6766 cea 2 and 7168 cea 2 are these in development atm ?
Providence is offline   Reply With Quote
Old 05-14-2014, 04:14 PM   #52
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
I like the 6266 Gen 2 which good for 800 crank horsepower and would move the power to the left considerably ... U might lose some top end hp but on a street car that's not a big deal. U would be at 700 wheel with it for sure... And the car would be a very good driver... I am considering it in the near future on my 10:5:1 motor...
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-14-2014, 10:51 PM   #53
being3
Modded ///Member
being3's Avatar
Now if ur really looking for something big.... Saw this baby in a GTR specialty shop in Dubai
Old 05-15-2014, 04:50 PM   #54
dragosid
My Ride: HPF 2.5 M3
Attachment 558432
LOL ... that was a PT106 IIRC
Old 01-21-2015, 10:12 AM   #55
Reid@SP
Regional Sponsor
Reid@SP's Avatar
No Sir. The current smaller GEN2 turbos are offered in 6266, 6466, 6870, and the 7675 which is coming this quarter.
Sound Performance
Shop (630) 893-5002
Cell (847) 363-3139
