///M3 Forum
Old 03-27-2012, 04:53 AM   #1
MoOriginal
My Ride: e46 M3 Cabrio
SMG II gear change problems
Ok guys thought id post over here to see what you knowledgable peeps might think
Long story short.
I have a 2002 m3 Convert.
88K
I recently had the diff replaced as central bearing had issues and leaking seals too.
At the time I had terrible judder
and when they took out the clutch to replace it they found the clutch so badly worn that it was frayed at the edges
New clutch fitted
So work done.
1. Diff fitted
2. New clutch
3. SMG fluid replacement for new
4. Diff oil - and friction modifer
5. SMG adaptations
6. New Salmon relay
Heres the problem
On full power - that is gunning it between
2nd into 3rd
3rd to 4th
I get a lag - the gear engages after a visible pause in power - and there is a sound from under the car - best described as a 'clacking' sound
like if you beat two pieces of two by four wood planks
There is a double 'clack' - and pause as car goes into gear between 2nd -3rd and 3rd - 4th.
All other gears are perfect and no problems, sounds etc.
Blipping on downshifts are fine
Downshifting into 3rd or 4th - does have a delay and car does not select the lower gear until its happy in the problem gears only.
In other gears the downshifting is fine...
Can anyone throw any suggestions
Someone mentioned to me syncromesh ?
Any thoughts appreciated.
Mo
MoOriginal is offline   Reply With Quote
Old 03-27-2012, 05:39 AM   #2
johnm
My Ride: TiAg M3
Better off sticking with Cutters IMHO...
Most likely culprit are the indent springs, however in order to eliminate a couple of other possibilities the first thing you need to do is get a full SMG re-adaption, not the half baked one that the cheap hobbyist systems do, as they often are only capable of doing the clutch. This will eliminate the GPT and possibly even cure the problem if it's only GPT out of cal. If the adaption fails and tells you to replace the gearbox then it's almost guaranteed to be indent springs, which are cheap, but a pain to replace. Ask on Cutters and you'll likely find someone nearby who's done it.
Be aware that when you do the adaption, if it fails, things may get much worse, to the point of being nearly undriveable, giving all the symptoms of a badly slipping clutch. Panic not, replace the indent springs and do the adaption again- most important, and it'll be sublime.
Cheers
JM
johnm is offline   Reply With Quote
Old 03-27-2012, 05:56 AM   #3
MoOriginal
Haha thanks John
Thing is this - I forgot to mention in list of things done
When they had the gearbox off - they found that I had the earlier version of the gearbox.
So basically this meant that only 2 out of the 4 springs were serviceable in the gearbox
the other 2 were blocked up - I actually saw this for myself
seems the later design allowed the servicing of all 4 springs
I had the 2 springs that were servicable - replaced for new.
The old springs although hard to tell - looked ok ...
The adaptation was as far as I know a full one - as they used a specialist technician...
You mention GPT and GPT out of cal - what is that ?
Old 03-29-2012, 08:49 AM   #4
johnm
My Ride: TiAg M3
I think someone's having a lend, there's only one version of the gearbox. A couple of the indent springs are behind plugs that look not unlike welchplugs and are well nigh impossible to get out without damaging, but they're not blanking plugs, there's deffo springs behind them.
http://realoem.com/bmw/showparts.do?...87&hg=23&fg=15
The gpt is the gear position sensor/ transducer, but somene's already stolen the gps acronym...
Cheers
JM
Old 03-30-2012, 03:34 AM   #5
MoOriginal
thanks john
I have seen the gearbox off and had a look at the said ident springs mounting points actually myself .
visually you can see that the mounting points are blanked by these plugs as you say
but the question is this if the garage manage to get to these 2 springs
and replace them
how then to plug up the holes again - and damaged plugs
Ive seen the diagrams also as there are 2 versions
one were you can extract all 4 springs and one where the diagram only shows extracting of 2 springs
Old 03-30-2012, 07:10 AM   #6
roadtrip1098
My Ride: 06 STi
A few things you can check. Some sound dumb, but sometimes the simplist solution works the best.
Have you tried doing the rolling reset so the system will "re-learn" the shifting? Just slap the car into N while you're rolling and pull back both paddles for 3-5 seconds. There's no confirmation that it has worked other than the behavior when it shifts.
Have you tried setting drive logic lower for "softer engagement"? The new clutch may bite harder and be causing issues.
How'd the rubber flex disc/guibo look?
Is it possible that they didn't use the right tourque when reinstalling the springs?
Is it possible that you received a defective clutch?
Could the flywheel be dirty or warped?
Did you have the pressure plate changed?
roadtrip1098 is offline   Reply With Quote
Old 03-30-2012, 01:47 PM   #7
MoOriginal
Thanks for the comments
Pressure plate was changed and the flywheel was fresh out of the kit with new clutch
The springs changed were the small ones held in by a press fit cap so no torque settings
Rubber flex disc was changed
Didn't change the drive logic was just left same as my original settings
Also a rolling reset wasn't done
Old 03-30-2012, 02:02 PM   #8
roadtrip1098
My Ride: 06 STi
I would suggest trying the rolling reset, it's free and easy to do with absolutely no negative impact. It is unlikely that it will solve your issue, but hey it's free and if it does work you just saved yourself a buttload of time and money.
Did they by chance bleed the hydraulic system? I know you said they reset it, but if I understand right the system must also be bled properly.
Also if it's the GPS that's gone bad, which can happen, it is a pain to install, but can be done in your driveway, no lift needed. I posted a DIY with pics and everything a while back, it outiines the symptoms pretty well too.
Old 03-30-2012, 02:17 PM   #9
MoOriginal
By rolling reset do you mean on the paddles held in?
In which case I have done that twice
I'll have a look for your gps posting as didn't look at that..
I'm sure they said they bled the system..I'll double check
Old 03-30-2012, 02:29 PM   #10
roadtrip1098
My Ride: 06 STi
Here's the link for that GPS DIY http://forum.e46fanatics.com/showthread.php?t=878863
Old 03-31-2012, 01:51 AM   #11
MoOriginal
So,after reading that thread seems like your an expert too like John
Reading your symptoms I don't seem to have similar gps issues??
It goes into gear fine doesn't feel,sluggish in any other gear.
Once the clacking gear change happens gears are great
No juddering
No cog light
I've noticed now that if i,lift between 3rd to 4th on full power the clacking change is a bit better
I tried same in 3rd but didn't work
But between 2nd to 3rd above 3000 revs on full power it will always make this horrible change
If I'm not hard on pedal then it changes smoothly
Perhaps it seems to change smoothly as the clacking noise and pause is,still happening but you feel,it less as with a slower gear change you expect a pause in the power more .....
Old 03-31-2012, 01:54 AM   #12
MoOriginal
Also does this make sense
When I had original juddering problem It started off between 2-3 3-4
This got worse and it started happening in all gears so quickly realised that the clutch needed replacing
However didn't get clutch replaced for about 2 months due to needing car as daily driver for work
So did the car store in memory the readings or problems with these gears that it then carried over to the new clutch ?
Old 03-31-2012, 04:58 AM   #13
roadtrip1098
My Ride: 06 STi
I'm no expert but I read a book or two on the smg. Where you said the problem occurred before and after the clutch change, it makes me think there's a loose support or a mount going bad someplace. If you're on a slight incline in first, come to a complete stop, let the car roll back just a little, then take off quickly does it make the same noise?
Old 04-02-2012, 06:21 AM   #14
MoOriginal
Thanks for the info dude.
Anything is appreciated of course
I tried what you said - and nailed it
no sound
the car has brutal changes as expected in 1st and 2nd
Old 04-10-2012, 10:24 AM   #15
MoOriginal
Someone also mentioned that the syncro might need replacing
does anyone think this is a good idea ?
Old 02-15-2013, 07:11 PM   #16
khawejaa
My Ride: E46 M3 convertible
Send a message via MSN to khawejaa
hello guys i need ur help what does this code mean?
(048) 30 gear can not be engaged
khawejaa is offline   Reply With Quote
Old 02-15-2013, 08:14 PM   #17
Chea
My Ride: 05 ///M
This came on but the car seems to be driving fine replaced the salmon relay and did the soft reset and nothing. Guess best step is getting it scanned. Fingers crossed
Chea is offline   Reply With Quote
