Sponsored by BimmerWorld
Old 09-27-2012, 10:40 AM   #21
My Ride: Lexus
Originally Posted by lsteg View Post
Want to give me a quick run down as to why? Also, where to purchase said nuts?
quality. dealer.
Old 09-27-2012, 10:41 AM   #22
lsteg
My Ride: 2001 330ci
quality. dealer.
Fair enough, thanks.
lsteg is offline   Reply With Quote
Old 09-27-2012, 10:47 AM   #23
ImolaSix
My Ride: '02 330Ci M-sport
quality. dealer.
I don't understand this. If the Meyle control arm itself is of high quality, shouldn't the hardware provided be of equal quality?
What evidence do you have to support that the Meyle nuts are inferior to the OE BMW ones?
ImolaSix is offline   Reply With Quote
Old 09-27-2012, 10:51 AM   #24
WDE46
My Ride: '13 128i, '04 330Ci
None. I used the Meyle ones. The threading was very good on the nuts. This size nut and bolt combo could easily hold several e46s in the air. I'm not concerned in any way.
Old 09-27-2012, 10:54 AM   #25
My Ride: Lexus
Not necessarily. Often times aftermarket companies toss in cheap hardware. Just enough to get you by. There's been discussions on the quality differences between Meyle and Genuine nuts. The quality difference is night and day. The Meyle nuts feel and look super super cheap relative to their control arms which feel and look very nice. BMW nuts are less than $10. Good safety precaution, if you ask me.
As with most things, your call
Old 09-27-2012, 10:56 AM   #26
My Ride: Lexus
Eh. This has been discussed on other forums before.
Old 09-27-2012, 10:57 AM   #27
ImolaSix
I guess I'll swing by the dealer today since my control arms just came in.
Thanks Mango!
Old 09-27-2012, 10:57 AM   #28
My Ride: Lexus
a 2-second search: http://forum.e46fanatics.com/showpos...41&postcount=1
Old 09-27-2012, 10:59 AM   #29
My Ride: Lexus
Thanks Mango!
you won't regret it. the BMW nuts are VERY very nice. having four in my pocket almost made my shorts fall off very very heavy duty feeling/looking.
Old 09-27-2012, 10:59 AM   #30
WDE46
Mind linking? I am very interested to read the threads. Does someone have an actual material comparison or test. If not it is all speculation. You can't really say the BMW ones just "feel" better when you hold them. Materials are deceiving.
Old 09-27-2012, 11:02 AM   #31
My Ride: Lexus
you're really going to argue over $10? who the hell is going to send nuts to a lab to do testing? hold the two side by side and you tell me if you perceive any difference. apparently, you haven't.
Old 09-27-2012, 11:15 AM   #32
WDE46
No I'm not arguing over $10. I'm arguing the claim you made that they are inferior. Had I heard about this I probably would have just ordered the BMW ones to be safe as well because, like you said, it's only $10. Now that I have the Meyle hardware installed I am interested to know what concerned people about the Meyle stuff. And yes, I did notice a material difference. The BMW is slightly goldish tinted, probably indicating Grade 8 nuts. The Meyle are shiny metal, might be stainless.
Old 09-27-2012, 11:21 AM   #33
My Ride: Lexus
Well there you go. No i don't have data or spec sheets to prove my assertion. I chose what I chose based on others observations, my observations, and the price of the new nuts.
I don't recall the particular thread where the quality difference was discussed--it was years ago. But if I come across it, i'll let you know.
Old 09-27-2012, 11:31 AM   #34
WDE46
I'm going to do research on it because I honestly want to know. I was looking at the BMW genuine on ECS Tuning and those are not gold tinted at all (don't know why mine are). Probably just a high grade steel, but I can't see a car company using less than class 8 hardware. The Meyle's finish might just be a zinc coating for all I know over the same bolt.
I emailed Meyle and asked for material specifications for the hardware they provide. I'm gonna post a thread with the response, if they respond.
Old 09-27-2012, 12:26 PM   #35
ExcelonGT
My Ride: 04 330ci ZHP 6-speed
Earlier this year I had a really bad wheel shake under moderate braking and everyone was convinced it was my control arms. the problem started when I replaced BMW OEM pads and rotors with Stoptech Rotors and Hawk HPS pads at 90k miles. I bought a set of new FCABs thinking that was the problem. however, I decided to ditch the aftermarket brakes and get everything replaced with BMW OE Rotors and pads (through the dealer). the horrible wheel shake vanished right away. Car has 125k miles on it now and braking is still very smooth. I am just now going to replace my FCABs with Meyle HD FCABs. Car is getting KONI Yellows as well this week. Cant wait!
ExcelonGT is offline   Reply With Quote
Old 09-27-2012, 12:31 PM   #36
Zell
Zell's Avatar
My Ride: so turbo wow
I am also having this problem, and I do know for a fact it is my brake rotor being the issue. My front-right rotor has a jutter when slowing down. I can hear the brake going "squeak-squeak-squeak" and feel the car kind of...I don't know how to describe it, it's not vibrate but it feels as if it goes faster then slower then faster very subtly. But it does sort of vibrate.
I have new rotors, old pads (but the pads are basically new), just occurred out of nowhere. Wheels are true, I don't think my hub is bent...so I don't know why this is? I've tried bedding multiple times, doesn't seem to fix it.
When I spun my rotor on the driver's right side, I noticed that it felt easier to spin up until a certain point when it met resistance, then got harder to turn, then got easier again.
It's only been a few months since I replaced the rotors. New Meyle HD FCABs are on.
Old 09-27-2012, 12:34 PM   #37
My Ride: Lexus
maybe your brakes got hot and you held them on the rotor for a while at a stop light and some material got "seared" onto the rotor. not enough for an outright vibration but enough for slight grab at that certain spot on the rotor.
try doing some aggressive braking maneuvers to "scrub" it off.
Old 09-27-2012, 12:41 PM   #38
ImolaSix
What brand of rotors and pads are you using?
Old 09-27-2012, 02:28 PM   #39
Zell
Zell's Avatar
Rotors are by BimmerBrakes, pads are unknown. I never looked at them.
I don't brake very hard so I don't think I caused pad buildup in one spot. I was extremely careful of that when bedding.
Old 09-27-2012, 02:37 PM   #40
My Ride: Lexus
That could be the problem right there. you should know what parts you're installing onto your car. especially items like brake components.
