Old 03-29-2012, 06:11 AM   #1
jjrichar
Modded ///Member
My Ride: 330 CiC, 330i
Project M54 Engine: Timing Chain Cover
Timing chain cover
Link to other parts of the project
http://forum.e46fanatics.com/showthr...5#post14015375
The timing chain cover sits at the front of the engine behind the vibration damper. In it is housed the coolant pump at the top, and at the bottom is where the crankshaft pokes though to connect to the vibration damper.
To remove the timing chain cover, it is an easy task if the engine is removed, and both the head and the oil pan are removed. The cover is jammed between the head and the oil pan. If the engine is in the car, it is possible to remove the cover without removing the head. It requires the oil pan to be off, and hence the engine supported from above. The three bolts that hold the head to the cover can be removed from above after the valve cover is removed. The vanos and timing assembly can stay in place.
Why would you need to remove the cover? If you need to get the crankshaft out, or there is something wrong with the timing/oil pump chains then you would need to have it off.
Removing it is a simple process once the head, oil pan, and vibration damper have been removed. Initially, the coolant pipe that goes into the back of the timing cover needs to be removed. There are two there. The top one goes into the head, and should already be gone. The bottom one goes into the timing chain cover. They are both a pain to get out. They both have two O Rings that are really jammed in there.
At the front on the cover there are a load of small bolts that need removing. Remove all of these, but leave the top two in there loosely. The cover is still held on by the two dowels. These are not like others on the engine, they are like a nail that has been hammered in there. You can't just pull the cover off. The Bentley manual talks about tapping them out from the front. This has the issue of you then having to fit them into the cover again prior to installation. It's much easier to tap them out from behind. They stay in the cover ready for installation.
When the cover has been removed, this is what it looks like from inside.
The chain guides can be easily removed, however, if they are like the guides on this car, the tabs that hold them on will break when you try to remove them.
Once the guides are off, the chains can be easily removed. Also the sprocket that drives both chains can slide off the crankshaft. The sprocket is one unit. It is reversible, and can be put on the other way around no problems. When the vibration damper is fitted, the sprocket is held between the crankshaft and the vibration damper.
Here is another picture just for information. I had said in a previous post that there was no requirement to hold the timing chain up when the timing sprockets (up the top connected to the vanos) are removed. This is the reason why. There is a lip on the timing chain cover that doesn't allow the chain to fall of if it is loose at the top.
Name:	Coolant pmp thermostat 11.jpg
ID:	444134   Click image for larger version
Name:	Timing cover 01.jpg
ID:	444135   Click image for larger version
Name:	Timing cover 08.jpg
ID:	444136   Click image for larger version
Name:	Timing cover 07.jpg
Name:	Timing cover 02.jpg
ID:	444138   Click image for larger version
Name:	Timing cover 03.jpg
ID:	444139   Click image for larger version
Name:	Timing cover 09.jpg
ID:	444140   Click image for larger version
Name:	Timing cover 04.jpg
Name:	Timing cover 05.jpg
ID:	444142   Click image for larger version
Name:	Timing cover 06.jpg
jjrichar is offline   Reply With Quote
Old 01-13-2013, 01:04 AM   #2
bmw interested
My Ride: 2003 X5 3.0
Nice job mate, you've been so helpful thus far.
bmw interested is offline   Reply With Quote
Old 02-18-2014, 07:50 PM   #3
Ferrari88
My Ride: 1999 VW Passat 1.8T
Thank you for the detailed steps! This really helps a lot right now. Need to replace the chain guide. Broke it while replacing the head gasket
Quick question though, is it necessary to remove the oil seal in order to remove the timing cover?
Ferrari88 is offline   Reply With Quote
Old 02-18-2014, 11:33 PM   #4
jjrichar
Modded ///Member
No, the seal can stay in place. The vibration damper is what is running on the seal, so when the vibration damper is removed, the seal isn't touching anything. That being said, if you had the cover off, replacing the seal is dead easy. The seal is inexpensive, so it might be worthwhile doing while you are there.
Old 02-18-2014, 11:45 PM   #5
dwtaylorpdx
My Ride: 2005 330xi
I would never put a used one back on especially given the BMW history of weak rubber bits.. Just my personnel paranoia..
dwtaylorpdx is offline   Reply With Quote
Old 02-19-2014, 01:53 PM   #6
bee-em-dougle-u
My Ride: 2002 BMW 325i
Really nice tutorial, and excellent pics. Well done.
2002 BMW 325i sedan
Manual gearbox, but of course!
Tasteful mods
128K miles and counting
bee-em-dougle-u is offline   Reply With Quote
Old 04-08-2014, 01:31 AM   #7
mmbthug1
My Ride: 330ci
when I remove the*crankshaft pulley*nut do the*crankshaft pulley*come right off and the crankshaft sprocket do it come off easy. When I take off your oil pan can i have it halfway off. Im doing it with the engine in
mmbthug1 is offline   Reply With Quote
Old 04-09-2014, 03:56 AM   #8
jjrichar
Modded ///Member
As soon as you remove the large bolt that holds on the vibration damper (the crankshaft pulley) the vibration damper and the sprocket pull straight off. Because there is a seal around the vibration damper, it will be a bit tight, and might require a bit of jiggling. Note the chains need to be off the sprocket if you want it to come off. ie the oil pump needs to be removed, and also the vanos and all connected components in the head need to be removed. To get just the cover off, the sprocket doesn't need to be removed. It just depends on what you need to do
With the oil pan removed, the cover can come off as long as the:
-vibration damper is removed.
-all nuts are removed around the perimeter of the cover.
-the two dowels are hammered out.
Old 05-27-2014, 10:41 PM   #9
mmbthug1
My Ride: 330ci
So I do not have to remove the head to get the timing chain cover off
Old 05-28-2014, 08:19 PM   #10
jjrichar
Modded ///Member
The cover is jammed between the oil pan and the head, so you have to remove either one of these so the chain cover can come out. The easiest is clearly the oil pan, so no you don't have to remove the head.
Old 05-29-2014, 03:10 PM   #11
mmbthug1
My Ride: 330ci
Thanks got it here is some pictures
ID:	560016   Click image for larger version
ID:	560017   Click image for larger version
Old 05-29-2014, 03:14 PM   #12
mmbthug1
My Ride: 330ci
Was not hard just alot of time im going to put it back together later but my old chain was stretch and sprocket was bad and second timing chain was stretch
Old 10-05-2015, 11:59 AM   #13
revzillia
My Ride: audi/ M3
I know this is a old thread , but I did a search and this poped up . Very good info here , but have question ?? what holds the lower gear in place ? is the a second keyway ?
Reason being the large{Jesus} bolt worked its way out on my m-50 race motor and sheered off the keyway that holds on balancer . That spun aprox 100 degrees creating all kind of havoc..
revzillia is offline   Reply With Quote
Old 10-05-2015, 04:14 PM   #14
jjrichar
Modded ///Member
There are two keys that fit in the same slot. One closest to the end locates the damper, and the other locates the sprocket. There's a picture in this thread that shows this.
http://forum.e46fanatics.com/showthread.php?p=14278286
Old 10-07-2015, 05:54 PM   #15
redfeathers
My Ride: 2001 bmw 330 ci
curious, jjrichar, did you rebuild your engine? If so, where did you get all of the torque spec's?
2001 bmw 330 ci 250k miles white AUTO A5S 325Z steptronic
redfeathers is offline   Reply With Quote
Old 10-08-2015, 01:47 PM   #16
revzillia
My Ride: audi/ M3
Thx. The balancer key just sheered off. Got lucky
Old 07-28-2016, 01:22 AM   #17
devo76
My Ride: 2001 BMW 325i
Sorry I know this is a old thread, fantastic write up! My question is I sheered off my damper woodruff key and I went to install a new one and it fell inside the hole as I tried sliding the crank pulley back on. I can't seem to locate it anywhere inside that hole obviously with limited access. From your pics it looks like it could be hiding possibly along that bottom chain rail. I have tried everything I can think of to get this out with no luck. Do you think it's OK just to install a new key or am I going to have to take the chain cover off to get to it?
devo76 is offline   Reply With Quote
Old 07-28-2016, 02:16 AM   #18
jjrichar
Modded ///Member
There is a chance that it may have fallen all the way to the sump, but you can't be sure. To get the cover off you need to remove the pan first, so I would remove the pan, see if it's in there first prior to removing the timing chain cover. Even if it was in the sump, I would want to get it out prior to driving the car.
Have you removed the seal? This is the first thing I'd do if I couldn't find it. Not hard to get out and it will give you more room to look, use magnetic tool, etc.
Old 07-28-2016, 02:35 AM   #19
devo76
Thanks for replying JJRichar, I have been pulling my hair out over this man! So how does that seal come out. I'm not sure on how to do that. I just went out to look at that seal and I think I see what you are talking about. It's obviously the hard rubber ring around the hole the crankshaft is coming out but how does it come out? Thank you so much for the help!
Old 07-28-2016, 04:20 PM   #20
jjrichar
Modded ///Member
The best way I found to do it was to gently tap with a hammer/flat head screwdriver around the perimeter so it moves only about a mm so you break the seal. Then tap on one position only (say the 3 o'clock position) and use some sort of pulling tool (I use 3mm fencing wire often for tool like this to make a hook that would fit in the gap) and pull on the opposite side (9 o'clock). What should happen is it pivots around the 12 and 6 o'clock positions and then you can just pull it out. I've done it before where after the seal was broken, just hitting it in one spot had it rotate nicely and then just pulled it out, but I'd have a tool to pull on the other side as well so you have no chance of pushing the seal inside.
