Old 03-29-2012, 07:16 PM   #1
MJ80
My Ride: E92 335i M Sport
325i 5 speed questions, dodgey mechanic ??
Hello, I own a 2003 325i with the 5 speed auto. Just recently when its a bit colder in the morning's its been a bit clunky and can struggle a bit when taking off, once its warm it drives fine. I decided I would take it to an auto transmission specialist and get him to perform a flush and new filter. Now he's has just told me the box is stuffed and basically needs big $ spent which I don't for a second believe as the car is only 117k kms old and has driven absolutely beautifully untill just recently and the box feels fantastic still after a min or two of driving. Car has had a very good life and really was owned by an old lady befor me and she never drove it hard (fuel consumption was at around 8l/100k when I bought it. Tell me this mechanic is trying to take me for a ride and that the flush is all it should need, sitting in the waiting room of the garage now...
Sent from my HTC Desire HD A9191 using Bimmer App
MJ80 is offline   Reply With Quote
Old 03-29-2012, 07:41 PM   #2
fastjasonbmw
My Ride: 330Xi
Why do you think it is transmission related, you could have some vacuum leaks on the engine ?
fastjasonbmw is offline   Reply With Quote
Old 03-29-2012, 07:44 PM   #3
MJ80
Sorry should have specified, clunky when going into reverse and drive and very slight hesitation between gears untill warm, around 1 min.
Old 03-29-2012, 08:02 PM   #4
fastjasonbmw
My Ride: 330Xi
I would drain and refill the transmission with the correct fluid and also replace the filter. Don't let him use off the shelf ATF! And see how it acts afterwards. I would also recommed reseting/clearing the transmission adaptations, if they are able to.
Old 03-29-2012, 08:48 PM   #5
MJ80
Its out of its service and home now, drove like an angel, didnt even notice gear changes its so smooth, but it is warm and drove well before, though not this good.
Will only tell if the cold issues are gone in the morning, i reckon he was just trying to take me for a ride.
Old 03-30-2012, 07:42 PM   #6
xixixi
Banned User
My Ride: 01 330x-xi
did you do your inspection 2? If not why? I wouldn't touch that fluid/filter unless you check your clutch discs. As the fluid breaks down the tranny ups pressure to make up for the lack of friction (grip) in the worn down fluid. Do your homework. GL man, I'd just swap in a 5 speed and call it a day sir. With all the labor involved you would be way ahead of the game. BTW as the fluid heats up the friction additives of the fluid changes.
Old 08-06-2012, 03:40 AM   #7
MJ80
I should update this just incase anyone searches for a similar issue and this comes up, it turned out to be nothing, had the car serviced and they cleared the codes, updated the software apparently and its been 110% since, strange but solved.
