Old 03-30-2012, 02:49 PM   #1
328ci906
My Ride: 2003 M3
M3 Running Cold w/ New Thermostat??
I just picked up my first M3 last Friday knowing that it was running cold. I assumed it needed a new thermostat, but after installing a new one it still runs cold. It's definitly an improvement over how it ran before, but the needle still isn't dead center. More often than not it favors the cold side. Is it possible I got a bad thermostat? Or could it be something else?
-2000 E46 328i
-2006 E60 M5
328ci906 is offline   Reply With Quote
Old 03-30-2012, 02:51 PM   #2
aikmanson
My Ride: E30
Just out of curiosity, have you checked the actual temperature using the OBC function? It could be possible your gauge is reading wrong. Always look into the simple things first.
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 03-30-2012, 02:59 PM   #3
328ci906
My Ride: 2003 M3
Yeah I was thinking that, but even my oil temp gauge never hits center, it always stays below 210 even when I beat on it.
-2000 E46 328i
-2006 E60 M5
Old 03-30-2012, 03:01 PM   #4
rayryz
My Ride: 2003, 325i
It happened to me before, the new thermostat was bad, in my case I bought a cheap one on Ebay (around 30$), I returned it and bought another one from advanced auto (around 80$) and it worked fine.
rayryz is offline   Reply With Quote
Old 03-30-2012, 03:06 PM   #5
328ci906
My Ride: 2003 M3
Yeah, I guess it's possible. I bought this thermostat new from my local dealer. But I'm not convinced its bad, only because it is an improvement over the old one. So I'm thinking something else might be wrong.
-2000 E46 328i
-2006 E60 M5
Old 03-30-2012, 03:23 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
A few things you need to know, not sure if you had a normal E46 before this M3?
The standard E46 temp gauge is buffered and it always sits dead center over a 50+F range. Only if it goes over center you should be very careful.
The M cars have much colder thermostats and the temp gauge is not buffered. Your car should have a 79C stat, which means a 175F.
Your temp gauge should stay about 11-11:30 position until the outside temp gets to 65-70F then it may start to hit the dead vertical position?
Not sure on the M3, but the oil temp usually is going to be about 10-20F above the coolant temp? Not sure the M3 has the oil-water-air heat exchanger like my M5, but I assume it has some sort of oil cooler?
Best to check the link below in my signature for the Hidden OBC menu, bring up the coolant temp and watch it. Should not drop below 78-79 once it warms up. If this is where your temps are with outside at or below 70F then you are probably normal.
The M is a very different car than the standard E46 in many ways, so you need to read up on it.
Old 03-30-2012, 06:34 PM   #7
aikmanson
My Ride: E30
Great information here!
2010 MINI Cooper S
Old 03-30-2012, 06:38 PM   #8
MasterC17
My Ride: hates A/C & Sunroofs
As jfoj stated, the M3 needle is not buffered, and to run a little less than straight up is entirely normal (around 80C). The oil will usually stay right below the center 210f mark unless you beat on it (6k RPM plus multiple times). Tracking the car the oil temps can hit almost 300f if its really hot out and you are really beating it.
MasterC17 is offline   Reply With Quote
Old 03-30-2012, 09:52 PM   #9
328ci906
My Ride: 2003 M3
Thanks for all the info guys! I spent some more time searching the forums and have been reading exactly what you've said. People that DD their M3's in colder weather will show a slightly cold coolant temp on the gauge. It's been just about 45 degrees here for the past week or so, so it makes sense that my temp gauge wouldnt hit dead center. I feel alot better now that I know why my car has been running cold. I was afraid something else was broken...
-2000 E46 328i
-2006 E60 M5
Old 03-31-2012, 12:20 AM   #10
TerraPhantm
My Ride: M3 & ZHP
Completely normal. The M3's gauge isn't as buffered as the non-M. It's setup so that it's dead center from 83 to 85 degrees. It'll lean left below that and lean right above that. The m3's thermostat opens up at 80 degrees, so it will lean left for the most part. I confirmed this when I was studying the M and non-M eeproms; there is nearly no buffer in the M3 while the non-M buffer zone is gigantic. I'll see if I can dig up what temperatures the 1/4 and 3/4 dots represent.
Fwiw my oil temperature is around 180 in this weather. When it warns up, it's more like 190-200. I have to really beat on it to get it above 210
Old 03-31-2012, 12:51 PM   #11
328ci906
My Ride: 2003 M3
Ok that makes me feel a lot better. That's exactly the kind of temps I am seeing with the new thermostat. Now I just have to rebuild my Diff seals to make it 100%. I was just waiting to place my order for diff seals until I had this cooling figured out. Thanks for the tips guys
-2000 E46 328i
-2006 E60 M5
Old 03-22-2015, 10:50 AM   #12
BUDGET76
My Ride: 03' M3 & 95' 330TI
I just picked up an '03 and had the gauge sitting below the middle in 20*F weather. Figured it was normal, but wasn't sure. Thanks for the good info in this post, I'll have to look at the data a little closer and keep an eye on it before doing the thermostat/ temp sensor. They're due to get done this summer anyway, just going to move down on the priority list a little
BUDGET76 is offline   Reply With Quote
Old 03-22-2015, 03:26 PM   #13
jfoj
Might need to correct the info I original posted.
The E39 M5 runs a 79C thermostat AND (this is VERY important) the E39 M5 temperature sender sits DIRECTLY on top of the thermostat. So the E39 M5 displayed temperate is VERY close to the thermostat rating up to about 75F outside temperature.
I have since found out the M3 is slightly different. I do not know the "normal" temp the M3 runs (need some people to report in that have good thermostats), but the thermostat temp appears to be a 80C rating, BUT on the M3 the temperature sensor is at the water output of the cylinder head so I would expect the registered engine temperature to be approximately 10-15F higher than the thermostat rating.
So in theory I would expect the engine temperate on a E46 M3 with a properly operating thermostat to run around nominally 85-88C in at ambient temps below 75F??
