Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 03-31-2012, 12:38 PM   #1
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
DIY: PADDLE SHIFTER MOD: Pull both paddles for sport mode
Hey Guys,
I installed m3 smg paddle shifters in my steptronic wagon a few months ago using this link (thanks for that diy!) but I wanted to be able to engage sport mode by pulling back both paddle shifters at the same time momentarily.
To achieve this I had to combine both paddle signals into one signal to activate latching relay.
To combine both paddle inputs into one output. I used a standard 4 prong relay. I wired it as such
pin 85 : tap into right paddle output
pin 30 : tap into left paddle output
pin 86 : switched power (I found green wire going to switches above my ashtray that was switched power, double check!)
pin 87: output to latched relay
the logic behind this that one paddle would activate the relay, the other would ground out the signal going to the latched relay, effectively only working when both are pulled at the same time.
-Theoretically you could swap pin 87 for 87a on a 5 prong relay so that the car is in sport mode when you first start up and normal mode when you hit both paddles, however I haven't tested this.
To make the car go into sport mode and stay there, you need a latching relay which effectively close and open each time it receives an input. To accomplish this I used a DEI 611T programmable switch, other options may be available but this was cheap enough and would do the job well. I picked mine up on ebay for $20 shipped.
The 611t has 5 wires
red : switched power
black: ground
green: input from relay (pin 87)
yellow: ground
brown: goes to 4 pin wiring harness that you tap into for the paddle shifters (one wire for each paddle, one ground, tap into the remaining wire)
I really like this mod as it allows me to drive regularly in drive and pop her into the gear I want to in case I see a fun corner coming up without my hands leaving the steering wheel
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 04-12-2012, 04:27 PM   #2
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
This is looking more and more tempting since I got a line on a wheel with paddles for $200! Subscribed!
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 04-12-2012, 05:07 PM   #3
DOT.
My Ride: '04 ZHP Sedan
Wow. Great DIY!
Now to find a SMG wheel....
DOT. is offline   Reply With Quote
Old 04-12-2012, 05:12 PM   #4
engtariq
My Ride: 2001 325i
Great diy
engtariq is offline   Reply With Quote
Old 04-13-2012, 01:45 AM   #5
fgin
My Ride: e46 facelift
I have not done the relays or any other modifications apart from hooking up the paddles to shift in M mode.
When I pull both paddles it goes from M to SD.
After this mod I wonder if your cars firmware would compensate the fact that the lever is in Auto and you have placed the car in SD or M using the relays. Then, what if you move the lever to N or R before you switch it back to Auto?
fgin is offline   Reply With Quote
Old 04-21-2012, 07:20 PM   #6
redbull 325is
My Ride: 325xit/6
Interesting that your car automatically does the pull both paddles back to achieve sport mode. when I leave it in sport mode and shift into reverse or park the only problem is the light for sport mode down by the shifter stays illuminated instead of park or reverse/etc.
Old 04-23-2012, 01:06 AM   #7
fgin
Ah that's good. If not, i would think the EGS might get confused and something bad might happen.
Yeah not all cars are able to go back to SD from pulling both paddles. Recently I helped another member install a similar wheel on a 2001 325ci and it did nothing when you pulled both paddles. I think it must be a feature they programmed into certain firmware versions.
Old 02-23-2013, 09:10 AM   #8
redbull 325is
My Ride: 325xit/6
Kinda miss my paddles, but 6 speed aint bad either
Old 09-09-2013, 01:16 PM   #9
Trev1964
My Ride: BMW 320ci coupe auto
I used this guide to do mine last week, just wanted to say thanks for posting and sharing your knowledge.
Trev1964 is offline   Reply With Quote
Old 10-04-2013, 02:40 PM   #10
Trev1964
Had to remove this mod today.
My up shift paddle started playing up today.
Would take several attempts to get an up shift, down was still fine.
Took the wheel off and cleaned all the switches and connections, was still the same.
Removed this mod and its fine again.
Weird.
Old 10-04-2013, 03:29 PM   #11
///M Protocol
Banned User
My Ride: i3
cool beans
///M Protocol is offline   Reply With Quote
Old 10-04-2013, 03:31 PM   #12
Trev1964
Would still like this mod, or a version off it.
Old 10-05-2013, 02:15 PM   #13
Trev1964
Anyone give me a clue for a proper version of this mod please..?
Old 10-23-2013, 03:27 AM   #14
Mflara20
My Ride: 04 330i
I would love to see the video of how you did this DIY. I'm a visual learner sorry.
Mflara20 is offline   Reply With Quote
Old 10-23-2013, 04:12 AM   #15
Trev1964
Its straightforward.
The instructions are good.
Unfortunately mine started playing up.
Old 12-05-2013, 11:01 PM   #16
redbull 325is
My Ride: 325xit/6
strange, never had an issue with mine, maybe you had a loose wire or something? try reversing the inputs (upshift and downshift) and see where the signal gets distorted.
Old 12-06-2013, 03:10 AM   #17
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
I waited 5 years for this DIY. Thanks
delmarco is offline   Reply With Quote
Old 12-09-2013, 07:10 PM   #18
redbull 325is
My Ride: 325xit/6
least I could do, especially considering that I know atleast 4 people around me that have done radio/sirius mods thanks to your great DIY
Old 02-06-2016, 05:51 PM   #19
clabcon
My Ride: e46 330 Ci
Are these being produced commercially yet?
clabcon is offline   Reply With Quote
Old 03-10-2016, 08:17 PM   #20
clabcon
My Ride: e46 330 Ci
Hey Guys,
black: ground
yellow: ground
Does anyone fancy making me this for $100?
diy, e46 paddle shifter, sport mode
