#1 |
M54B30 mixture adaptations
Hello! I'm from Russia so sorry for my bad English
![]() I have an e39 BMW with M54B30 engine. In INPA software I checked an adaptation page. There is a problem in multiplicative adaptation - it's was too low (-6.8%) on both banks, but additive adaptation is nice (0.02). It seems like I have too much fuel in mixture. First I desided that my MAF is bad (I plug it off - and got a better power on low RPM) - so I got a new one (VDO-Siemens) - but nothing changes (it shows correct values 13.5kg on idle run) Fuel consumption is 15-16 l/100km in city ride with high traffic. Also I have a new exaust camshaft sensor (BMW original), new O2 sensors (all 4), new ignition coils (BOSCH). I replaced my VANOS seals and rattles repair kits 10000km ago to Beisan System orings. I checked a fuel pressure - it's OK. I made a VANOS test in DIS - reaction times is OK, but VANOS leak test failed (+ 25.3 and -25.6) I recorded some videos of INPA pages to show you. May be you can tell me what is the problem? I'll be very grateful if you will help me. Thank you! INPA rough test INPA O2 sensors INPA VANOS page INPA analog values INPA mixture adaptations |
#2 |
Buy besian system vanos kit, crimp the connector receptacles, update and reset the adaptations again.
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#3 |
#4 |
Well then can't help ya without looking at it.
#5 |
Banned User
I dont have much experience troubleshooting "rich codes" (i do know how to deal with lean codes though) but try checking the fuel pressure. I don't have the figers from the top of my head but I think your fuel pressure is 3.5 bar (95% confident). My rationale is that you have a malfunctioning component in your fuel system that is causing you to dump more fuel than what the engine is able to burn.
some other common areas for rich codes are a stuck injectors and dirty air filter (won't let enough air in). btw...are you running rich on both banks or just one? this is very important. both banks is indicative of a system wide failure (a component that is shared by both banks) whereas a single bank is more isolated. I hope this helps. good luck |
#6 |
![]() 2002 TiAg M3 OEM 19s/Fiamm triple air horn/Valentine V1/Uniden BCD396T/Uniden XL 520 Pro/Lightwerks TFX with 55 watt kit/Mediabridge 1500/Pro Fit iPhone bracket and holder |
#7 | |
so cute
![]() Quote:
Air filter changed 7000 miles away, but I bought a new one and I'll replace it in days. Also I'll try to flash a newer DME firmware. Injectors was cleaned and checked 5000 miles away, it's productivity are equel to each other. And yes, it's on both banks. |
#8 | |
#9 |
#10 |
Is the SES/Check Engine light on?
I doubt that you have any codes at the -6.8-8% Long term/mutiplicative fuel trims. Do you know if the car has had any performance software installed? Shark Injector/Dinan etc. I see very similar fuel trims (+0.02-0.03 short term/additive and -6-8% long term/multiplicative) in my M54B30 since I installed the BMW Performance Intake and had the Dinan Stage II software installed.
#11 | |
Car is full stock. BTW what can you tell about your intake tuning and performance software? how much performance addjustion did you fell? thanks! |
#12 | |
The only place it might have come into play was the backstretch at Road Atlanta and the straight after turn 3 at Road America.I can't use the increased red line, I haven't added the Dinan Auto trans software yet, it would work for a manual transmission!
#13 |
What was made:
both catalyst ripped off, DME flashed to euro-2 (2 O2 sensors still presents), intake camshaft sensor replaced (BMW original), adaptations cleared. And multiplecative adaptations still -6.5 on both banks. I don't know what to do next. |
#14 |
Why do you think you need to do something? Do you have a check engine light?
The ECU is able to adjust the air / fuel over a range to compensate for differences in each engine and wear over the life of the car. If it has to compensate more than a narmal amount you will get a check engine light indicating an issue. http://www.europeantransmissions.com...ptationBMW.pdf Fuel trim: refers to feedback adfustments to the base fuel schedule. Short-term fuel trim refers to dynamic or instantaneous adjustments. Long-term fuel trim refers to much more gradual adjustments to the fuel calibration schedule than short-term trim adjustments. These long term adjustments compensate for vehicie differences and gradual changes that occur over time.
#15 |
adjustment range is -7....+10 for multiplicative. -6.5 is on the verge of good and evil
#16 |
some news: changed fuel filter, still -6-7 adaptations. But!
I took a look at ignition plug - it have a white electrode. It means that mixture is lean. DME thinks that there is too much fuel incorrectly. Can it be O2 sensors who gave wrong information to DME? |
#17 |
unreal_rus
i have the same problem (multiplicative adaption near -11,1% bank_1 and -9,8% bank_2), did you find any solution? |
#18 |
No, the problem still exists. New fuel injectors - no changes.
#19 |
unreal_rus
did you measure oil pressure, check vanos' camshafts correct positions (reference) and check tappets? P.S. there is one opinion that electromagnetic valve (that opens oil flow to vanos) can leak and make problems... i didn't check this yet Last edited by 5eth; 11-06-2012 at 05:00 AM. |
#20 |
My Ride: '06 330CiC, '03 M5
Non OEM MAF's are known for at times under reporting the airflow and causing the DME to remove fuel, negative fuel trim values.
This will then actually cause a lean condition. An incorrect MAF would likely cause your problems. Can you read and post the Grams/sec at idle from your current MAF. I think about 6 Grams/sec and idle is pretty typical? Try an borrow or swap a known good MAF onto your car and see what happens. Good luck.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
