Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 04-01-2012, 07:43 PM   #1
mfischer267
My Ride: 1999 BMW 328i
Gimme ideas!
Just got myself a 99 328i! I love it and am wondering if there are any "must have" upgrades/mods I should do. Thanks!
mfischer267 is offline   Reply With Quote
Old 04-02-2012, 03:00 AM   #2
tag90
My Ride: 330ci
If you are looking for power you can gain quite a few HP by fixing everything that is broken. Perhaps you have a little hesitation at around 2500 rpms, look into vanos repair. Here is a DIY http://www.beisansystems.com/procedu..._procedure.htm Maybe you are slowly loosing oil could be the valve cover gasket or the oil filter housing gasket. Have you replaced the cooling system components yet? The expansion tanks are notorious for exploding. Pulleys, belts and other things could use to be done at the same time. How about the air filter? Spark plugs? Transmission fluid? Differential fluid? Does your car make a whistling sound as you are accelerating? Could be the lower intake boot.
Look into it. There is loads of good information on this forum just use the search function in the upper right hand corner. If you have a question just search, I imagine it has been asked before.
Welcome!
Photobucket
"You got a tree in your paint"
tag90 is offline   Reply With Quote
Old 04-02-2012, 03:13 AM   #3
calE46
My Ride: 325
Agree ^^ make sure you replace the cooling system. Make sure all your components are up to par first. Then make your car breath better intake/exhaust and headers if u wanna go that route. Good luck
calE46 is offline   Reply With Quote
Old 04-02-2012, 03:00 PM   #4
mfischer267
Thanks a lot guys. I will definitely look into what needs doing. Cooling system is a good idea
Old 04-02-2012, 07:34 PM   #5
Perry330ci
My Ride: 2001 BMW 330ci
Welcome to the site I'd say a good exhaust replace cats and a cold air. Do a good tune up and make sure everything is good to go. Stay away from headers unless you want big power and noise.
Perry330ci is offline   Reply With Quote
Old 04-02-2012, 07:41 PM   #6
Gillracing
My Ride: 2004 330ci
Welcome to the site i'm new also, My car seem to have everything that needed replaced or they did a hell of a job detailing it, But i just the cold air set up on mine!
Gillracing is offline   Reply With Quote
Display Modes
