Old 04-02-2012, 03:00 PM   #1
david @ eas
Past Site Sponsor
My Ride: E46 M3
eas | VF Engineering Supercharger Kits for your e46 M3 - MFEST Special Promotion!
With MFEST VI around the corner, EAS and VF Engineering have come together to offer MFEST special pricing for our valued forum members!
VF-Engineering chose to supercharge the BMW E46 M3 to add to already superior throttle response and give wild mid-to-top end power with the centrifugal Vortech supercharger. Maintaining the original BMW quality, smoothness and reliability were the key factors in the VF design. This is where the VFE software comes into full play. VF has harnessed reliability of Vortech superchargers and quality of VFE's custom software with their 15+ years of supercharging experience and worldwide OEM supply contacts to create the ultimate supercharger system for the ultimate driver's car.
All key components are 100% made and tuned in the USA. Supporting components such as flow matched injectors, radiators and water pumps are all acquired from German OEMs. This system has been fully road tested and dyno tuned on both the VFE Mustang MD500AWD and eas's in-house Dynojet 224XLC dynamometers with and without engine load.
Specifications
VF570 Supercharger system shown
VF420 Supercharger System, (4.0-4.5 PSI, 420hp, 320 TQ)
Supercharger system setup for 4.0-4.5 psi V3-SC trim supercharger system (non cooled). Replacement cast intake manifold prepared for aftercooler cartridge. High flow fuel injectors, Bosch MAF housing, VFE ECU flash. Easy to upgrade to VF480.
VF420 Supercharger system components:
- VFE custom tuned VF420 software flash
- 4.0-4.5psi supercharger pulley setup
- Top speed governor removed
- Vortech V3 SuperQuiet SCi trim supercharger (self contained, no external oil lines)
- Bosch MAF housing with recalibration
- 1 year unlimited mileage limited product warranty
- Replacement cast intake manifold
- VF CNC machined 6061 aluminum bracket system
- OEM BMW idler pulleys
- Stage 1 OEM High flow spray pattern matched fuel injectors
- VF Custom molded polypropylene ducting
- VF Custom tuned cast supercharger intake
- High flow Greddy Type R overrun bypass valve system
- Custom crank case ventilation system
- 4 ply silicon couplers with OEM screw clamps
- Replacement OEM serpentine belt
- K&N induction filter with cold air intake
- Comprehensive installation CD-ROM
- Precision Made in the USA
VF420 Specifications
PSI: 4.0-4.5
HP: 420 (Stock: 333)
Torque: 320 (Stock: 262)
MSRP: $5900
MFEST Special: $5162
Only 10 VF420 kits available at this special price!
VF480 Supercharger System (5.5-6.0 PSI, 480 HP, 340 TQ)
Supercharger system setup for 5.5-6.0 psi, V3-SC trim supercharger with air/water cooled cartridge inside cast intake manifold. High flow fuel Stage1 injectors with VFE ECU flash. Easy to upgrade to VF570.
VF480 Supercharger system components:
- VFE custom tuned VF480 software flash
- Replacement 5.5-6.0psi supercharger pulley
- Slide-in air/water heat exchanger for intake manifold
- VF custom molded 3 gallon water reservoir system
- OEM front center water radiator with OEM hangers and water lines
- Bosch water pump activated by key power relay
- Bypass valve spring upgrade
VF480 Specifications
PSI: 5.5-6.0
HP: 480 (Stock: 333)
Torque: 340 (Stock: 262)
MSRP: $8900
MFEST Special: $7787
Only 10 VF480 kits available at this special price!
VF570 Supercharger System (8.5-9.0 PSI, 570hp, 380 TQ)
Supercharger system setup for 8.5-9.0 PSI, V3-SC trim supercharger with air/water cooled cartridge inside cast intake manifold. OEM spring tensioner upgrade, Stage 2/3 Bosch fuel injectors, Hitachi MAF conversion, with custom VFE Software flash. Requires sport Cats downstream from header. Cold weather requires boost gauge monitoring and AFR gauge monitoring.
VF570 Supercharger system components:
- VFE custom tuned VF570 software flash
- Replacement 8.5-9.0psi supercharger pulley
- Replacement OEM serpentine belt & tensioner
- Replacement fuel pressure regulator
- Stage 2/3 OEM High flow spray pattern matched fuel injectors
VF570 Specifications
PSI: 8.5-9.0 (Stock: n/a)
HP: 570, 600 w/ race gas (Stock: 333)
Torque: 380 (91OCT), ~400 w/ race gas (Stock: 262)
MSRP: $9900
MFEST Special: $8665
Only 10 VF570 kits available at this special price!
System components are in stock and ready to assemble immediately. This product is not compliant with the California Air Resource Board and not for use on public roads in California. This applies to any aftermarket product that does not display a CARB EO#.
For in-house installations, a 25% non-refundable deposit will be taken in order to make an appointment.
Full info on VF Engineering systems can be found on our website here: http://www.europeanautosource.com/ca.../superchargers
If you have any questions or are ready to get a VFE Supercharger kit installed now, please feel free to contact me directly via PM, email or simply give me a call at 714.369.8524 x27
david @ eas is offline   Reply With Quote
Old 04-03-2012, 11:33 AM   #2
david @ eas
Past Site Sponsor
My Ride: E46 M3
Thanks for the inquiries, all PMs have been replied!
Old 04-05-2012, 02:45 PM   #3
david @ eas
Past Site Sponsor
My Ride: E46 M3
Option for custom powdercoated manifolds and intake elbow is also available if desired!
Let me know if you'd like to get your e46 M3 boosted!
Old 04-09-2012, 11:38 AM   #4
david @ eas
Past Site Sponsor
My Ride: E46 M3
Another shot of Orange Fever's VF Supercharged E46 M3:
Give us a call today to get your M3 boosted!
Old 04-11-2012, 01:42 PM   #5
david @ eas
Past Site Sponsor
My Ride: E46 M3
Anthony's VF480 equipped E46 M3:
MFEST VI is right around the corner, don't miss your chance!
Old 04-13-2012, 06:51 PM   #6
david @ eas
Past Site Sponsor
My Ride: E46 M3
VF420 on this Silver Grey e46 M3:
The clock is ticking, don't miss out on this special!
Old 04-30-2012, 12:11 PM   #7
david @ eas
Past Site Sponsor
My Ride: E46 M3
With Bimmerfest around the corner, we have extended this special for a limited time!
Don't miss out on this deal, give us a call today!
Old 05-02-2012, 05:11 PM   #8
david @ eas
Past Site Sponsor
My Ride: E46 M3
Here is a video of a VF480 equipped E46 M3 on the dyno:
Only a couple VF kits still available at this special price!
Old 05-16-2012, 02:02 PM   #9
eas
Past Site Sponsor
My Ride: BMW
Hurry time is running out!! Call today to order your VF kit while the sale lasts!!
