Go LSD or stay stock? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-02-2012, 06:07 PM   #21
TX78666
My Ride: 330i ZHP, N55 135i
Originally Posted by jcns View Post
Those who just don't get it will never appreciate what a LSD can do.
But, being able to appreciate it, and getting a couple thousand dollars worth of benefit, are two different matters.
Here's a riddle for everyone. All of the talk is always about power loss with an open diff, and inside wheel spin (other than the 1/4 mile stuff). If the inside wheel maintains traction, then (with an open diff) the outside wheel will spin faster than the inside wheel, as it needs to travel further. The outside wheel also should have more traction, since that's where the weight is.
An LSD does not know if one wheel is spinning faster because of lost traction, or because it is on the outside. It acts to keep them both spinning closer to the same speed as one another.
The riddle is, when both wheels have traction in a corner, does the LSD create a tendency for the rear of the car to want to go in a straight line? Does this affect handling?
I know the stock answer is that the LSD is better for handling, and overall, I don't question that it is. I just wonder about the physics of it, in the scenario described.
Anyone awake for that class?
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 04-02-2012, 06:15 PM   #22
JayKayo
Account closed at users request
My Ride: 2005 330Ci ZHP
Send a message via AIM to JayKayo
You got me excited with the "Go LSD"
JayKayo is offline   Reply With Quote
Old 04-02-2012, 06:15 PM   #23
TX78666
I guess I am particularly wondering, relative to the different setup options for LSD. Is it possible to set one up with not enough slip? All of my experience is with factory limited slip diffs. Part of me was sighing with relief, when my wife turned down the offer for a new diff. One less thing for me to figure out.
Old 04-02-2012, 06:44 PM   #24
E46330iguy
My Ride: Supercharged 330i
Da Fvck do you need a LSD for ? I dont even have one
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 04-02-2012, 06:58 PM   #25
Russian172
My Ride: e46 sedan e46 m3
my main reason if i were to get an lsd if there was a ton of snow and rain annually
in my case there is a ton of sh!tty weather so i do need a lsd some times but i live through it without the fun
OP if you can afford it go for it i personally think you wont but ill just say you should
Russian172 is offline   Reply With Quote
Old 04-02-2012, 07:16 PM   #26
shanneba
My Ride: 2003 330Ci
Do some searching for 1.5 and 2 way limited slip diff, the short answer is yes it can make the rear tend to go straight. (Of course you are at full throttle when you get to going straight on a track any way if you have enough traction )
Some interesting limited slip diff reading for your enjoyment !!
http://www.taylor-race.com/pdf/under...ferentials.pdf
http://www.performancegearing.com/specifications.php
http://www.wavetrac.net/
http://www.quaife.co.uk/shop/products/qdf14n
Join BMWCCA
Old 04-02-2012, 07:23 PM   #27
E46330iguy
Unless your putting down over 100 hp more than stock and a manual tranny you dont need an LSD even for the track < i track mine often and do just fine, You dont need to get one for wet road or snow either , I drove mine for nearly 3 years in the snow without problems
Old 04-02-2012, 07:26 PM   #28
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Originally Posted by Alex323Ci View Post
also, are you sure your pinion bearing is going out? have you checked your fluid and or replaced recently?
Was hoping a post like this would be here.
OP, diff whine is a very common thing. Have you looked to see if you have any signs of leaks around the seal in back, to the drive axles or from the drive shaft. Very easy to check the level...and to drain and fill.
Please start there. I understand the guys like their lsds, but you don't need it at all...and you don't need another diff.
My crappy stock pos 2.93 diff has 230K miles on it, doesn't whine, and brings me to 39 in first, 69 in second. I can't wait to show a 330 what a 328 can do on the dragstrip...coming up end of May!
Change the fluid first. Then, consider other things too before changing the diff. I can't say I've heard of one diff failure here at all. Because of that, you might also want to search your regional forum for a well-recommended Indy. Just saying!
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 04-02-2012, 07:28 PM   #29
E46330iguy
BMW Diffs are really strong, Im going with the low on fluid diagonis
Old 04-02-2012, 07:32 PM   #30
N89
My Ride: 330Ci
The indy I had do it (I don't have access to a lift and jackstands scare me) said he didn't drop the driveshaft which means the tape wasn't touched.. which means my diff truly whines.
Or I could put back my silent 2.93...
Hopefully mines doesn't wine, I picked up a 3.38 also... but what's this about "dropping the driveshaft"? I've never heard of anything like that with swapping the diff?
N89 is offline   Reply With Quote
Old 04-02-2012, 07:32 PM   #31
dmax
dmax's Avatar
da fvck do we need fluids for?
dmax on Facebook
Mangofy your E46!
Old 04-02-2012, 07:41 PM   #32
E46330iguy
His Indy dosent know what hes doing if he said thats the reason why it whines, By tape i think hes reffering to a sort of clayish substance that goes between the steady bearing and the car to dampen noise
Old 04-02-2012, 07:42 PM   #33
E46330iguy
Intoxication
Old 04-02-2012, 07:43 PM   #34
N89
My Ride: 330Ci
Yeah I'm getting ready to swap mines in over the weekend 'cause I should finally have time and this tape and drive-shaft dropping stuff threw me off.... I was like
Old 04-02-2012, 07:47 PM   #35
TX78666
Thanks.
I'll check that out. I was really just looking for the short answer (which you provided), but I will read the link, too.
Old 04-02-2012, 07:54 PM   #36
shanneba
My Ride: 2003 330Ci
Did you ever drive a BMW with a LSD in the wet, ice or snow?
If you did you would know the benefits.
Join BMWCCA
Old 04-02-2012, 07:56 PM   #37
Alex323Ci
My Ride: M3 & 323Ci (sold)
i give up!!!!!!!!!
way too many people posting about something they don't fully understand
i wish i had Moderator options so i could just delete the nonesense
Old 04-02-2012, 07:58 PM   #38
katu
My Ride: '04 330ci ZHP
Alex for moderator!
katu is offline   Reply With Quote
Old 04-02-2012, 08:01 PM   #39
JohnIBarr01
My Ride: ZHP 6MT, Mk.6, Jeep
LSD > No LSD. There's a reason it's almost always offered at an additional cost.
Don't believe me? Take two identical Jeeps, one with LSD's in both axles and one without, out on a mud-filled trail. Which one is probably getting winched out?
Pat Summitt Foundation | VWvortex | V2Lab | Twitter | Facebook
Originally Posted by TheGreenspanator
Let me guess: This doesn't happen in Germany
JohnIBarr01 is offline   Reply With Quote
Old 04-02-2012, 10:27 PM   #40
TX78666
LSD > non LSD yes.
Jeep analogy - no.
Take a Jeep with 44" mudders and a Jeep with Pilot Sports and throw them in the mud. I should then put 44" mudders on my e46?
Take a Jeep with 4WD and a Jeep with 2WD and throw them in the mud. So, I should have 4WD for the track?
The "higher price must mean better" idea is also dangerous.
LSD is better, but not for the reasons you cited, particularly in this application.
differential, lsd
