Old 04-03-2012, 08:45 PM   #61
JohnIBarr01
My Ride: ZHP 6MT, Mk.6, Jeep
Originally Posted by E46330iguy View Post
a 1000 horse power car here Higher above sea level taken down to the states tuned would make more than 1000 horse power down at sea level
I know this. Just being a Yank.
Sarcasm isn't understood too well here...
Pat Summitt Foundation | VWvortex | V2Lab | Twitter | Facebook
Originally Posted by TheGreenspanator
Let me guess: This doesn't happen in Germany
JohnIBarr01 is offline   Reply With Quote
Old 04-03-2012, 08:48 PM   #62
Andy2108
My Ride: SpecE46 & E46 M3
Originally Posted by mrbcc View Post
Hey all,
My differential pinion bearing is whining at 10+MPH. Took it in and the local shop (great guys, btw) and they quoted me a used diff replacement ("low mileage", 6mo warranty) diff "green-seal" improvement, boot seal replacement, general cleanup, fluid replacement, etc for about $985 (The diff was about $385, other parts about $150).
Asked if I brought in a new LSD and he quoted me 4 hours (~$100). thinking about $1700-2000k for the LSD diff...
So $2100-2400 for the LSD or $1000 for used, stock???
should I bite the bullet? Is the LSD that much of an improvement? what would you guys do?
brett
Buy an M3.
/thread
Old 04-03-2012, 10:45 PM   #63
E46330iguy
My Ride: Supercharged 330i
Sarcasm isnt conveyed over the internet very well
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 04-03-2012, 10:56 PM   #64
Andy2108
Was that sarcasm?
Welcome to 1993
Old 04-03-2012, 11:14 PM   #65
NOVAbimmer
My Ride: E60M
Sarcasm isnt conveyed into Canada very well
very true... you all definitely can't take a joke
NOVAbimmer is offline   Reply With Quote
Old 04-03-2012, 11:20 PM   #66
Andy2108
Where's BMWFFQ?
Old 04-04-2012, 03:04 AM   #67
Alex323Ci
My Ride: M3 & 323Ci (sold)
Your right i use to build 1000HP race car monsters i no nothing about LSD's at all
well i admit i may have come off rude. but the thread had already touched on the point that HP does not matter in being able to benefit from a Limited Slip Differential. then you posted something to the contrary. thus my frustration of "two steps forward, and then three steps back". if you're going to promote your theory of needing to be over 100Hp over stock and/or a manual needing a LSD i'd gladly point out all the reasons and cars that dismiss this thought. but i'm sure since you "no" 1000HP race cars and LSD you know enough that is was a misunderstanding in your post?? if not i'm always willing to hear and maybe see a new idea and reasoning to something already learned in my decades of building cars. i'm always open to learn from others if that's the case.
for what its worth, i personally installed LSDs in several of my BMWs
Old 04-04-2012, 01:49 PM   #68
EverydayGetaway
My Ride: 2003 330i ZHP
Power had very little to do with the usefulness of an LSD. My first BMW was a bone stock E36 318is with an LSD, and that thing could take corners faster, go through rain and snow easier and do just about everything better than my second 325is could because it had an open diff. There is a DRASTIC difference between an open and limited slip diff, anyone who says otherwise is kidding themselves. Open diffs give you less feel of the road, less control over what the back of your car is doing. I would definitely put an LSD in my 330 if it were cost-effective to do so.
On the topic, anybody know anything about these? http://bavauto.com/shop.asp
EverydayGetaway is offline   Reply With Quote
Old 04-04-2012, 08:10 PM   #69
mrbcc
My Ride: Silver 330i
Originally Posted by Alex323Ci View Post
are you talking about the $300 the shop is asking extra to change the seals and fluid in the new donor diff? or to have done on your current diff? changing the fluid on your diff shouldn't be more than $50. output shaft seals are very easy to do when the diff is out..very. i think you posted something else before about boots, like the axle cv boots. that is easy to repack with grease when the diff is out too. for them to change the output seals and change the fluid on a diff that's already out should cost no more than $100. $200 with labor and that's even on a very high side. i would shop around to another bmw indy shop or find your own used diff, have the seals done by someone else. then have it installed. most of the time the seals are plenty good, it's just easy to do when it's out and that part of labor already paid for when doing a diff swap. if you wanted the cheapest way, buy used diff off the forum or online at a salvage yard, put new fluid like Redline in and just have it installed.
They wanted to do a fresh seal on the new diff. Some kind of special sealing material, not the green paper seal they used to use. Based on your advice I think I'll just have them swap the fluid in the new diff and have it swapped out. Then done.
mrbcc is offline   Reply With Quote
Old 04-04-2012, 09:53 PM   #70
katu
My Ride: '04 330ci ZHP
BMW doesn't make the paper seal for the diff cover anymore. As you mentioned, the shop would use a rtv silicone sealant to reseal the cover, this is cheap and pretty quick to do. I did it on mine when I installed the 3.46.
katu is offline   Reply With Quote
Old 04-05-2012, 12:52 PM   #71
Alex323Ci
As katu said above. BMW stopped making the paper gasket for the diff cover seal. So it sounds like they want to scrape the old one off and seal with rtv. Which is basic stuff any garage or diy'er could do.
Old 04-05-2012, 01:00 PM   #72
Alex323Ci
Exactly, power does not mean one can't benefit greatly from a LS Diff. Contrary to another's post.
Another simple example is from bmw's lineup the 325es, '91 318is.
Old 04-06-2012, 08:26 AM   #73
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
I found that additional power just magnified the benefit of a LSD. I installed the OS Giken several months BEFORE the AA/2 SC kit was installed. I did notice a difference in cornering (even on track days as well) but not significantly enough to be worth the LSD's investment, IMHO. When the AA/2 SC kit was installed THEN I noticed a BIG difference in cornering, especially under power. This is why I posted at the beginning of this thread that a power increase would justify a LSD's cost much better. YMMV
Jim
Jim Murphy is offline   Reply With Quote
Old 05-20-2012, 10:47 AM   #74
gnome
My Ride: 2003 325iT
Been follwing the LSD threads - where is the best deal for a Wavetrac LSD for non-M? Aware of a group guy going on for Wavetrac?
Thanks.
gnome is offline   Reply With Quote
Old 05-20-2012, 10:58 AM   #75
330Cole
My Ride: 01' 330Ci
Doesn't an LSD make it possible to do doughnuts and drift as well?
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 05-20-2012, 12:39 PM   #76
bayjatt101
My Ride: 330i zhp
Is it possible to use a m3 diff on a 6speed zhp?
bayjatt101 is offline   Reply With Quote
Old 05-20-2012, 09:25 PM   #77
Andy2108
No. Buy a 240sx for that.
No.
Old 05-20-2012, 09:36 PM   #78
BeMyWhip
My Ride: 01 BMW 330ci
No.
I owned a 240SX back in the day when it wasnt a big deal; damn, should have hung on to it lol.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 05-21-2012, 06:11 AM   #79
330Cole
My Ride: 01' 330Ci
Well the short answer is no, but it can be done using an m3 tranny, driveshaft, and output shafts. Which probably would be too cost prohibitive for what ya get.
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 05-21-2012, 06:12 AM   #80
330Cole
My Ride: 01' 330Ci
No.
I was actually just thinking that right after I posted... Spot on, mate!
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
differential, lsd
