Old 04-09-2012, 04:46 PM   #1
redneckrice94
My Ride: 2000 323i
Tunable ECU/ECM?
I have been searching everywhere, and I know there are a few tunable standalones that work for non-M but I cannot figure out which ones will work.
Does anyone know of anyone that makes a tunable ECU for the 323i? I know they will probably cost somewhere in the 2500-3500 dollar range. If anyone has other ideas let me know. I want to go turbo but may have to do a supercharger instead since they make bolt on kits but I am looking to keep more torque and the AA stage 2 supercharger doesnt make enough for my taste.
"If you cant stand behind our Troops, feel free to stand in front of them."
redneckrice94 is offline   Reply With Quote
Old 04-09-2012, 05:58 PM   #2
lab rat
My Ride: '02 330iT
Under the hood of the 323 is not the right place to look for torque. I had the ESS twinscrew on a 325 and I only had about 200wtq.
It was fun but not as much fun as supercharged 330 (310wtq).
Because sleeper
Old 04-09-2012, 07:36 PM   #3
redneckrice94
My Ride: 2000 323i
How did the 330 make that much more torque?
Old 04-09-2012, 08:09 PM   #4
lab rat
My Ride: '02 330iT
Longer stroke, intercooler, additional 1.5 PSI (compared to the stage 1).
Because sleeper
Old 04-09-2012, 08:11 PM   #5
zcchen
My Ride: Z3M/F80M3
Some companies can build u harness for whatever car.. Apex does Pectel, Vipec and Motec I believe.. ProEFI is also another option.. the harness can be made given enough time and money.. don't believe there is any PnP kit for non-Ms
zcchen is offline   Reply With Quote
Old 04-10-2012, 06:20 AM   #6
SweTurbo
Big Pimpin'
My Ride: 323i -98
ProEFI has a PnP i was told by jason before
You should select ECU by whoever can do the tning for you , if you buy an ecu and have no tuner for it... well you can figure the rest out
Old 04-10-2012, 10:34 AM   #7
redneckrice94
My Ride: 2000 323i
I checked out ProEFI and nothing was on their website, but I will call them later today.
Old 04-10-2012, 10:57 AM   #8
SKIPPY PB
My Ride: YZ125
lol at this thread.
SKIPPY PB is offline   Reply With Quote
Old 04-10-2012, 11:15 AM   #9
redneckrice94
My Ride: 2000 323i
Most stock ECU's are not capable of calculating fuel and ignition timing for boost, which is why everyone has to tune their cars. I am willing to have my car tuned but my problem is that I cannot find any info on proper ways to turbo my car as I do not want the linear power band of a AA2 Supercharger.
Old 04-10-2012, 11:35 AM   #10
SweTurbo
Big Pimpin'
My Ride: 323i -98
A standalone is great if you actually work on your car , if you just want it to go fast and turn left then hit up nick @ techniquetuning.com
Old 04-10-2012, 11:55 AM   #11
redneckrice94
My Ride: 2000 323i
does anyone know anything about that shark edit software?
Sent from my SPH-D710 using Bimmer App
Old 04-10-2012, 12:14 PM   #12
sunnyjay
My Ride: 01 330i
Wrong, you have know how to in the form of changing the coding.
sunnyjay is offline   Reply With Quote
Old 04-10-2012, 12:27 PM   #13
redneckrice94
My Ride: 2000 323i
my main goal is to have software so that i can tune the car myself. I have friends that tune their own subarus and mitsubishis after building their engine and turbo systems from the ground up. our biggest issue is finding the software to modify fuel trims, ignition timing, etc on the stock ecm.
Old 04-10-2012, 12:38 PM   #14
sunnyjay
My Ride: 01 330i
Yes that is the issue, its not very diy friendly unless you understanding coding/hex addressing. There is a open source tuning solution for all the dsms and subarus and its easy to use.
Old 04-10-2012, 12:48 PM   #15
redneckrice94
My Ride: 2000 323i
So my best bet is to wait for the Shark Edit? I am just trying to figure out my best way to build my car as I dont want to just buy a kit. Also, if I throw the money at my car that a kit would require, I would make less power and spend more money than just trading my car in for an M5 so I at this point am stuck between a rock and a hard place.
I am really open for any ideas!
Old 04-10-2012, 12:51 PM   #16
sunnyjay
My Ride: 01 330i
You can wait for shark edit but I doubt it will come out. You can alway use some of the other stand alones like proefi, vipec, motec, and others.
Old 04-10-2012, 12:59 PM   #17
redneckrice94
My Ride: 2000 323i
ProEFI looks like it would be the best of the ones you listed, however, can you tune proefi or other standalones to use the dualvanos system properly?
Old 04-10-2012, 04:45 PM   #18
02PRUV
My Ride: E46 M3 Turbo
Use Vipec. And yes it can do the vanos. I use one on my M3 and it works great with the vanos.
They also have all the BMW setups so you can go in and choose your crank and cam triggers from a drop down menu and just start tuning. They would also probably have a base map to get you running.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-10-2012, 09:14 PM   #19
mike@maximumpsi
My Ride: 02M3T
There are no current standalone EMS options that I know of that will allow you to pass an OBD2 Scan. Aside from that, there are numerous options if you are going to build your own harness. If not, Jason@ProEFI, Neel@apexspeedtechnology, or a handful of others can build you a plug-in solution for the right price.
As for DME editing software, you will not find that anywhere at the moment. While Shark Edit is a possibility, it's timeline is questionable at best.
You also happen to have a E46 with very limited aftermarket FI options. Do you already have an AA kit? ESS makes a twin screw SC kit that may satisfy your needs.
I honestly think your best bet would be to sell your 323 and choose a different platform to start with. TT offers a great turbo setup for the E46 330's with a nice torque delivery, and we will be offering our E46M3 kit soon.
-Mike
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 04-11-2012, 12:49 AM   #20
lab rat
My Ride: '02 330iT
+1
with the prices you are looking at for standalone ECU the 2k for used M54B30 is pretty cheap.
If you want to keep it on the budget with stock DME look at the W.A.R. chip. While not designed to make a brand new fuel map it could be used to modify existing FI tune.
Because sleeper
