Old 12-18-2012, 10:45 AM   #21
MaverickM3
My Ride: gets badge
Glad you got it worked out.
MaverickM3 is offline   Reply With Quote
Old 12-18-2012, 12:53 PM   #22
nnacpil
My Ride: 2006 BMW M3
Thanks for replying. I checked my wg lines and one of the connectors from the skinny hose to the thick hose was broken. Went to advanced auto to pick up a vacuum connector and fixed the line. Put everything back together along with testing the solenoids which btw works properly. Tested the car and was still over boosting.
Wanted to mention that I recently swapped my SS race exhaust to hpf's ti exhaust. Since the back pressure is reduced, would this cause my over boosting issues? I've read that people would have to send their ems back to HPF for a new tune. After checking the map sensor, boost solenoids, and wg lines, it has lead me to believe that I need a new tune.
Anyone care to input? Thanks.
2006 BMW lllM3 SilverGrayMetallic/Cinnamon/Apex Arc-8
llHPF/ProEFI Stage 2.25 w/6766
SOLD!!!!!!!!!!!
nnacpil is offline   Reply With Quote
Old 12-18-2012, 01:19 PM   #23
Commanderwiggin
My Ride: 1000rwhp Turbo M3
You went from a muffler to straight pipes...so I would say you definitely have quite a bit of reduced backpressure which would cause some overboost most likely if it wasn't tuned for it...that much overboost? Tough to say...
Old 12-18-2012, 01:29 PM   #24
nnacpil
Thanks. I'm waiting for Chris k to reply back to see what he thinks. He's been helping me.
We've lead to think it was wg related so he had me check the lines. My dump isn't even opening up on boost. The Tial wg is brand new but could it be the dump itself or wg?
SOLD!!!!!!!!!!!
Old 12-18-2012, 01:45 PM   #25
Commanderwiggin
If it's not opening up on boost then something else is wrong.
Old 12-18-2012, 01:55 PM   #26
nnacpil
Any ideas? Wg or dump issues?
SOLD!!!!!!!!!!!
Old 12-18-2012, 10:08 PM   #27
GRK///M3
My Ride: LSB M3
Originally Posted by zac5 View Post
No, I can't. but then if I get the meth system, i have to send the ems back to HPF to get a retune, right?
No you don't, HPF loads the stage 2 tune on your AEM by default . I called and asked before I put my meth kit on. Worked just fine without sending the AEM back.
Sent from my SAMSUNG-SGH-I717 using Bimmer App
GRK///M3 is offline   Reply With Quote
Old 12-19-2012, 03:57 AM   #28
zac5
My Ride: Turbo M3
Yes, I figured that out when I had meth kit installed later. Thanks all the same.
zac5 is offline   Reply With Quote
Old 12-20-2012, 05:41 AM   #29
Evil Twin Rob
My Ride: 2004 M3
My car was overboosting and it turned out to be a bad wire in one of the HPF harnesses. I believe they replaced the harness that tied the AEM to the factory ECU, but I can't say for sure.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 12-20-2012, 06:17 AM   #30
nnacpil
Thanks. I hope that's not the case. How was that determined the problem?
I was thinking to buy race gas next weekend to record some solid pulls to show you guys what I'm seeing.
SOLD!!!!!!!!!!!
Old 12-23-2012, 02:50 AM   #31
Evil Twin Rob
My Ride: 2004 M3
Pretty much just trial and error. It ended up being the last thing on the checklist because it was the hardest component to swap. Fortunately the car was already at HPF when it happened.
HPF 2.5
Old 12-23-2012, 02:58 AM   #32
nnacpil
I see. Well I've talked to HPF and they want me to send my ems out to them for a new tune. I'm hoping this will be an easy fix. I'll keep the thread posted for results once I get it back.
SOLD!!!!!!!!!!!
