Old 03-05-2015, 07:56 PM   #1
Smwillrich
My Ride: 00' 328i Sedan 5MT
E36 to e46 welded diff swap???
Can this be done? Is it compatible? My buddy has an e36 318 diff laying around and I want to weld it up if it is compatible I have a 2000 328i sedan and plan on sliding it with the lower gear ratio from the 318 diff! Someone help thanks!
Smwillrich is offline   Reply With Quote
Old 03-05-2015, 09:08 PM   #2
invisible man
My Ride: invisible car
Completely different case.
Giubo. G I U bo. Pronounced joo-boh. Don't allow yourself to sound ignorant.
invisible man is offline   Reply With Quote
Old 03-05-2015, 11:36 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Yeah, you'll need an E46 diff. Assuming that you have a 5 speed*, a 3.46 diff would be cheap to purchase & great to weld up. Understand that there are "Cons" to a welded diff if you don't already realize this.
Good luck,
Rob43
* If you have an Auto trans, you already have a 3.46 diff.
Then you want a 3.64 diff, which will most likely be harder to find.
SUMMIT POINT WV 1:24:229 SCCA
Old 03-06-2015, 02:22 AM   #4
Smwillrich
I had a feeling they were two completely different cases just didn't dig deep enough to find it out myself, and yes it's a 5 speed. So knowing that now the question is does every 5 speed e46 diff bolt right up. I want to find a 318 diff for the lower gear ratio.
Old 03-06-2015, 03:16 AM   #5
paraklas
My Ride: ESS TS2 320ci
E46 318i has smaller diff case (168K) than the 320> models (188K)
Old 03-06-2015, 03:38 AM   #6
Smwillrich
hmm.. Well that sums that up for me. So a welded 3.46 is the way to go huh?
Old 03-06-2015, 02:55 PM   #7
Rob43
Rob43's Avatar
The 3.46 diff is about a 18% increase over your current 2.93 diff and it's relatively easy to purchase. Everyone that does this mod seems to really like it, I'm sure you will too.
Good luck,
Rob43
Old 03-07-2015, 01:41 AM   #8
Smwillrich
Anyone know where I can find a non welded 3.46 diff in the states? I live in Washington state and will pay for shipping at the right price.
Old 03-07-2015, 03:03 AM   #9
paraklas
ebay?
http://www.ebay.com/sch/i.html?_from...Text=&_sacat=0
