Steering wheel vibrations... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 04-03-2012, 11:36 PM   #1
abdkhan1
My Ride: 2005 BMW 325ci
Angry Steering wheel vibrations...
I have gotten new tie rods, new tires and replaced my oem bushings to MEYLE ones. I still have some wheel play on freeways speeds. It seems to be getting annoying after a while. I have gotten the wheels balanced multiple times, and checked for wheel bents and NOTHING! The only thing I can think of that could be ****ed up is Control Arms and or Sway Bar end links. I really need some advice plz, I would really appreciate it.
abdkhan1 is offline   Reply With Quote
Old 04-04-2012, 12:22 AM   #2
ating
My Ride: 2004 M3
what wheels do you have?
ating is offline   Reply With Quote
Old 04-04-2012, 12:27 AM   #3
abdkhan1
17' ASA AR1 with 235/45/17 Continental DWS all around.
Old 04-04-2012, 02:23 AM   #4
ating
My Ride: 2004 M3
Do your wheels require hub centering rings? If they do, but you don't have them, you'll get wheel vibrations.
e.g http://forum.e46fanatics.com/showthread.php?t=846918
You'll need to do some research on whether or not your wheels need these rings.
Old 04-04-2012, 04:12 PM   #5
abdkhan1
They don't require hub rings. They are wheels are exactly hub centric. I however think it could be my steering coupling.
Old 04-05-2012, 09:52 PM   #6
abdkhan1
Smile
So turns out that it was my steering coupling after all.
Old 04-06-2012, 07:32 AM   #7
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Thanks for the update.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 04-08-2012, 08:07 PM   #8
Ky///m3
My Ride: 1988 E30 M3
did you only experience it above 60? i am having the same problems and wonder if it is the same thing. just your steering wheel vibrated left to right correct?
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline   Reply With Quote
Old 04-10-2012, 10:15 PM   #9
abdkhan1
So a couple days into my fix and I'm getting those shimmers above 60mph again. So I decided to buy control arms (meyle brand). Hope this resolves my issue once and for all. Because I'm tired of this bullshit.
Old 04-10-2012, 11:11 PM   #10
Ky///m3
I'm taking my car to BMW in the morning to figure this **** out. I have the same issue and have been chasing it for awhile. I'll post the results
Old 04-10-2012, 11:30 PM   #11
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Control arm balljoints
control arm bushings
tie rod outer balljoint
inner tie rod
wheel
tire
wheel bearing
those are areas that can cause steering wheel vibrations. if you look at the suspension you should be able to figure out why i mentioned these components. if there's play in the balljoints then there is definitely a vibration.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 04-10-2012, 11:51 PM   #12
abdkhan1
inner tie rod
wheel
tire
wheel bearing
Well said.
Old 04-11-2012, 04:23 PM   #13
Ky///m3
Your caliper could be sticking. What's what's wrong with mine.
Old 04-11-2012, 04:32 PM   #14
abdkhan1
Exclamation
How can I check if I have issues with my calipers?
Old 04-11-2012, 06:25 PM   #15
Ky///m3
When car is cool, take it on the expressway till the vibration starts. Drive for a few minutes then pull over and inspect rotors/around wheel area. If warmer than usual.....by this I mean excess heat......you have a caliper stick issue.
Maybe someone knows a better way?
Old 04-27-2012, 12:00 AM   #16
abdkhan1
Update: So I replaced the control arms with meyle ones and it fixed my steering shimmers.
Old 04-27-2012, 12:20 AM   #17
Turntables83
My Ride: 2005 330i ZHP
Nice! Good to know. Thanks for update.
Turntables83 is offline   Reply With Quote
bmw, e46, problem, steering, vibration
