Old 04-04-2012, 12:13 PM   #1
TheKingSim0n
My Ride: BMW 325i
Send a message via AIM to TheKingSim0n
Speakers for E46 Sedan (Non HK)
I am just trying to verify which is the best set up for audio speakers between Vibe Audio Space 5 and Vibe Audio Space 6? I have the stock amp with Dynavin Android navigation unit.
Space 5: http://www.sonicelectronix.com/item_...o-SPACE-5.html
Space 6: http://www.sonicelectronix.com/item_...io-SPACE6.html
After searching the forums i see they are both recommended so idk which to pick for my E46 Sedan (Prefacelift, if it matters) ?
TheKingSim0n is offline   Reply With Quote
Old 04-04-2012, 12:37 PM   #2
vadim
My Ride: 08 E92 335i, 05 325i
You want 6.5" speakers, so VAS 6 would be a better choice; however, they are NOT plug-and-play replacement of the OEM speakers. Just beware that you will need to do some modifications for them to fit.
vadim
'05 E46 325i MT
'08 E92 335i MT
'11 X5 35d
vadim is offline   Reply With Quote
Old 04-04-2012, 12:57 PM   #3
TheKingSim0n
My Ride: BMW 325i
For them to fit into the speakers housing or the actual connections and cabling need to be modified as well?
Old 04-04-2012, 01:31 PM   #4
BigDRick323
My Ride: 2000 323i
Yes, anything other than OEM or BSW will have to be modified to some degree, but it is more than worth it and if you do it correctly no one will notice that modding has been done. I am rocking Vibe 3D along with MB Quarts up front, JL 650 in the back and JL 12" in the trunk. It's the BOMB!
Old 04-04-2012, 01:40 PM   #5
FenderGuy05
My Ride: 2002 BMW 325i
The amount of modding is small. I just recently upgraded my set to some older alpine type s components(from previous car) and they definitely kick better. You just have to tap into the wires for the stock harness, i just cut the clip off the end.
Now I just have to get my damn amp working to get some good highs.
FenderGuy05 is offline   Reply With Quote
Old 06-07-2012, 11:59 AM   #6
TheKingSim0n
My Ride: BMW 325i
So you guys are running these Vibe speakers on stock amp?
Old 06-07-2012, 01:55 PM   #7
Mr_325
My Ride: 2007 X5 3.0Si
just got the newest kenwood 2din installed and i'll probably be going infinity's all around with a 10" digital design comp sub in the trunk
Mr_325 is offline   Reply With Quote
Old 06-07-2012, 02:16 PM   #8
tony325ci_51
My Ride: BMW 335i 2007 Coupe
You'll need speaker converters to go from the BMW stock 3-hole template to more common 4-hole mounting speakers. Like these:
http://www.caraudiodirect.co.uk/con-...nt-and-re.html
13cm speakers are designed to drop in to these converters but are too small for good sound (I've tried them).
You then need to modify the converters to accept bigger speakers. Strictly speaking 6.5" (17cm) are too big, you'll find 6.25" (16cm) speakers fit better.
Hint: many speakers will have 16 or 17 in the part number to denote speaker size in cm, look for 16.
You'll also need to chop the OEM BMW speaker plug off and join standard plugs to the wires. As long as you observe polarity (and insulate nicely) all should be well.
There's a DIY here:
http://www.e46zone.com/forum/topic/5...-an-e46-coupe/
tony325ci_51 is offline   Reply With Quote
Old 06-07-2012, 02:48 PM   #9
optrs
My Ride: 01 330ci,94 325is
You can find 6.5" front speaker adapters on ebay http://www.ebay.com/itm/BMW-E46-6-5-..._Video&vxp=mtr
optrs is offline   Reply With Quote
Old 06-07-2012, 09:05 PM   #10
roosty
My Ride: 330ci
new to the forum.... hi. what amp is best for the space6 speakers? i just got a 330ci and all speakers are BLOWN. space6 looks like what i want to do. dont have any factory amps. its the factory head unit non-HK. and im not 100% certain that the 6.5" will work for my car... its an 02 330ci coupe non-HK.
roosty is offline   Reply With Quote
