Old 04-04-2012, 05:28 PM   #1
Flaboy239
My Ride: 2004 330ci
Car stalls at idle...
I recently purchased a 2004 330ci. It runs and drives great but it has stalled on me twice sitting at red lights. It starts right back up and drives with no issues. Any idea what could cause this?
Flaboy239 is offline   Reply With Quote
Old 04-04-2012, 05:59 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
I suppose it's possible this car has never in its life received a DME software update. I had a problem with this back in 2004 shortly after I bought my car. A software update resolved the issue. You might contact a dealer and see if they have any record of an update being performed. It's also possible you have an actual maintenance problem but that would require some diagnostics to get to the bottom of things.
Old 04-04-2012, 06:07 PM   #3
Flaboy239
My Ride: 2004 330ci
The car was tuned by Active Autowerke. Not sure if that means anything. Idk what dme means. I'm new to the bimmer world.
Old 04-04-2012, 06:18 PM   #4
TxZHP04
The DME is basically the engine computer. If Active tuned it then you need to talk to them. Is the car stock otherwise? What air filter is in the car?
Old 04-04-2012, 06:24 PM   #5
PNWDiego
My Ride: 328ci
check for codes in the computer, that'll give you a clue as to where/what
PNWDiego is offline   Reply With Quote
Old 04-04-2012, 06:26 PM   #6
Flaboy239
My Ride: 2004 330ci
No it's far from stock. The previous owner took it to active and dropped $25k on it. I'm not going to list it all, there's too much. There's a couple threads where I list most of it. Maybe I'll run it through a scanner to see if any codes come up.
Old 04-04-2012, 06:34 PM   #7
TxZHP04
Oh, it's that car, the one with the SC'er and too many other mods to list. Yeah, check for codes but you'll still likely want to talk to Active for troubleshooting advice. Could be the tune, could be the MAF, could be any number of things. If you have an oiled air filter (such as K&N), it may have contaminated the MAF. Might want to try some CRC MAF sensor cleaner to see if that helps.
Old 04-04-2012, 06:39 PM   #8
Flaboy239
My Ride: 2004 330ci
It had AA headers on it and was tuned for the headers and no cats. The dealership hat to put the stock manifolds and cats back on it in order to legally sell it. I thought maybe that could have something to do with it. I need to get the headers on ASAP.
Old 04-04-2012, 08:38 PM   #9
TxZHP04
I don't know that it's impossible but it seems highly improbable that stalling at idle is related to the header switch.
Old 04-06-2012, 03:13 AM   #10
YOLO89
My Ride: Hooptie
I too have the same issue it even stalled on me while making a turn. I've ran it for codes and haven't found anything. Mine isn't modded either but let me know if you ever figure out what the issue may be...
YOLO89 is offline   Reply With Quote
Old 04-07-2012, 12:44 PM   #11
fatboyx9
My Ride: 325Ci 330i
I have a 325Ci and dies occassionally while backing up, has dies a few times while pulling out in first. I cleaned the MAF sensor with CRC cleaner. It's a 5 speed. Still trying to figure this out.
fatboyx9 is offline   Reply With Quote
Old 04-07-2012, 02:13 PM   #12
TxZHP04
For those of you without engine mods and no stored codes, try cleaning your ICV.
Old 04-07-2012, 04:07 PM   #13
fatboyx9
My Ride: 325Ci 330i
Replaced my ICV.
Old 04-07-2012, 04:24 PM   #14
xixixi
Banned User
My Ride: 01 330x-xi
It's your maf or an intake leak
Old 04-07-2012, 04:38 PM   #15
TxZHP04
Originally Posted by fatboyx9 View Post
Replaced my ICV.
Have you scanned for codes? Checked fuel trims? I only suggested ICV if these other things didn't pan out.
Old 04-07-2012, 04:39 PM   #16
Flaboy239
My Ride: 2004 330ci
Now my check engine light is on. I'll scan it Monday and see what pops up.
Old 04-07-2012, 04:42 PM   #17
xixixi
Banned User
My Ride: 01 330x-xi
maf or intake leak, get a cigar and start blowing!
Old 04-07-2012, 04:44 PM   #18
Flaboy239
My Ride: 2004 330ci
That makes sense because sometimes at idle my rpms will get a little erratic for a few seconds. All signs point to intake or vacuum leak.
Old 04-07-2012, 04:46 PM   #19
xixixi
Banned User
My Ride: 01 330x-xi
5 dollars please! This is a test you can do, hammer the throttle until you get to a corner, mash on the brakes. I bet that thing dies GL man
Old 04-07-2012, 05:06 PM   #20
Flaboy239
My Ride: 2004 330ci
Check is in the mail...
