Old 04-07-2012, 05:24 PM   #21
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by Flaboy239 View Post
Check is in the mail...
Hope you get it figured out man! Let us all know!
Old 04-07-2012, 08:09 PM   #22
fatboyx9
My Ride: 325Ci 330i
Scanned codes, none, have't checked fuel trim's.
fatboyx9 is offline   Reply With Quote
Old 04-08-2012, 03:11 PM   #23
Chayan
My Ride: 330i 04
Hey there, I have a 330i 2004, I had the same issue, my RMP will bounce between 400 to 700 on idle and sometime it will stall. It is a problem with late model engine and I had it fix it by re-flashing a new version of the DME. You can ask to your BMW dealer, I think it's around 100$ OR you can do like me and find a good friend who has the BMW diagnostics program and did it for free
here is the bmw bulletin report: http://www.argyrides.eu/bmw/mods/stall/stall.htm
You can download the diagnostic program and buy a 30$ obd2 cable and have your own diagnostic program. ( you can code whatever you want like the dealer)
look in the bimmer forum for more info.
Chayan is offline   Reply With Quote
Old 04-15-2012, 06:43 AM   #24
fatboyx9
My Ride: 325Ci 330i
Anyone beside the "stealership" update the DME? My local dealership want's $199 and up to 6 hours to do the reflash.
Old 04-15-2012, 07:11 AM   #25
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You didn't say what you'd done to check for intake leaks. If you replaced the icv yourself, often the lower boot stays on, but it's not seated right.
There are lots of hoses that can crack/leak and I'd begin there before tossing money on reprogramming. Truth is, if it worked before, things were fine. That said, with your 'stuff' under the hood and stock header back on, maybe the old tune won't work well for what you have now...and if you do get it reprogrammed, then add the old headers back on, you'll end up with the same issue again.
...just another reason to keep things stock...makes it much easier to figure things out...although it can still be tough enough to be entertaining!
Good luck, OP!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 04-15-2012, 07:46 AM   #26
Flaboy239
My Ride: 2004 330ci
I installed the headers a few days ago. The car hasn't stalled again but the rpm will still jump. I found a receipt from the previous owners mechanic and it stated that the intake needed to be removed to find an intake leak. Service was not performed tho. So now I'm positive it's an intake leak. I'll find it eventually.
Flaboy239 is offline   Reply With Quote
Old 04-15-2012, 08:56 AM   #27
fatboyx9
My Ride: 325Ci 330i
I replaced the ICV myself, haven't checked for vacum leaks, waiting on smoke machine. Car is all stock. Replaced plugs and pre-cat O2 sensors, cleaned MAF.
Old 05-09-2012, 09:33 AM   #28
Sweetness
My Ride: '01 325i
Camshaft position sensor
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 05-09-2012, 06:34 PM   #29
fatboyx9
My Ride: 325Ci 330i
Intake cam sensor?
