Old 04-05-2012, 05:04 PM   #1
bimmerkidd03
My Ride: 2003 325ci convert
2003 e46 convertible passenger door wont unlock using key of unlock button
Hello, i cannot get the passenger door to unlock on my 2003 convertible, when i use the key and press unlock only the drivers side door unlocks, and the same thing when i press the unlock button inside the car. the only way it opens is if i reach over and open it from the inside using the door handle inside the car. it used to unlock but not it doesnt work, any idea what could be wrong?
bimmerkidd03 is offline   Reply With Quote
Old 04-05-2012, 05:09 PM   #2
My Ride: Lexus
GM5. Rebuild it.
Old 04-05-2012, 05:49 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
See the link below in my signature for GM5/door lock problems.
Suggest you e-mail Scott @ www.bmwgm5.com and ask him what he thinks.
Sounds more like a door lock solenoid to me?
Old 04-07-2012, 12:19 PM   #4
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
There are no solenoids used in the door lock assembly. There are two motors in each door for the locks. One for single lock and one for double lock.
OP, most likely the door lock/latch assembly needs to be replaced. GM5 problems are intermittent. Your problem sounds like a solid failure.
scottjoh is offline   Reply With Quote
Old 04-10-2012, 10:03 PM   #5
bimmerkidd03
Thank you for the replies! I did buy an aftermarket warranty from the dealer but I doubt this problem would be covered by it right?
Old 04-10-2012, 10:17 PM   #6
tcphoto
My Ride: E92 335 MT Coupe
Try pushing the unlock button twice. Read the manual.
tcphoto is offline   Reply With Quote
Old 04-12-2012, 01:19 AM   #7
edwin05
My Ride: E46 M3
i have the same problem but mine is the driver door that wont open if you fix it can you tell me how please because im tired of going to the passenger door to open my door
edwin05 is offline   Reply With Quote
Old 04-14-2012, 02:26 PM   #8
SuperSleeper
My Ride: 2003 330CIC
That is timing
Wow, I have 03 vert too, and the this just started with me on the passenger door as well. Locks ok, but can't unlock electronically either from key or inside car.
SuperSleeper
SuperSleeper is offline   Reply With Quote
Old 04-14-2012, 02:29 PM   #9
SuperSleeper
Actually discovered one more thing. Doors lock with key only, not with internal button.
SuperSleeper
Old 04-14-2012, 03:53 PM   #10
jasonbimmer
My Ride: 2001 BMW 330xi
the button and the hazard switch is prone to break. search. there is a DIY shows you how to fix it.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
