Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 04-05-2012, 06:03 PM   #1
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Thumbs Up Kevin's E85 BURNING HPF Stage 1 Turbo BMW M3 w/HPF-AEM
Kevin drove and raced his E46 M3 with our stage 2 and 2.5 turbo kits for several years. He recently bought another gorgeous white E46 "SMG" M3 and shipped it to us for our HPF/AEM "E85" tune. This car is running our standard stage 1 turbo system with no other modifications except for our in tank walbro pump upgrade, FIC injectors and E85 for fuel. The switch on his steering column switches between low boost (6psi) and high boost (12psi). The car is so quiet and so smooth. A 620rwhp "stealth" daily driver is very cool.
Chris.
HPF/AEM w/E85
HPF Chris is offline   Reply With Quote
Old 04-05-2012, 06:09 PM   #2
Ky///m3
My Ride: 1988 E30 M3
Chris, have Kirk call me. I want this
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline   Reply With Quote
Old 04-05-2012, 06:13 PM   #3
M3PTGSC
My Ride: M3
Wow nice!! This is great for people who don't want to spend extra money to swap everything
09 SL63 AMG Designo,pano and whole nine yards lol
07 S550 P2 4matic-gone
03-M3-6766 DBB..Tubular manifold...
97-M3-
95-M3 SC stage 2-Widebody...
08 Gix 1k 08 ZX10R
M3PTGSC is offline   Reply With Quote
Old 04-05-2012, 06:41 PM   #4
d'ray18
My Ride: E90 335
2008 E90 335i
d'ray18 is offline   Reply With Quote
Old 04-05-2012, 06:41 PM   #5
cnotesdip
My Ride: 330ci
x2
cnotesdip is offline   Reply With Quote
Old 04-05-2012, 07:00 PM   #6
Bdave
My Ride: M3 HPF Stage 3
Awesome! I mentioned doing this same thing to my car and you never commented. I assumed you were against it. I guess not!
I still have some developmental questions. Chris, what happens if the owner ever runs out of E85 and cant find a station that sells it? I am assuming that this is NOT a flex fuel situation.
Also how does the owner keep from blowing up his motor when he pumps E70 thinking its E85? There can be many reasons for this to happen....mis labled, mis informed, or the pumps are all undergoing a transition period from Summer to Winter blend or vice versa.
Some of the Mustang and Supra guys who run fixed(no flex sensor) Ethanol maps test each and every tankful with a portable tester. Effective but tedious sounding.
Or can there be failsafes that can be programmed in for the very likely event that someday. somewhere the E85 that is pumped is no where near the percentage it is supposed to or believed to be?
The reason I am asking is that I think this is an awesome way to go for those of us that cant afford fancy new flex fuel systems or just want to stay with AEM for now.
There should be a minimum of 3 selectable tunes IMO:
1) Pump gas for those times when that is all that is available
2) E85 tune which should be for the average percentage available in your local area..likely 82% to 84% content.
3) E70 Even if you live in a warm state, its nice to be able to travel elsewhere and use sometimes the only ethanol available...E70
I loved the bumper cam. This is maybe the stealthiest HPF car out there..stock exhaust and not one tiny tell tale puff of black smoke/soot on acceleration. Well done!
Bdave is offline   Reply With Quote
Old 04-05-2012, 07:06 PM   #7
zander271
My Ride: 6spd ZHP/5sp XI
2) E85
I've has the same question.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 04-05-2012, 07:32 PM   #8
STORMER
My Ride: AA SC 98 M3
great stuff guys. Also interested in answers to bdaves questions
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 04-05-2012, 07:58 PM   #9
Bdave
Its a good idea if you can let your tuner KNOW what likely percentages of actual ethanol content you will encounter in your home town station(s). Try and choose stations that are consistent. Or take samples and have them tested.
Its hard not to want to think about getting one of these. I just found out about them. <600bux for the whole kit, sensor, in or on dash gauge read out. cool.
Yes, the kit below does include the sensor even though there is a note that it is not included. Ignore that notation. It is a disclaimer for when you just buy the gauge alone. They show a photo of the included 3 parts, the gauge, harness and sensor which is super easy to install in return line. A snap DIY.
https://partsforspeed.com/index.php?...roduct_id=4941
Here is a review on the E85 content gauge kit.
http://forums.evolutionm.net/alterna...iewed-ttp.html
Here is an excerpt from the above link:
Aside from slight variances in actual ethanol content, in many locations there is a "winter blend" major change in the content at E85 stations that take it down to the minimum 70%. They do this for improved cold start performance of the engine.
Problem is if you have been custom tuned to the edge of performance at 85% ethanol and all of a sudden got less ethanol and more gasoline, your car would no longer be tuned for the fuel content you had originally been set up to use.
On flex fuel N/A cars, these changes in content can be handled by the front O2 sensor which can adjust the fuel trims automatically. However on a high performance turbocharged engine like the 4g63 Evo at 35psi or so of boost pressure, a 15% change in alcohol content can have a serious impact on performance and octane level.
This is where the Zeitronix Ethanol Content Analyzer comes in handy.
There was a recent incident in N California where E85 was only E50. Such a difference can cause some serious engine damage on E85 tuned car. We also have seen E92 last summer when gas prices went through the roof. They added more E into E85.
E85 is a wonderful fuel, but you need to know what you get.
Old 04-05-2012, 08:02 PM   #10
InDiGlOM3
My Ride: HPF M3 stg 2.5
One of the e85 only Evos around here has a lil tester, almost looks like a preg test lol, and it wasnt one time use, could use it over and over.
Old 04-05-2012, 08:39 PM   #11
SlideFox
My Ride: A Bucket w/ 4-Wheels
SlideFox is offline   Reply With Quote
Old 04-05-2012, 08:48 PM   #12
Bdave
Originally Posted by SlideFox View Post
Haha. Yes, i did see the "poor man's E85 tester". Not very practical IMO, but worth a mention, I suppose. I almost posted the link. I didn't. I will now.
http://forums.evolutionm.net/alterna...-analyzer.html
Read the whole thread. Its becomming apparant via MANY forums that single or dual stand alone E85 maps are becoming all the rage. There is no swath of blown engines because not everyone out there has ANY way of telling for sure what their ethanol percentage actually is.
Take for instance this guy:
"You are looking at it wrong, the Fairfield fuel is good and the Hayward fuel is crap. We want high levels of alcohol. Yes both are supposed to be E85
The Hayward fuel has way too much gasoline so it's something really low like only E50
in my STI It's been running like crap on the Hayward fuel, AFRs are at least a full point richer and the fuel trims have gone crazy tyring to compensate...car has felt very sluggish and idle is often unstable..."
I am surprised some serious damage was not done. Regardless of risk, I would feel MUCH better with the in-line sensor and gauge that constantly reads out Ethanol percentage, the Zeitronix ECA. Looks a sure winner.
Think of it. These guys are reaping the benefits of E85 with just a fuel map tune! Ok, so no awesome traction control, no auto flex fuel. I can live with that if all the hardware I need is a sub 600 dollar gauge. And most of the guys don't even have that!
If I look hard enough, I can find the thread where I talked in depth about this(did not know about the Zeitronix then). I was pretty much poo poo'd by the cliques at the time. Thats OK. But dont think now, you might be missing out on something tangible and real here? Its easily with in anyone grasp to run E85 with out 6.5k worth of equipment. Kevins Stage ONE dyno speaks for itself. No Pro EFI, no smoke and mirrors, just cool burning clean power...and a lot of it too.
Old 04-05-2012, 08:53 PM   #13
leletyM3
My Ride: 05 M3
Finally it is done I was waiting for the results! Congrats Kevin!
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser
leletyM3 is offline   Reply With Quote
Old 04-06-2012, 05:26 AM   #14
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Nice one Chris Wish we had E85 in Bahrain
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 04-06-2012, 08:20 AM   #15
AirFrcd
My Ride: Mfizzle, and GT-R
Talking
X2 - Just like Huy said, Congrats Brotha
Now go set up some runs between the 2 of you guys, in Mexico of course.
It should be very interesting to see the runs, as both you guys are running close in power.
Stage 1, e85 vs. Stage 2, Race + Meth
I can do everything through Christ who gives me strength.
Philippians 4:13
AirFrcd is offline   Reply With Quote
Old 04-06-2012, 09:26 AM   #16
xcoolnessx
My Ride: Rover
Ohhh that sounds like a great idea! I'm up for it when I get her back. Should be back next week
HPF M3 AKA on supraforum SupraKiller
AKA z06forum VetteKiller
AKA svtforum SVTkiller
Photobucket
xcoolnessx is offline   Reply With Quote
Old 04-06-2012, 11:22 AM   #17
sunnyjay
My Ride: 01 330i
sunnyjay is offline   Reply With Quote
Old 04-06-2012, 12:07 PM   #18
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
Not surprisingly, that's the best spooling curve you guys have posted yet! Nice!
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 04-06-2012, 12:32 PM   #19
Bdave
I wish someone would post about fail safes, actual number of selectable maps that were programmed in Kevin's car... ie provision for gas or E70?
Does anyone think that the fairly expensive Ethanol gauge (Zeitronix) is a good idea or totally unnecessary? I am quite curious as too your thoughts.
I predict more than a couple HPF owners doing this...going with an E85 tune with out a true flex system in place. Its been shown to be viable for years with some other FI cars.
Old 04-06-2012, 01:03 PM   #20
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
COngrats Kevin! I LOVED your first titanium silver HPF M3 and all the videos!
Great to see you back in a e46!
figured this is what youre missing now.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
