Old 04-06-2012, 06:45 AM   #1
Flaboy239
My Ride: 2004 330ci
Squeaky supercharger pulley
I got an AA sc kit and the pulley squeaks like crazy. It didn't do this when I bought the car a week ago. When it's cold it's really bad. It gets better when it warms up but doesn't go away. It's very annoying. Any suggestions on the best way to fix this? I don't want to just start spraying **** on it and making a mess or possibly do more damage.
Flaboy239 is offline   Reply With Quote
Old 04-06-2012, 07:26 AM   #2
pilot1ner
My Ride: e46
Are you sure its the supercharger pulley and not another pulley? I remember mine did the same thing but it wasnt the supercharger being that it didnt have any bearings.
pilot1ner is offline   Reply With Quote
Old 04-06-2012, 08:14 AM   #3
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
i think you may have to
adjust the belt .. that is what happen to my s/c had the same noise..... it is a easy fix....you should call aa just to confirm on what i said...
bob
bobm3 is offline   Reply With Quote
Old 04-06-2012, 08:31 AM   #4
TrippinBimmer
My Ride: Just Fast!
There is adj. on the back of the s/c for the belt and holding of the S/C.
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 04-06-2012, 10:37 AM   #5
332xi
My Ride: too fast e46/330xi
plus 1 on the belt. it sounds like it's too loose. either adjust like trip said or find a size smaller belt for your pulley.
332xi is offline   Reply With Quote
Old 04-06-2012, 02:56 PM   #6
joshzhp
My Ride: ZHP--Stock
Easy to see if the adj. is installed and tight
joshzhp is offline   Reply With Quote
Old 04-06-2012, 03:15 PM   #7
Flaboy239
My Ride: 2004 330ci
Anyone got a pic of where I can adj the tension or is it obvious?
Old 04-06-2012, 07:38 PM   #8
Flaboy239
My Ride: 2004 330ci
Here's the squeak. Hopefully the video works.
Nm, couldn't get it to work...
Old 04-09-2012, 12:34 PM   #9
Flaboy239
My Ride: 2004 330ci
It appears to be the lower idler pulley that's attached to the supercharger mounting bracket. There appears to be some surface rust. I'm going to take it apart and clean/lube it to see if it helps.
Old 04-09-2012, 05:24 PM   #10
Flaboy239
My Ride: 2004 330ci
Well that wasn't it. That pulley was in good shape. While the belt was loose I checked the tensioner pulley and it seemed fine also. It's def coming from the drivers side. What the hell is it?? It's very loud and very annoying.
Old 04-09-2012, 05:56 PM   #11
joshzhp
My Ride: ZHP--Stock
PM sent
Old 04-09-2012, 06:28 PM   #12
joshzhp
My Ride: ZHP--Stock
Problem solved.
Old 04-09-2012, 06:41 PM   #13
Flaboy239
My Ride: 2004 330ci
Easy fix. Thanks bro
Old 11-27-2013, 08:13 PM   #14
DylanFulton7
My Ride: Audi S4
Sorry to bring this back from the dead... What was the fix? I'm having the same squeaking and it's driving me mad!
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Supercharged 328Ci - SOLD
C32 AMG - SOLD
E53 X5 - SOLD
545i/6 - SOLD
DylanFulton7 is offline   Reply With Quote
Old 11-29-2013, 12:21 PM   #15
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
You would have to try adjusting the turn buckle on the back of the blower it has a bit of play with it which should help stop the belt squeal. If you have any questions please feel free to contact me directly via E-Mail at Viral@activeautowerke.com
Viral@ActiveAutowerke is offline   Reply With Quote
