Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 05-21-2012, 12:53 PM   #261
My Ride: Lexus
I'd say that link is pretty good. The bleeding part is a bit basic though but follow both and you should be fine. It almost implies that you're done as soon as water comes out of the bleed hole. The system will take a while to "gulp" all the water down. But the bucket is a good idea. You at least have a sense of when your system is filled to capacity
Old 05-21-2012, 01:25 PM   #262
330CSL
My Ride: 03 330ci
Why is the expansion tank mounting plate considerd optional?
330CSL is offline   Reply With Quote
Old 05-21-2012, 01:26 PM   #263
moiz21
My Ride: 1999 323i 5-SPD
Because it usually survives the taking apart of the cooling system. I've done both my brother's auto and my manual car. And on both occasions the mounting plate survived the transfer over to the new radiator.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 05-21-2012, 01:46 PM   #264
Jimmynolan
My Ride: BMW 318ci sport coup
Ohhhh noooooo Finnish work get to the car park and there's a puddle under my car, turned out to be the coolant for some reason the fans not coming on and the pressure is blowing the lid off the tank. It seems like the water is not circulating round to the radiator. The hose leading to the thermostat doesn't seem to be getting hot as much as the others anyway. I don't know much about cars as most you so this might not be clear. If you have any idea what I'm talking about and how to resolve this please let me know
Jimmynolan is offline   Reply With Quote
Old 05-21-2012, 02:07 PM   #265
My Ride: Lexus
+1 what Moiz said. It's just a piece of plastic that locates the expansion tank and is quite expensive. If it breaks upon removal, you can always buy a new one. Or if you're that worried, buy it when you buy the other cooling parts, and return it if you don't need.
Old 05-21-2012, 02:56 PM   #266
BeMyWhip
My Ride: 01 BMW 330ci
If you do keep it, at least change the O ring on the back of it. Never re use O rings.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 05-22-2012, 12:42 PM   #267
TheRarp
My Ride: 02 - 325Ci
I got my car a year ago, Auto 325ci, 2002 138Kmiles.. did VCG, flushed/fill up coolant, replace fcabs and updated a few other things.. fluids, internal/blower motor resistor etc.. . Car is running great and no issues.
The question is by looking at the components, how do I know if the cooling system was already done or not?
anything to look?
TheRarp is offline   Reply With Quote
Old 05-22-2012, 01:18 PM   #268
My Ride: Lexus
You don't really know. You can simply look at the parts and make your best judgment call. Some parts like the radiator and expansion tank have a date stamp/tag on it. Check it out.
Old 05-22-2012, 01:25 PM   #269
liquiddawn
My Ride: 2001 BMW 330i
Thanks for this awesome info Mango! It saved my engine and when my cooling system went down, I knew exactly what parts to replace and what to replace them with. Cooling system will be good to go for the entire time I plan on owning the car
liquiddawn is offline   Reply With Quote
Old 05-25-2012, 09:26 PM   #270
Ray B
My Ride: '08 328iT '02 325iT
This will be my first complete cooling overhaul.
One question on the radiator from Behr.
The bottom drain hole appears factory sealed.
In other words it looks like it should be knocked out.
Can this remain closed until the next flush ?
Ray B is offline   Reply With Quote
Old 05-25-2012, 09:46 PM   #271
Stinger9
My Ride: '04 330Ci
On the bottom of the Behr there should be a drain that can be opened.
It would be necessary to open this for a coolant draining.
Can you describe what you refer to in more detail?
Or better yet, take a pic for us?
Old 05-25-2012, 10:06 PM   #272
My Ride: Lexus
Correct. What stinger said. It looks sealed but its not. It comes off.
Old 05-25-2012, 10:11 PM   #273
Ray B
I got the new Rad today.
I was surprised the bottom drain hole
didn't have a blue screw ( but easy to use the old one)
I was also surprised the hole was not open
Would you install the blue screw now
Or can I wait, leaving the plastic sealed
Hope I'm making sense
Old 05-25-2012, 10:13 PM   #274
Ray B
Okay sealed is not the best word
Old 05-25-2012, 10:13 PM   #275
My Ride: Lexus
Take a picture of what you're talking about. Not sure I understand
Old 05-28-2012, 05:33 PM   #276
Turntables83
My Ride: 2005 330i ZHP
Successfully completed the cooling system overhaul over the weekend. Thanks for the info.
Most parts were in decent shape except the pulleys which were pretty much dry and noisy. Eventually it had to be done.. so i am happy i got this out of the way.
Everything went super smooth except that i am not too happy with the stewart pump performance. I had the impression the temperature needle would lean a tab to the left but it's sitting right on the middle like it used to before.
Turntables83 is offline   Reply With Quote
Old 05-28-2012, 06:01 PM   #277
Stinger9
My Ride: '04 330Ci
Temperature is not controlled by the pump, but the thermostat via the ECM. The Stewart only provides the excess capacity to cool more if extreme weather or duty requires this.
So relax.
And your gauge is not analogue, so you would not have seen an accurate reflection of the temperature even if the pump had lowered the operating temperature a bit.
And your engine is designed to operate at a specific temperature for many reasons. Everything runs right here. BMW could have adjusted the operating temperature lower if they wanted to, but didn't.
Old 05-28-2012, 08:38 PM   #278
Turntables83
So relax.
yes yes.. no need to give me the noob speech lol. i expected "noticeable" results with the stewart pump like most claim. That is all.
Good points though for someone that doesn't know those things.
Old 05-28-2012, 09:34 PM   #279
Stinger9
My Ride: '04 330Ci
No intent to offend. Just figure to get it all out because others read here too.
Had the S pump on for years now and temp needle stays rock steady straight up even when driving in stop and go traffic in 115 degree weather.
Old 05-29-2012, 01:23 PM   #280
autiger17
My Ride: 2004 330xi
Behr radiator won't fit?
Hi guys -
I have a 2004 330xi Auto. I have been struggling to mount a new Behr radiator since 6+ hours now. It looks like it fit in nicely but one of the holes does not line up (see the attached pic). It appears to be a snug fit otherwise. It does not wiggle at all. I have removed and installed the radiator over and over again with the same end result and I am afraid I might cause stress fracture in the hoses that hook up to the back of the engine block.
I ordered it from BMA Auto parts based on Mango's parts list. The packing slip has the correct part number: 17119071519.
Any ideas what I can do here? I called the local stealerships here and no one has a radiator in stock. The dealers in the Pittsburgh area suck real bad, couple of them did not even have the engine oil drain plug in stock last week
If anyone has any experience with this can you please help?
Thanks.
autiger17 is offline   Reply With Quote
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
