Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 06-08-2012, 04:20 PM   #341
My Ride: Lexus
you don't need any more coolant. just get a gallon of distilled water
Old 06-08-2012, 04:45 PM   #342
Tex323GripIsKey
My Ride: 2000 323i Green
.97 cent special FTW!
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 06-08-2012, 05:15 PM   #343
EverydayGetaway
My Ride: 2003 330i ZHP
I like to have the extra coolant on hand just in case anyway... and since I just got back from riding my bike to the dealer, I might as well go ahead and mix it and get to bleeding! lol They looked at me really funny showing up on a bike...
EverydayGetaway is offline   Reply With Quote
Old 06-08-2012, 05:54 PM   #344
Tex323GripIsKey
Haha thats awesome. Did you just throw the coolant in a backpack and zip off?
Old 06-08-2012, 06:19 PM   #345
EverydayGetaway
Worse than that, put it in a plastic bag and hung it from my handle bars... couldn't find a backpack.
Also, I just posted a new thread... somethings gone funky with my engine
Old 06-10-2012, 04:01 PM   #346
Earendil
My Ride: 2000 E46 328i
Hour and a half into this job I have everything removed, and am ready to install after some beer. A couple quick questions on effective draining. I pulled both blue drain plugs located below the expansion tank, and the one on the side of the block. But...
I'm seeing standing coolant after removing the water pump. Normal?
When I pulled the lower radiator hose, the hose was full of coolant. Normal?
On my E30, once all the plugs are pulled you're not going to find any more coolant anywhere. I'm wondering if this is due to the E46 design, or indicates the system is plugged, or that I'm a dumbass and there is another place to drain from?
And yes, the car is level
Earendil is offline   Reply With Quote
Old 06-10-2012, 05:16 PM   #347
Stinger9
My Ride: '04 330Ci
Missed the drain plug at the bottom of the radiator?
Or did you remove the radiator?
If you drain the rad, you should be OK, but flushing with some distilled water would be better.
If your old coolant wasn't too bad, not as critical. But if it was overdue, best to get the spoiled stuff all out.
Old 06-15-2012, 09:34 PM   #348
330CSL
My Ride: 03 330ci
Does the bentley service manual detail the overhaul of the e46 cooling system? I was thinking about buying before tackling this project.
330CSL is offline   Reply With Quote
Old 06-15-2012, 09:57 PM   #349
Stinger9
My Ride: '04 330Ci
I own a Bentley and recommend you get one if you have a future with your car. That said, while the manual always has invaluable information, it is not the complete treatise on the e46 by a long shot.
If you had to choose between the Bentley and this board, I'd go with the latter. Guys here give you more real world perspective and tips and sometimes pictures. But when preparing for a project, you want as much in front of you as you can get.
Old 06-15-2012, 10:53 PM   #350
EverydayGetaway
There are plenty of guides online to get this done without a hitch. Most of it is incredibly straight forward. Just google "E46 Cooling overhaul DIY"
Old 06-16-2012, 01:23 PM   #351
#E46_addict
My Ride: 2000 BMW 323i
This is awesome sauce lol. Imma get schedule mine asap. Thanx for this.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
#E46_addict is offline   Reply With Quote
Old 06-17-2012, 12:10 PM   #352
superd21007
My Ride: 99 323i
yes perfect timing indeed. I have a quick question.. I have a 99 323i manual. The other day I was parked,car idling, for several minutes when I looked at the dash and saw the temp needle just touching the red zone and the light came on just as I turned car off. I let it cool for a while and took it for a quick easy spin. Temp was still on the very high end, but just as soon as I got air flow from driving the needle immediately fell and went back to normal. Drove it easy for a bit and had no more issues. So question is... probable radiator fan failing or thermostat?
superd21007 is offline   Reply With Quote
Old 06-17-2012, 12:52 PM   #353
STORMER
My Ride: AA SC 98 M3
Could be thermostat. Have you checked your coolant level?
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 06-17-2012, 01:19 PM   #354
My Ride: Lexus
Could be either but the bottom line is you need 1) enough water/coolant, 2) proper and adequate flow (effective water pump, operational thermostat, and air free system), 3) air moving over the radiator (aux fan and/or mech. fan) to keep the car from overheating
could be air pockets, clogged radiator, t-stat, fans.
Sounds like air isn't moving over the radiator at idle. When the car is moving, naturally air flows over the radiator. Thats why your car cools as you drive
Old 06-17-2012, 02:28 PM   #355
superd21007
My Ride: 99 323i
@ Mango: Yeah I came tothe same thing, that's why i'm thinking fan...
@Stomer: yeah coolent is good..
thanks!!
Old 06-17-2012, 05:33 PM   #356
Stinger9
My Ride: '04 330Ci
Don't drive it this way.
Agree my money on fan or thermostat.
Watch the fan at idle to see it spin?
Old 06-19-2012, 08:33 AM   #357
Macuti35
My Ride: e46 325ti compact
Does any one know how to replace an o/s front seat belt.
Macuti35 is offline   Reply With Quote
Old 06-19-2012, 12:45 PM   #358
superd21007
My Ride: 99 323i
Update:
Got engine hot in driveway,temp gauge staid at half, steady. Revved it hard from a bit. Fan never kicked on, but needle didn't budge. No errors in dash. Took fan out, spins easily by hand and it does kick on with a/c on as it should.
Not an expert but trying to narrow down the issues with out spending $$ I dont have...
Still thermostat? relays now???
Old 06-19-2012, 12:58 PM   #359
My Ride: Lexus
aux fan switch
Old 06-19-2012, 01:07 PM   #360
superd21007
My Ride: 99 323i
and what is that exactly??? :')
Is that the silver box with electrical wires attached to fan housing?
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
