Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 06-19-2012, 02:29 PM   #361
boatshoe
My Ride: 330xi
Will I need to bleed after opening the expansion tank cap just to check the level? Air escaped when I removed the cap as usual, then I screwed the cap back on. Do I need to bleed?
boatshoe is offline   Reply With Quote
Old 06-19-2012, 03:08 PM   #362
ShootyzGruve
My Ride: 2003 325i
Nope.
ShootyzGruve is offline   Reply With Quote
Old 06-21-2012, 09:36 AM   #363
superd21007
My Ride: 99 323i
aux fan switch
Righteous call Mango!!! 18.02 spent and 15 minutes of actual work.
Thanks for the assist!!
superd21007 is offline   Reply With Quote
Old 06-21-2012, 10:40 AM   #364
My Ride: Lexus
As shorty said, correct. Opening the cap does not aerate the water.
No problem!
Old 06-21-2012, 12:56 PM   #365
Tex323GripIsKey
My Ride: 2000 323i Green
Now time to hit the extra 2 pnts with a rebound of the entire cooling system!
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 06-23-2012, 04:59 PM   #366
missamo80
My Ride: 2001 325i
Great thread, especially since I need to do this (second time!) and replace the radiator. I noticed your list doesn't include any gaskets or o-rings though. For example, there's no thermostat housing gasket in the list. Is that because the parts you've listed already include it?
Neil
missamo80 is offline   Reply With Quote
Old 06-24-2012, 02:33 PM   #367
Stinger9
My Ride: '04 330Ci
Typically the thermostat comes with a gasket already in place.
What other gaskets do you have in mind?
Old 06-26-2012, 04:15 PM   #368
BMWBMX'er
My Ride: '00 323i
So on an auto, there's no need to order the t-stat or expansion tank mounting plate noted in the first list, just get those listed in the "auto's only" list?
BMWBMX'er is offline   Reply With Quote
Old 06-26-2012, 04:20 PM   #369
My Ride: Lexus
Some people break/destroy the auto t-stat upon removal. Same with the mounting plate. buy them and return them if you don't think you need them afterward. if you can afford it, go for it. They aren't absolutely vital though AFAIK. The auto guys might know better.
Old 06-26-2012, 04:42 PM   #370
BMWBMX'er
My Ride: '00 323i
Awesome! I just wanted to make sure that the ones from the "auto" list were the only ones I needed, vs getting dupes of the ones meant for the manual cars from the list above. Thanks for the awesome thread too, Mango! I've killed for such attention to
detail in a service manager at some of the repair shops I've worked at!
Old 06-26-2012, 04:46 PM   #371
My Ride: Lexus
No problem and yes... unfortunately that is hard to come by sometimes
Old 06-26-2012, 06:33 PM   #372
BavarianBombshell
My Ride: 2001 BMW 330Ci
Cooling - Read Guide but Need More Info
So I've read into the cooling guide extensively on this forum and it's been very helpful.
I just have a very simple question. Is there any way I could know if the previous owner replaced anything?
I just bought the car a few weeks ago and the Carfax and there are extensive records. However, many of them simply state "vehicle serviced."
(It notes the water pump was replaced and cooling system checked at 26,000 miles, it now has 122,000.)
Because the majority of the comments are very vague, I don't know what was actually serviced with a lot of these records. If I were to call the dealership(s) the car was serviced at, would they be able to tell me if the cooling system was replaced? I know there are some privacy laws so I'm not sure if this is feasible.
I realize I'll probably get a lot of responses saying, "just fix it..." which I'll do if I cannot find proof that it has been done recently.
Thanks for the help.
BavarianBombshell is offline   Reply With Quote
Old 06-26-2012, 06:47 PM   #373
cvx5832
My Ride: 325Ci, 325Cic, C300
If it's close enough, I'd go to the dealership and ask for a print out. I did and got lucky, but others have reported that they were turned away.
Can't hurt to ask.
cvx5832 is offline   Reply With Quote
Old 06-26-2012, 07:11 PM   #374
My Ride: Lexus
I would just replace everything. Some parts like the expansion tank and radiator have date stamps on white stickers. Look closely. For the radiator, remove the air intake scoop. The sticker should be right on top of the radiator. Almost nobody replaces their radiator though. If your car has over 100k miles, the expansion tank was probably replaced as they're known to fail between 80 and 90k. If they're there and 3 years old and newer, then I'd say you're OK with keeping them. If not, then history is unknown and so will be the reliability of your cooling system.
Sometimes, confidence is worth the extra few dollars.
Old 06-26-2012, 07:25 PM   #375
BavarianBombshell
Thanks for the help Mango. I'll check everything out but, as you recommend, I'll probably just end up replacing.
I learned my lesson after not keeping up on my 1.8T Passat properly. Not doing $500 maintenance ended up ruining the engine. Not worth it.
Old 06-26-2012, 07:47 PM   #376
My Ride: Lexus
Let me guess. Timing belt?
Old 06-26-2012, 07:56 PM   #377
BavarianBombshell
Oil sludge.
Could have gotten everything flushed out but there were no signs of a problem, so I just ignored it.
A few months later the oil pressure light came on and the engine was fried within a few seconds.
Old 06-27-2012, 05:51 PM   #378
Zabusa
My Ride: 2004 BMW 325
Where is a whole cooling system replacement DIY? or more specifically, how to removed the radiator, as i found a few random DIYs that cover the ET and WP. I just ordered my whole cooling system and then some and it came in, should be getting it done friday.
Zabusa is offline   Reply With Quote
Old 06-27-2012, 06:09 PM   #379
My Ride: Lexus
Sorry can't help you there. Search around on Google.. you'll find it. I'll just stress to triple-check everything you do, take breaks, and work slowly. Rush into anything and you'll have problems.
Old 06-28-2012, 12:31 AM   #380
Zabusa
Cool. Just replaced all the pulleys, and belts and the heater valve that didnt fix my AC issue, but ill get to it and update I been researching this overhaul for weeks.
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
