Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 06-29-2012, 01:01 PM   #401
Stinger9
My Ride: '04 330Ci
System is full of coolant everywhere. So open anything and fluid will drain out.
First drain the whole system.
Old 06-29-2012, 01:01 PM   #402
sweetbro858
Banned User
My Ride: BMW
Originally Posted by Zabusa View Post
im also replacing wp and pulley too, idk which to do first. Will coolant leak after i removed the wp?
No, coolant won't leak.
sweetbro858 is offline   Reply With Quote
Old 06-29-2012, 02:18 PM   #403
Wolrab
My Ride: 330Ci MT, 545i SMG
Best to drain the coolant before you remove anything. Don't forget to break the wp pulley bolts loose while the belt is still on.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 06-29-2012, 03:17 PM   #404
Zabusa
My Ride: 2004 BMW 325
so the clowns at my local dealer gave me the wrong washer for the coolant drain plug... ugh.. im seeing a local store might have one now.. any change i may be able to get it locally somewhere other than BMW?
Zabusa is offline   Reply With Quote
Old 06-29-2012, 04:35 PM   #405
Stinger9
My Ride: '04 330Ci
You will probably be OK if you used the old one in a pinch.
Maybe a little sealant if in doubt.
Old 06-29-2012, 04:40 PM   #406
Zabusa
ok ill probably just do that. i just dont want to have to flush and refill again.
Old 06-29-2012, 04:54 PM   #407
Stinger9
My Ride: '04 330Ci
Just don't want to over-tighten
stripping those threads would be a disaster.
Old 06-29-2012, 04:58 PM   #408
Zabusa
i might take the 30 min ride to buy the damn washer... it would be hard to over tighten seeing as i can barely get my habd/wrench to undo/tighten the bolt lol
Old 06-29-2012, 06:07 PM   #409
Stephmc2
My Ride: 2002 325i
Originally Posted by Stinger9 View Post
You can't afford an extra $50 to get a new thermostat in there?? yikes.
What's the rest of this repair costing you already?
You could gamble on leaving the thermostat for another month. But it's just that--a gamble. And not doing hoses adds to the risk.
I'd drive very conservatively if I were you and stay close to home. Is that the way you want to live?
The job is already costing me about $700.00 as I am not mechanical so it is at a shop. The thermostat part is not the problem it is the labor. I think they said an extra 200.00 to do the thermostat!
Stephmc2 is offline   Reply With Quote
Old 06-29-2012, 06:19 PM   #410
Stinger9
My Ride: '04 330Ci
You're at a very expensive shop. Two hours to do a thermostat is excessive.
Experienced could do it in under 30 minutes.
I do understand your predicament.
Old 06-29-2012, 06:20 PM   #411
Stinger9
My Ride: '04 330Ci
Seems like a hard place to wrench at first, but then you can do it when you get the position right.
Old 07-06-2012, 01:15 PM   #412
325guy
Banned User
My Ride: 2003 325i stick
Where do you guys order your cooling parts from? Turner motorsports? ECS tuning?
Mango?
325guy is offline   Reply With Quote
Old 07-06-2012, 01:27 PM   #413
Stinger9
My Ride: '04 330Ci
bmaparts.com has great prices
And you can always comparison shop at www.furiousmethod.com
Where do you work on your car if you're in the city?
Old 07-06-2012, 06:04 PM   #414
325guy
Banned User
Me? I buy the parts from turner motorsports or some cheap place and then bring the parts to a bmw indy like motorworks west in new jersey. And then just pay for labor.
Shops sometimes say 'were not really a bring your own parts kinda shop' and i say dont worry about it its my car ill bring the parts.
I keep my baby in a garage in new jersey.
Old 07-07-2012, 02:57 PM   #415
ExitBuddy
My Ride: 2008 335i Vert
Mango?
+1 FuriousMethod.com. Then I looked up places that tend to always be the lowest or one of the lowest, there's about 5 or 6 that you will see always mentioned on the boards.
Price ranges for specific items can be pretty big. I wanted all OE, and for overall total spent, I've done great at TheBMWPartstore.com. You can email Mike there, he was a huge help to me in making sure I got the correct parts for my e46.
ExitBuddy is offline   Reply With Quote
Old 07-07-2012, 11:45 PM   #416
325guy
Banned User
Are you a bias ad?
Old 07-07-2012, 11:59 PM   #417
missamo80
My Ride: 2001 325i
I'm doing this next weekend and got all my parts from bmaparts.com (as mentioned in the very first post in this thread). Cheaper than anywhere else I could find, especially for the radiator.
Neil
missamo80 is offline   Reply With Quote
Old 07-08-2012, 08:13 PM   #418
ExitBuddy
Are you a bias ad?
Huh?
Old 07-09-2012, 04:16 PM   #419
Pocket Rocket
My Ride: 1999 323i
Overhauling my cooling system and now ordering parts. Are there o-rings I need to order while I'm at it?
Pocket Rocket is offline   Reply With Quote
Old 07-09-2012, 04:18 PM   #420
Earendil
My Ride: 2000 E46 328i
My water pump and thermostat housing both came with new rings. I didn't order new rings for anything, and I don't recall thinking I should have.
Earendil is offline   Reply With Quote
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
