Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 07-09-2012, 04:21 PM   #421
My Ride: Lexus
If it's not on my list, it doesn't need to be ordered.
Old 07-09-2012, 04:32 PM   #422
Wolrab
My Ride: 330Ci MT, 545i SMG
Other than what comes with all the new parts, I think the only seal you need is the metal seal ring for the engine block drain plug.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 07-09-2012, 04:43 PM   #423
My Ride: Lexus
Is that on my list, Wolrab? if not... could you fetch the part number for me so I can add it? I thought I added that... good catch.
Old 07-09-2012, 04:47 PM   #424
Wolrab
To be honest, I didn't check first to see if it's on your list. It's 07 11 9 963 200.
Old 07-11-2012, 10:01 AM   #425
My Ride: Lexus
I added it. Thanks. (If it's on there twice, it's Wolrab's fault!) He owes you $0.25
Old 07-11-2012, 10:46 AM   #426
BMWBMX'er
My Ride: '00 323i
What???? Mango, you forgot something???? Well, what good are you anyway???? SHEESH!!!! Just kidding....thanks for all the great info!
BMWBMX'er is offline   Reply With Quote
Old 07-11-2012, 10:56 AM   #427
My Ride: Lexus
haha. at your service, my friend.
Old 07-11-2012, 02:25 PM   #428
Mr_325
My Ride: 2007 X5 3.0Si
wish when i first bought my car this thread was around...
owned the car for 2.5 yrs now... bought at 79k km's.
within the first year (approx 90k km's) i started having some of the leaking symptons, luckily no temp gauge raising
the shop i brought it too said these cars were common for the plastic dry rotting because of the engine heat so he fixed it but never put in detail what was all replaced
he did fix the issue and it's been fine since but now i have no clue which parts on the above list have been fixed
end result was $900 with labour of course
Mr_325 is offline   Reply With Quote
Old 07-12-2012, 11:58 AM   #429
JHalleck
My Ride: 2000 323it
Exellent information. I have one quick question. In April I did a overhaul of the system with ECS kit that had all hoses, thermostat, waterpump, ET, AT thermostat, WP Pulley, and belts.
I have a 00 323it with 171k. No hx from previous owners about maitnence
Now I have a coolant leak from the radiator. (Kicking myself for not replacing it then)
My question is : On top of the parts that are easy to break when removing the ET, are there any sensitive brackets on the radiator that I should purchase as a precaution?
Again thanks for your help
JHalleck is offline   Reply With Quote
Old 07-12-2012, 12:08 PM   #430
My Ride: Lexus
There's the expansion tank bracket as listed in my list but in my opinion it's not really prone to breaking. I think DMAX recommended removing the radiator w/ the expansion tank still attached. I haven't tried that but i suppose it's worth a try. Other than that seems you're good to go.
Old 07-12-2012, 12:19 PM   #431
JHalleck
My Ride: 2000 323it
Exellent Mango thank you. Oh and just a reminder for everyone of how bad the stealerships try to RAPE you, they want 450+ for a stock radiator!!!
Old 07-12-2012, 09:25 PM   #432
Stinger9
My Ride: '04 330Ci
Yes, should have replaced the rad. Cheap.
One important fact you've left out is the trans you have. With a manual no problem. With an auto, you'll have to think about the trans fluid lines and thermostat I've been told breaks easily when trying to disconnect. Best to have another on hand.
And do you have a viscous coupled fan or electric?
Remember to shop price using www.furiousmethod.com
Old 07-12-2012, 10:18 PM   #433
JHalleck
My Ride: 2000 323it
I know about the transmission thermostat, but didnt think about the lines. I have an electric fan. (I think)
Sent from my DROID2 GLOBAL using Bimmer App
Old 07-16-2012, 11:49 AM   #434
filipinoise
My Ride: '02 325ci
Just finished my cooling overhaul (as well as replaced belts, idler pulley; didn't replace radiator or thermostat - thermostat was replaced by PO right before he sold me the car about 5k miles ago) about three days ago and since then, I've driven the car roughly 50-60 miles or so. Everything works well and the car heats up to operating temp in a snap. The temp gauge has probably hit 12 o'clock 4-5 times since I replaced everything (remember, I only finished this DIY 3 days ago) with no ill-effects or signs of overheating whatsoever. No leaking at all, either. Is it safe to assume that I have properly bled the cooling system & I am good to go? I've had my eye on the temp gauge each time just to make sure the needle doesn't make the slightest movement passed 12 o'clock. Just in need of some enlightenment, I suppose, as I have never done anything like this before.
'02 325ci 5MT
I take pictures in the San Francisco Bay Area.
www.eluisphoto.com
filipinoise is offline   Reply With Quote
Old 07-16-2012, 11:58 AM   #435
My Ride: Lexus
The best test besides actually monitoring your coolant temps (the gauge is buffered so is unreliable) is to let the car idle. That's the quickest way to get a car with a failed cooling system to overheat. If you can idle it without overheating, you're probably fine. (idle it after driving around and car fully up to temp--don't idle from cold or will take forever). Really though the car would overheat at any speed pretty quickly.
Let car completely cool and check coolant level.
Old 07-16-2012, 12:04 PM   #436
filipinoise
My Ride: '02 325ci
Gotcha. The car has idled numerous times in those 50-60 miles (San Francisco Bay Area = lots & lots of stop and go...) and everytime I returned home and allowed the car to cool down, I checked coolant level and it was perfect.
Thank you for your help, good sir~
'02 325ci 5MT
www.eluisphoto.com
Old 07-16-2012, 12:10 PM   #437
My Ride: Lexus
Sounds like you're good to go =) NP
Old 07-16-2012, 01:54 PM   #438
Grundyboat
My Ride: 1999 328i
I did all of the above on my 1999 two years ago. I now have an issue with the a/c that I can't figure out. When putting Gage on a/c to see if it needed freon because it is blowing hot it reads the same on the high and the low side. I am figuring something might be clogging lines etc or one of the new a/c parts have gone bad, but I am stumped as to what to check and how. I did the a/c replacement on my own without anyone's help and it has been running great till this week. My husband is not mechanically inclined at all and says get rid of the car, instead of fixing it. Help. I love my car it only has 70k on it and everything and anything that could fail has been replaced before it had a chance to do so, right down to the window regulators and seatbelt mechanisms. Last time I bought it to a service garage my rear head rests were stolen so I do things myself now. Any suggestions or thoughts would be greatly appreciated. Don't want to replace the whole system again when it could be a simple fix. Thanks in advance "Terribly Hot in NJ" and sweatin' that my hubby will sell my car.
Grundyboat is offline   Reply With Quote
Old 07-16-2012, 02:05 PM   #439
Grundyboat
My Ride: 1999 328i
Old 07-16-2012, 04:03 PM   #440
ryannel2003
My Ride: '04 Cadillac Deville
Edit
ryannel2003 is offline   Reply With Quote
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
