Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 09-24-2012, 01:41 PM   #581
Stinger9
My Ride: '04 330Ci
sensor at the bottom of the ET is a coolant level sensor.
Could have damaged it. It is fragile.
From all you say, your coolant level is OK. The float stick is accurate.
Sounds like your level sensor is still not OK, or is installed badly.
Coolant proportion is irrelevant.
Old 09-24-2012, 02:22 PM   #582
joegr
My Ride: 2002 325i
Originally Posted by Raymond42262 View Post
But why would a sensor that measures temperature that mounts outside the tank have anything to do with the fluid level inside the tank ? I could understand if there was a problem with the flotation stick.
But how does a temp sensor relate to water level inside the tank ?
It's not a thermistor, it's a magnetic reed switch. It reacts to a magnet in the float.
joegr is offline   Reply With Quote
Old 09-24-2012, 06:54 PM   #583
Guest100615
Account closed per your request
Thanks !
Thanks ! I bet others learned from this as well.
I'll order a new sensor.
Guest100615 is offline   Reply With Quote
Old 09-24-2012, 09:06 PM   #584
bimer21
My Ride: stick 325i
Quick question i will do my coolant system this week and i ordered online a coolant temperature sensor! But it came in the box 2 of then! Do we use two or was a mistake of the owner! And were are located then? Both are equal!
bimer21 is offline   Reply With Quote
Old 09-24-2012, 09:22 PM   #585
My Ride: Lexus
^ I'm fairly certain those are for an E36. Where did you order from?
Old 09-24-2012, 10:37 PM   #586
Stinger9
My Ride: '04 330Ci
Reason to be confused!
These are not the temperature sensors that go into the lower radiator hose, which I assume which is what you want?
I believe there are one or two sensors like this up top of the engine. One sits in the oil filter housing and is called an oil/engine/water sensor or something like that. Another sits near the back of the engine into the manifold. Might be called an air temperature sensor?
The above from memory, but would require some research on www.realoem.com.
But these are not your lower hose sensor. Need to straighten this out with your vendor.
See part #13 http://www.realoem.com/bmw/showparts...01&hg=11&fg=30
And part #3 here: http://www.realoem.com/bmw/showparts...79&hg=11&fg=40
Old 09-25-2012, 06:21 AM   #587
bimer21
My Ride: stick 325i
Thanks but I was not looking for the fan sensor (one in bottom hose) my car work at 93 most the time never go over 94 degree C, but my gauge is passing 1/2 in cluster. I search the webs that you post and the air temperature sensor doesn't look nothing like those! Just the one on the oil filter case! The person that i buy it from send me 2 instead of one! But thanks its help me a lot! I will change my ET, both hoses, wahler thermostat, graf wp, belt, tensioner, and this sensor to see if my gauge start working normal! Radiator was change 4 months ago!
Old 09-25-2012, 11:16 AM   #588
Stinger9
My Ride: '04 330Ci
Excellent plan!
Let us know how the gauge fix works?
Old 09-25-2012, 11:50 AM   #589
bimer21
My Ride: stick 325i
I will I just hope it works good when i change all of that!
Old 09-28-2012, 12:09 PM   #590
bimer21
My Ride: stick 325i
Doing the work now! I got aftermarket hoses a behr thermostat brand and wp dont say nothing! But they look new less that 30k milles! But putting now everything new OEM also! Let see how it ends
Old 09-28-2012, 12:12 PM   #591
bimer21
My Ride: stick 325i
Also new belts
ID:	471449   Click image for larger version
ID:	471451   Click image for larger version
ID:	471452   Click image for larger version
Old 09-28-2012, 01:48 PM   #592
Stinger9
My Ride: '04 330Ci
Check out all three pulleys while you have it all apart now.
Old 09-28-2012, 02:17 PM   #593
bimer21
My Ride: stick 325i
Alright guys here is all new:
2 hoses, ET, WP, Thermostat, oil/water temp sensor(located at oil filter housing), 2 pulleys, belt, BMW coolant, fan switch sensor(located at bottom hose) and my temp gauge still over 1/2! Whats next? Also i have no leaks at all! Before works at 93-95C now 96-97C
Old 09-29-2012, 04:26 AM   #594
TonyJ
My Ride: E46 330i
I drove home last night at around 11PM. Suddenly the temp gauge swung to the red zone. Coasting to stop. Some coolant leaked to the ground. It was only a few kms to home, so I let it cool down a little and limped home. At the mean time, switched on the digital temp gauge. The temp rose very quickly. On average I can only drive a few hundred meters before it reached 120 degree. I hope the head is not damaged.
There're actually not much leak, and all components are still sealed. I suspect the high temperature caused excessive pressure and blown open the radiator cap. Turned out the water pump was the culprit. It was a Bosch pump I bought only 5 months ago. Big mistake! Look at this picture. The whole impeller was shattered. Stay away from this crap.
TonyJ is offline   Reply With Quote
Old 09-29-2012, 09:40 AM   #595
bimer21
My Ride: stick 325i
Dam! Just buy a new water pump and start driving again
Old 09-30-2012, 07:40 AM   #596
TonyJ
My Ride: E46 330i
My local reseller saved my day. He personally delivered a new pump within 2 hours after I took out the old pump. Car was happy going now.
Old 10-04-2012, 01:46 PM   #597
cheonguk
My Ride: 330Ci
Great info thank you
cheonguk is offline   Reply With Quote
Old 10-05-2012, 11:08 AM   #598
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Mango I sent you a pm but I will post it here for all. If some of the brand names are different is that ok? I am ordering from BMA-Parts and some of the names have changes. Not sure if you picked these brands for quality?
Thanks,
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 10-05-2012, 11:12 AM   #599
My Ride: Lexus
I need specific examples
Old 10-05-2012, 11:21 AM   #600
bimer21
My Ride: stick 325i
Mango i change my coolant system complete as post before but my temp gauge still passing 1/2 and temp is 96, what should i do next?
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
