Thread Tools Search this Thread Rating: Thread Rating: 420 votes, 4.68 average.
Old 10-05-2012, 10:41 AM   #601
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Expansion Tank, Automatic Thermostat there is a "OE Supplier" ,Pulleys are available as Meyle Units, Wahler Thermostat Housing, Engine Cool Fan Switch.
LMK.
joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 10-05-2012, 11:06 AM   #602
My Ride: Lexus
OE supplier is always good, Wahler is good, Meyle is good (though they should offer INA or Ruville) you should be fine really. just make sure waterpump is Saleri or Genuine BMW and expansion tank always Genuine BMW
Old 10-05-2012, 11:08 AM   #603
bimer21
My Ride: stick 325i
I put OEM ET, hoses, OEM 2 sensor(1 in oil filter, 1 lower hose), Graf WP, wahle TM, OEM pulleys and belt!
bimer21 is offline   Reply With Quote
Old 10-05-2012, 11:11 AM   #604
SeattleLSB
Ok. I wanted to make sure. I'm going to call them about the WP. That part # brings up the Meyle waterpump. Do you see any issues with the FAE Switch? I'm converting to the electric fan as well at the same time.
Joe
Old 10-05-2012, 12:58 PM   #605
E46@46
My Ride: 2003 325xiT
Mr. Mango, in your bleeding instructions it sounds like the car is not running while filling it up (while inclined). Is that correct? Thx
E46@46 is offline   Reply With Quote
Old 10-05-2012, 01:03 PM   #606
Stinger9
My Ride: '04 330Ci
Fill the car entirely the first time without running.
Old 10-05-2012, 01:25 PM   #607
My Ride: Lexus
Joe
Yeah call and ask for the Saleri pump. FAE switch.. not sure. go genuine when it comes to sensors/switches
yes. engine never running
Old 10-06-2012, 11:55 AM   #608
Guest100615
Account closed per your request
I recently replaced my expansion tank.
I have checked the water level several times to make sure everything is good.
I checked yesterday and again this morning.
The coolant appears to have foam at the top. Even though I have bled it several times, it appears I have oil spitting out the expansion screw at the top.
It is definitely oil.
I have several oil drops along the engine bay and a few on the top of the alternator.
I was going to take off the cover of the engine and look closer. I was thinking it could be the gasket.
But if the gasket was bad, assuming that was the only problem, that would not allow oil into the radiator.
Could it be the water pump or heaven forbid, a crack somewhere in the engine head ?
I don't have oil or water leaking anywhere while it is sitting still.
I hope I don't get bad news from you.
Guest100615 is offline   Reply With Quote
Old 10-06-2012, 12:03 PM   #609
Stinger9
My Ride: '04 330Ci
What's your mileage?
What is the recently history of any abnormal overheating?
Did you see any oil in the coolant when you drained it?
Oil in the coolant before the ET failed?
Oil in the coolant is the best indicator of a failed head gasket.
Yes a failed gasket would allow oil into the radiator.
What does the oil look like on the dipstick?
How could a water pump allow oil into the coolant?
Old 10-06-2012, 12:20 PM   #610
Guest100615
80k
expansion tank cracked, lost water overheated
no
no
like oil...........but the level is higher than usual
IDK
How does water get into the engine from a leaking gasket ?
If I replace the gasket, do I just do the gasket on top, or do I need a gasket kit?
Other than the gasket and new sealant, what do I need to do the job ?
There is also a faint burning smell.
Old 10-06-2012, 12:31 PM   #611
Stinger9
My Ride: '04 330Ci
Let me be clear. Are you confusing a valve cover gasket with a head gasket? They are very different, and replacing a head gasket is a horrible job that requires skill and probably the services of a machine shop to mill the head.
When the car overheats, in very short order the head can overheat enough to warp. That allows oil pressure from a channel up to the head to leak over into the coolant circulation channels.
Pull a sample of your coolant out of the ET with some tubing and examine it in a clear container. Report back.
It would also shed more light on the situation if you'd describe in detail exactly what happened before and after the ET failure. Where were you? How far from home? How much you drove after the fail?
Old 10-06-2012, 12:48 PM   #612
Guest100615
I was confusing the two gaskets. I was thinking of the valve cover gasket. I don't think that is going to solve my problem.
So, the head gasket repair is not an easy job ? This is what I need ?
The light came on in heavy traffic. It took a while to pull over. The coolant was low. I allowed it to cool off for 2 hours. Topped it off. Drove a mile to safety.
Did not overheat.
Plan B is to tow it to an indy shop.
Old 10-06-2012, 02:34 PM   #613
Stinger9
My Ride: '04 330Ci
Sorry to say you do need a professional to eliminate the possibility that you need to get a new head gasket.
Compression test and leak down test are both possibilities you should discuss with them.
When overheating in the slightest amount, stop the engine immediately and drive no more. Check for leaks. Cool and check ET level.
Old 10-06-2012, 06:36 PM   #614
Guest100615
Thanks, I think I need a pro too...
Old 10-08-2012, 10:25 AM   #615
Zell
Zell's Avatar
My Ride: so turbo wow
Sooooo does anyone else have their coolant always stay at the exact minimum level? Every time I've ever topped it off, it just goes eventually moves down to the exact minimum but never goes any farther. Seeing as every car I've ever had seems to have the coolant at the exact minimum when it is cold, is this normal?
Old 10-08-2012, 11:47 AM   #616
Stinger9
My Ride: '04 330Ci
perspective for you
Generally speaking I lose no coolant over thousands of miles. Rarely do I add any.
When I do top it off, I bring it up to the max level rod reading. Over time as it decreases, it moves down slowly rather than falling to the min level.
Old 10-09-2012, 12:01 AM   #617
TonyJ
My Ride: E46 330i
Interesting theory. I always suspect I had a slow leak somewhere, even after I changed almost everything... So I keep topping up to the max before it got a chance to drop to min. Will refrain from topping up to see how it goes.
TonyJ is offline   Reply With Quote
Old 10-22-2012, 04:20 PM   #618
My Ride: Lexus
Depending on temp, my coolant either moves from min to max. keep it in that range and you'll be fine
Old 10-26-2012, 12:48 PM   #619
djacobso
My Ride: 325i
M56 vs M54 Radiator
I'm convinced that its time to replace my cooling system on my 2004 325i that now has 75K miles. However, my car is a SULEV with the M56 engine and I'm wondering if the parts shown in the E46 Cooling Guide are applicable to my vehicle. One of the on-line retailers told me there is SULEV specific radiator and that the standard M54 part will not work. However, I haven't been able to find a definitive answer on that. Are there other parts that may be specific to the M56? How do I go about identifying which (if any) parts are unique? Thank you.
djacobso is offline   Reply With Quote
Old 10-26-2012, 05:57 PM   #620
Stinger9
My Ride: '04 330Ci
Have you plugged your VIN into www.realoem.com and seen what part numbers come up on the search?
Check to see if they're the same as the general numbers for common e46's.
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
