E46 COOLING SYSTEM GUIDE - overheating/coolant/etc - Page 35 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 421 votes, 4.67 average. Display Modes
Old 11-18-2012, 11:17 PM   #681
Stinger9
My Ride: '04 330Ci
Not unusual to have to do it a few times over heatup/cooldown cycles.
Repeat until you get no more air out.
Old 11-18-2012, 11:51 PM   #682
Juliopinto03
My Ride: 2000 328i
I just added radiator fluid and bled the system however my coolant level indicator came on
Does this mean I didn't add sufficient coolant prior to bleeding the system?
Juliopinto03 is offline   Reply With Quote
Old 11-19-2012, 12:57 AM   #683
Stinger9
My Ride: '04 330Ci
Coolant level indicator is strictly just an indication that the level in your ET is too low.
Check it manually and add to raise the rod to its uppermost position. Run car and bleed again and check again. Repeat until perfect.
May have to position car with front end raised compared to rear to get it right.
Sponsored Links
Advertisement
Old 11-19-2012, 01:37 AM   #684
Juliopinto03
My Ride: 2000 328i
Yes your right. I pulled my car out of the garage which isnt level and let the vehicle cool down. Once cool I added radiator fluid since the level was low so i'll continue to bleed the cooling system until its correct. Fortunately for me I didnt observe any leaks so Im glad replacing the hoses did the trick.
Old 11-26-2012, 09:07 PM   #685
Myke451
My Ride: 325CI
For the people that aren't adventuresome DIY'ers, I just had an ECSTuning level 2 cooling system refresh kit (w/ the BMW parts), idler & belt tensioner installed by local indie BMW garage for about $1,100. The thermostat was not getting the engine warm enough so I figured I'd have the whole thing done. 2004 325ci w/ 99,300 mi.
Hope this info is helpful.
Myke451 is offline   Reply With Quote
Old 11-27-2012, 05:24 PM   #686
Nichts
My Ride: BMW/ BMW/ Infiniti
My leak is coming from part 22 and I'm not sure if part 23 (sensor) is involved.
https://www.trademotion.com/parts/20...iagram=1945090
To me it looks like it's coming from where the sensor meets the fitting.
I've never really worked on my own cars but I want to fix this.
If I just change out the parts (lower hose and sensor) then replace lost coolant will the repair be complete? Do I have to bleed air using the bleeder screw by the et cap after in this case? Anything else I should do, just with this repair? Thanks.
Photobucket
Photobucket
Nichts is offline   Reply With Quote
Old 11-27-2012, 05:43 PM   #687
Stinger9
My Ride: '04 330Ci
You have outlined the correct procedure.
Replace the two parts after lowering your coolant level. Bleed after filling with the bleed screw you described.
Screw may crack and necessitate replacement of upper hose too. Many have replaced this screw with the brass aftermarket one.
Old 11-28-2012, 01:00 PM   #688
Nichts
Thank you. What is your recommended method of lowering the coolant level before beginning? I apologize for the amateur questions.
I’ve inspected the leak much more closely today. There are no leaks coming from any cracks or damages. The leaking is happening inside the fitting that the temp sensor sits in (at the end of the lower hose, by the radiator). On the fitting there are, for lack of a better term, “drain/vent holes”. One square hole on each side, which is where my coolant is escaping.
Photobucket
Old 11-28-2012, 01:19 PM   #689
Stinger9
My Ride: '04 330Ci
There are no drain/vent holes on the fitting for the temperature sensor.
You could just buy a new sensor that comes with a new O-ring and correctly install it with lube (coolant can be used). This will stop your leak as described by you.
Some buy the O-ring separately, but dealer does not sell it that way. A new sensor will not hurt anyone. Is cheap.
Lower coolant by draining at the radiator bottom drain fixture. Careful as it is plastic.
Remove ET cap when doing this.
Are you known to your friends as "mr. nothing"?
Old 11-28-2012, 01:42 PM   #690
Nichts
Thank you for the detailed help! Sorry for the incorrect info about the holes. After looking again I was referring to the cutouts that allow the sensors clips to expand. Thanks again.
Old 11-28-2012, 02:42 PM   #691
Stinger9
My Ride: '04 330Ci
Let us know how things go!
no need to apologize. we all come here to ask questions about what we don't already know. me too.
Old 11-28-2012, 08:44 PM   #692
cgd
My Ride: 2001 330CI
Just replaced my ET how important is it to bleed the system? Is there an average time heatup/cooldown cycles, Can the bleed be done after its been driven? Thanks
cgd is offline   Reply With Quote
Old 11-28-2012, 08:52 PM   #693
Stinger9
My Ride: '04 330Ci
Very important to bleed the coolant at the bleeder screw.
Takes all air out of the system which can greatly reduce the efficiency of the cooling system, and cause other problems. Potentially damage parts.
Yes you can bleed your system at any time. Bleed a couple/few times until you get no more bubbles.
Old 11-28-2012, 08:55 PM   #694
cgd
My Ride: 2001 330CI
Thanks, old time wrencher. First attempt at a BMW, recently replaced the oil, anti-freeze and spark plugs. Missed the need for the bleeding, could that have possible added to the failure of the ET? Had a large crack/break down the side of it. 2001 330CI w/107k, looked to be an original part.
Old 11-28-2012, 09:00 PM   #695
Stinger9
My Ride: '04 330Ci
Split ET not your fault. Just age takes them out; most sooner than yours.
Old 11-29-2012, 01:01 AM   #696
tcseadoo
My Ride: 01 325i
Tensioner pulley replace question
I ordered a new tensioner pulley from BMA (along with Aux fan, thermostat, and plastic rivets) Forgot how the tensioner pulley goes back on the tensioner. Washer, pulley, socket head screw or pulley, washer socket head screw? I think it's the first one but should have taken pic or made notation. Thanks for any answers.
T C
tcseadoo is offline   Reply With Quote
Old 11-29-2012, 01:12 AM   #697
Stinger9
My Ride: '04 330Ci
when in doubt, go to www.realoem.com
does this help: http://realoem.com/bmw/showparts.do?...90&hg=11&fg=18
Old 11-29-2012, 06:05 AM   #698
tcseadoo
My Ride: 01 325i
That does help.
Thanks.
Old 11-30-2012, 11:36 AM   #699
Newman513
My Ride: 325xiT Hellrot 5spd
Is it okay to use ECS Tuning's $330 Level 2 kit, vs their OEM $480 kit?
Have there been any problems with their parts before? I know they have a 1 year manufacturing defect warranty.
http://www.ecstuning.com/ES2063862/
vs
http://www.ecstuning.com/ES263517/
Newman513 is offline   Reply With Quote
Old 11-30-2012, 11:40 AM   #700
My Ride: Lexus
vs
I recommend you piece together a "kit" yourself. that "kit" barely scratches the surface. Replace everything or you are just inviting trouble. GL!
Sup? It's '06 Mango • 4.1M VIEWS
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
