Rating:
#761 | |
Not necessarily...that light will come on if air is in the system too. Only if he is/and continues to be low on coolant, would that confirm a leak. +1 though on not over-filling. The "filler diagram" says Kalt/Cold
#762 |
Mr Mango, I wish my son had read your post. He drove our 318i (2002 4 cyl auto) when the coolant lights came on and blew the engine at 94 000 k's. I replaced the motor and the gearbox at the same time, seeing that I had a 2003 30 000 k car scrapped as a result of collision damage as a donor. The young man has learnt his lesson, I think. He now travels with coolant - ready mixed - in the boot and will hopefully start reading the advice on this site. I find your and jfoj's advice invaluable. Keep up the good work in 2013.
#763 |
I forgot to mention. It was the plastics that gave in. Cracked pipe, leaking coolant, blown engine.
#764 | |
Grand Superpatriot
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#765 |
My Ride: 2005 325xi
CrazyOneToo. They were talking about Silicone dielectric grease, commonly referred to as "o" ring grease.
Mango: I'm about to do the cooling system overhaul, I replaced my thermostat 2 years ago exactly. It has roughly 25k miles on it, should I replace it as well or can it wait a couple more years to the next coolant change? BTW its a Wahler. |
#766 | |
Grand Superpatriot
#767 |
Wahler is the preferred brand and 25K miles is young yet.
Inspect the connections when you have the hoses off and no need to replace if they look good. |
#768 | |
2. V configuration and inline configuration engines have nothing to do with vulnerability to damage. Where did you come up with that? 3. I don't think we get overheating threads on a daily basis, they are often but not daily. I so think you telling every new member to change their cooling system is something daily. 4. No, I haven't noticed people who maintain their cooling system having less problems, and I'm talking about real life, not just what you read on the forum. Funny things is I've seen cooling system parts fail that you totally forgot to mention in your DIY. ![]() 5. You obviously are the one who has a hard time spending money on their car if you are DIYing and buying stuff yourself instead of taking your car to any reputable service center. It's a pretty weak argument saying "I spend more money on my car, I deserve to be driving it more than you." I talk and work on BMWs in real life, and do actual work on them. I'm not just making threads about rumors and complaints I read online. You are going in the right direction with telling people to do maintenance and making it easy for them, but the blindly replacing of parts is just wasteful and does have its risks. |
#769 | |
Grand Superpatriot
There's documented cases of brand new Behr AND Wahler thermostats failing after only one year. I'm only recommending this because OP will be in there anywhere. My Wahler has 30k miles on it and so far so good. But if I was in the OP's position, I would definitely replace it. Is $40 worth the peace of mind? your call
#770 | |
Grand Superpatriot
#771 |
TIP: for people doing cooling system work, buy some O-ring lubricant, which is essentially just a silicone grease with minimal additives. It makes all the O-ring connections go on and come apart significantly easier. You'll happily spend the $12 for a large tube of it if you've ever dealt with a sticking connection. The O-ring safe grease is also good for preventing corrosion of metal parts like electrical terminals and waterproofing and lubricated sealed connections so it's a versatile product. I recently used this on a cooling system job last week and it was worth every penny.
#772 |
My Ride: 2005 325xi
#773 | |
Grand Superpatriot
FYI, my cooling thread isn't a "DIY," as you call it. It's simply a guide on the the E46 cooling system. If you want to replace hard pipes, heater lines, water valves, heater cores, and aux fans, go right ahead. 99% of the time, the parts I list do the job of keeping your car cool based on personal observations and mountains of info out there. If I list all of the parts in the system, then the cost would go up significantly and that would make this absolutely essential job cost-prohibitive--which goes against the whole point of this thread. Of course, I've said this several times. Read the multitudes of positive feed back I've gotten or the mere fact that this thread is a sticky and tell me this hasn't been helpful to people.
#774 | ||
#775 | |
Documented cases of parts failing right out of the box too. But we're not operating on the premise that the exception rules our behavior. Of course all of this is opinion and individual choice. It's a trade-off between reliability and cost. |
#776 | |
Grand Superpatriot
Of course we wouldn't be discussing this if the poster replaced the rest of the system when he did his thermostat. If the cooling system is original and one part fails, never replace just the failed part. http://forum.e46fanatics.com/showthr...198&highlight= http://forum.e46fanatics.com/showthr...=924712&page=2
#777 |
#778 | |
Grand Superpatriot
spend a little now or a lot later
#779 |
AND control cost and quality of install!
I'm on the side of bulletproof cars. Feels good to have new parts. |
#780 | |
My Ride: 2005 325xi
I would have, had I known about this site and this thread in particular at that time. This should also make you cringe, I used green pre mixed antifreeze and just mixed it with what BMW antifreeze was left in there. |
| Tags |
| bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump |
| Rate This Thread | |
