Thread Tools Search this Thread Rating: Thread Rating: 420 votes, 4.68 average.
Old 01-05-2013, 11:13 AM   #821
minde238
My Ride: bmw 323i 99
Originally Posted by Stinger9 View Post
So far your logical thinking is fine. You've just not done enough to your cooling system to build confidence back into it.
If you were truly a student of this board, you would have done a complete cooling system refresh.
And you've not given us enough of a complete history of the repairs you've done to your car? What is the mileage on this car and service history?
And perhaps most importantly for now, did you replace your thermostat?
And learn how to use the hidden OBC functions and set it to monitor your coolant temperature. Report back to here.
And verify that your fan is functioning properly?
I just hope its not the gasket/head ?
So what more should i do? try to bleed it the same way i did before?
Well as i said i've only had a mechanic to change the water pump and the mileage is 172k thats all i know
About the thermostat, no i havent replaced it.is it hard to diy?
and in the pdf file included in ur answer, what is the "left insturment key" mentioned in there? is it the one which unlocks the car?
sorry for all the nuisance, but a car to me is like a i know nothing about them, but im always eager to improve.
thanks for all the help so far.i will try to bleed it again.
minde238 is offline   Reply With Quote
Old 01-05-2013, 11:49 AM   #822
Stinger9
My Ride: '04 330Ci
Simple rule: bleed until you get no more air out. Then you're done.
Thermostat is easy DIY, and I'd do both main hoses at the same time along with temperature sensor in the lower hose. Always search for DIY's or youtube vids to watch for yourself if you think you are mechanic enough to do the job easily and you have the correct tools. You know your skill level better than we do.
Did you read the entire post #1 on this thread? If not, you should.
And oh yeah, we hope it's not your head either!
Old 01-05-2013, 03:11 PM   #823
minde238
And why is the water always boiling? i can see that with the car on and ET cap removed.cheers
Old 01-05-2013, 03:38 PM   #824
Stinger9
My Ride: '04 330Ci
Sure it's boiling? What's the temperature?
Did you check with the OBC?
Old 01-05-2013, 04:27 PM   #825
tcphoto
My Ride: E92 335 MT Coupe
I thought that I would do my cooling system refresh but the eBay fan removal tool turned out to be crap. After finding Smolck's YouTube video, I may try the rubber mallet and 32mm wrench maneuver. It looks a little over the top but the mechanical fan is on there tight. If that doesn't work, I can always take the mallet to the fan and then replace it
tcphoto is offline   Reply With Quote
Old 01-05-2013, 04:35 PM   #826
Stinger9
My Ride: '04 330Ci
Remember, clockwise removes it.
Old 01-05-2013, 05:09 PM   #827
tcphoto
It's burnt in my brain, I've been watching quite a few video's and reading DIY's. It was just aggravating to have a few hours to do the job and the fan was not going to let go. I'll have more time on Monday and will give it another try.
Old 01-05-2013, 10:05 PM   #828
My Ride: Lexus
I thought I explained this 400 billion times already? Spray the fan nut w/ WD40 and let it sit 10-20 min. it helps. If you have the upper hose removed (which I assume you do) take your 32mm wrench (or appropriate adjustable wrench) and a large screwdriver wedged between the water pump bolts then it'll come off quite easily.
HTH!
Old 01-05-2013, 10:10 PM   #829
wildirish317
My Ride: 2004 325Ci vert
400,000,000,000 times? I don't think you're there yet. Close, but not quite. Keep going.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-06-2013, 05:26 AM   #830
minde238
What i noticed this morning, after adding some coolant to the ET together with removed bleeding screw (till its bubble free ofcrs). the top radiator hose got really hot and quite hard, also the lower radiator hose did get quite hot too it wasnt cold at all. so if both hoses are hot, does it mean its the head gasket?cheers guys!
oh, and the big fan just behind the radiator isnt spining at all. is that very bad? could this be the real problem?
Old 01-06-2013, 12:55 PM   #831
rakim
My Ride: e46 318
many thanks every one
rakim is offline   Reply With Quote
Old 01-06-2013, 01:01 PM   #832
rakim
My Ride: e46 318
hi every one out there just quicke question which is the best bmw E36 OR E46? 320'S?
Old 01-06-2013, 01:50 PM   #833
Stinger9
My Ride: '04 330Ci
Originally Posted by rakim View Post
hi every one out there just quicke question which is the best bmw e36 or e46? 320's?
yes!
Old 01-06-2013, 07:38 PM   #834
wildirish317
You left out a few (E30, 2002, 635, etc) but yes. All of them.
Old 01-07-2013, 01:23 AM   #835
mikeetastic
My Ride: lots of 3
My original water pump died today after 193K miles.. just heard a loud sound while driving and it's my fan hitting the shroud. Turned off the engine immediately so no overheat, my temp didnt even move past 12 oclock.. all the cooling system are NEW (radiator, hoses, thermostat, expansion tank) last year 15K miles ago and flush all done at the stealer...
I will DIY everything this time but question:
1: do i need to replace anything else when i change my WP (undecided yet between graf or Saleri)
2: do i need to do coolant flush or just top off will do? bleed?
Thanks all in advance...
@mango
I cant seem to find the the $54 saleri bump you mention at bmaparts??
mikeetastic is offline   Reply With Quote
Old 01-07-2013, 02:50 AM   #836
My Ride: Lexus
@mango
Call BMAparts and ask for it. Saleri=BMW.
Replace anything you haven't already from my list.
You 100% need to refill the system AND bleed if you're replacing the water pump. Half the water will eject itself.
GL
Old 01-07-2013, 01:47 PM   #837
G-Train
My Ride: 2000 323i
Just another coolant path to take the coolant around and into behind the water pump.
See #5
Looks like a twelve year old hose!
Cant seem to find hose #5 to order. Anyone know the order code off the top of their head?
G-Train is offline   Reply With Quote
Old 01-07-2013, 02:51 PM   #838
Stinger9
My Ride: '04 330Ci
why can't you find it on www.realoem.com when you plug in your VIN?
Then use www.furiousmethod.com to shop for prices on genuine BMW parts.
EDIT: Glad to be of service!
Old 01-07-2013, 03:34 PM   #839
G-Train
My Ride: 2000 323i
Thanks for the links, never used that site before.
Old 01-08-2013, 02:14 PM   #840
mikeetastic
My Ride: lots of 3
GL
OK i will bleed after WP has been done (still waiting for parts to arrive)... but upon lots and lots of google and youtube vids - i have come up with 3 methods (so far)
1: posted on page 1
2: this 2 youtube video, they start bleeding while engine is running..
and this
3: similar to 2 but start the engine and rev it 5K (post here: http://www.e46fanatics.com/forum/sho...6&postcount=35)
there could be more methods out there (saw a post from dmax about his alt method but cant seem to find it) so it's really confusing me now..
again this is gonna be my first time bleeding a 99 323i M/T e46 or any BMW car so im loading up the info and getting ready this weekend..
Thanks in advance for the input..
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
