E46 COOLING SYSTEM GUIDE - overheating/coolant/etc - Page 54 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 421 votes, 4.67 average. Display Modes
Old 02-27-2013, 02:17 AM   #1061
drawz
My Ride: BMW 3-series 325
Your E46 cooling system is not a Chinese restaurant menu. You cannot pick and choose and not expect to have problems. Replace it all and you'll be problem free for close to a decade. Good luck!
was just trying to get advice on what is most likely the problem. I'm at work offshore right now. So I'm not able to look at it now
drawz is offline   Reply With Quote
Old 02-27-2013, 02:37 PM   #1062
entrax
My Ride: 2002 325xi
Originally Posted by Mhnd View Post
He's correct about the transmission oil thermostat cooler breaking 90% of the time while removing the expansion tank, mine broke see picture ....
interesting that mine looks the same way! are there any metal replacements? like how there's the stewart water pump...
entrax is offline   Reply With Quote
Old 02-27-2013, 02:42 PM   #1063
Stinger9
My Ride: '04 330Ci
Not expensive enough to just not replace each time you have the system apart there.
Never heard of a metal replacement.
http://www.rmeuropean.com/Part-Numbe..._6BB4EABD.aspx
Never read a report of one breaking unless it was during removal.
Sponsored Links
Advertisement
Old 02-27-2013, 02:50 PM   #1064
entrax
My Ride: 2002 325xi
yeh they're cheap enough, i'm only worried about it breaking under constant heat/cold cycles in daily usage of the car during the next 70k after i have the coolant system apart. after all, how does one know if it didn't break prior to removal and causing longer warm up times/higher operating temps?
Old 02-27-2013, 04:43 PM   #1065
Mhnd
My Ride: 2004, 330XI
The only time they break is during removal. Mine had147K original and it broke when I was removing the expansion tank!
Mhnd is offline   Reply With Quote
Old 02-27-2013, 05:24 PM   #1066
My Ride: Lexus
Just coded my car to have the windows continue to roll down/up while the door opens. It was so annoying that the window stops in its travel once you open the door.
I also tried to code double impulse hazards, verified the code stuck, but the hazards still behave normally. I have a feeling my LED tail lamps aren't letting it blink?!
Old 02-28-2013, 03:06 PM   #1067
325iGirl03
My Ride: 2003 325i
Just posted a thread about this, thanks! Very helpful.
325iGirl03 is offline   Reply With Quote
Old 02-28-2013, 03:09 PM   #1068
My Ride: Lexus
No problem.
And I just realized I posted the post above this in the wrong thread
Old 03-05-2013, 06:11 AM   #1069
drawz
I did look around in the enginebay to day to find any leaks. My termostat does not look quite good? (See picture below) And to day i noteced that it comes white exhaust from my car. also when the car is warm. the car does not overheat and have never been overheated. Could the termostat casue that white exhaust?
Old 03-05-2013, 06:12 AM   #1070
drawz
Old 03-05-2013, 10:53 AM   #1071
Stinger9
My Ride: '04 330Ci
I sure don't like the look of that VCG. I'd replace that with a new Non-Victor Reinz gasket and clean things up. Include cleaning or replacing the thermostat.
Then check frequently for new leaks.
Old 03-05-2013, 12:01 PM   #1072
drawz
VCG will be replaced verry soon, ordered It yesterday :-) I also ordered the thermostat.. Don't like the look of it either.
Old 03-05-2013, 12:21 PM   #1073
My Ride: Lexus
I'm just going to leave this here mmkay?
http://forum.e46fanatics.com/showpos...0&postcount=16
Old 03-08-2013, 12:09 AM   #1074
TonyJ
My Ride: E46 330i
I have just change to a VR. Is it that bad? I wasn't awere of it but now it's too late
TonyJ is offline   Reply With Quote
Old 03-08-2013, 12:31 AM   #1075
///MPR77
My Ride: 2002 M3 Three Pedals
Yeah, a lot of us are having problems with new VR gaskets leaking.
There are a few that have reported no problems with their VR Gasket.
Did you already install it?
DIY | Bleed Cooling System
Old 03-08-2013, 12:50 AM   #1076
TonyJ
My Ride: E46 330i
Just a week ago, together with the vanos...
So how long does VR last?
Old 03-08-2013, 01:08 AM   #1077
My Ride: Lexus
about a week lol
Old 03-08-2013, 01:09 AM   #1078
TonyJ
My Ride: E46 330i
about a week lol
I don't get it. What's to lol? People were posting new one leaks that got me paranoid.
Old 03-08-2013, 09:32 AM   #1079
Stinger9
My Ride: '04 330Ci
Mine lasted 8000 miles. Some report shorter lives before they start to leak.
I followed the install procedure exactly and have years of experience.
Gasket is especially defective sealing around the half moons.
Old 03-08-2013, 10:55 AM   #1080
My Ride: Lexus
because it lasts a week?
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
