Rating:
#101 |
Problem is a crack anywhere is not strong enough to hold up when the system gets pressurized up to 15 psi. That is what the cap is rated for when new.
#102 |
Sweating copper pipe is a sweet art.
Seen many a plumber do sloppy work. Yet another place where I do my own work because some professionals take no pride in their work. |
#103 |
Stinger9, ET cap is rated 29psi , not 15. Our system runs on 2bar pressure. 2bar=29psi . The cap is stamped 200Kpa in the inside. 200 kPa = 29.0 psi
Ilovecars800490, please stop crying about how plastic is bad ,this and that. I can send you a box of tissues if you want . Plastics have revolutionized the automotive industry and made things possible that havent been possible before , they made mass production affordable and generally only carry benefits, so please stop talking bad about plastics.
#104 | |
My Ride: 2003 330i sport 5spd
#105 | |
Wonder what the actual operating pressure is under normal operating conditions? I see the test pressure for the leak down test is 1.5 bar. |
#106 |
Great write up. Bookmarked for future
Sent from my DROIDX using Bimmer App |
#107 | |
http://store.bimmerworld.com/water-p...-nut-p706.aspx Last edited by Stinger9; 04-14-2012 at 05:58 PM. |
#108 |
Well, I never understood what the hype was about these brass screws. Its a nice piece sure, but its not like the original screw is bad or anything .
#109 |
Stay stock my friends!
I'm wondering if someone could fabricate a bleeder screw for me out of solid silver? Maybe incolnel?
...and that nut cover for the WP? Does it come in designer colors or would I have to paint it Fern Green? Will it affect my HPs? /threadjack...sorry Mango...I'm bored!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#110 |
2006 330CI - No front auxiliary fan?
Hi, I have been out of the BMW scene for a while (since 2007) when I hit a deer with my 2001 330CI M/T but just yesterday bought a 2006 330CI ZHP with 6-speed manual trans. My wife has a 2005 330CIC auto trans and this morning I noticed that my car does not have the "pusher fan" on the front of the radiator like my wife's automatic car has.
I googled and couldnt find out if my car was ever equipped with both a pusher and a pull fan. Does anyone know the answer? Thanks for any help |
#111 |
Manual's should only have an electric puller fan in between the radiator and engine. No viscous fan mounted on the water pump like the automatics.
#112 | |
Wanted to share some information for those of you looking to grab some parts to do the work yourself.
I placed a $300+ order with BMA last week on a bunch of parts i needed to do a cooling update on my 325xi. The are great people to deal with. Very communicative and friendly people. I had a few issues with my order though and wanted to point this out for reference... Quote:
I also went with the OEM Saleri Waterpump, which arrived damaged. The plastic impeller was cracked and there was no way i was putting that into the car. Since my OEM Waterpump had some play i needed to replace it. Went and grabbed a GMP (metal impeller) and put that in, although i wanted to go with composite. Little disappointed as i ended up paying more for this water pump than i wanted. Have to return this also. FYI make sure you check for this is you are getting the plastic impeller as it might be easy to overlook. Overall i changed the following:
All went smooth and didn't take very long, aside from the running to the parts store. I will be doing my brothers in the near future and will for sure do a DIY article. I didn't have as much time as i would have liked so i was not able to document it. |
#113 |
You did all that work and did not put on new hoses?
And did you use a metal replacement water pump pulley? Why did you prefer a composite impeller in your wp? Everyone else avoids these like the plague. |
#114 | |
Yes, got the metal waterpump pulley. I have a couple good friends who work as BMW techs and they recommended the plastic impeller over the metal. I trust their judgment as they deal with these things on a daily basis. If it ever breaks i don't want metal bits floating around in the system. |
#115 |
Gotcha re the hoses!
I've never ever heard of metal impeller failing. Composite fails many times. But I'm not trying to get you to change because I think that hasn't happened with many new ones. |
#116 |
Hardly glowing re BMA if they don't pack securely enough to avoid a broken water pump and don't check against your VIN for correct parts.
BMW went to hydraulic tensioner early on and does not supply the mechanical any longer. Have to get it from aftermarket if you want one. No one does. Convert to the hydraulic one as no one has problems with this in the vast majority of cases. |
#117 |
Here is the difference i was talking about. I don't know if this is the difference between hydraulic / mechanical? Anyway, as you can see the bolt seats into the pulley, but the hole in the new pulley (left) is too small and will not work.
![]() Here is a shot of the cracked WP Last edited by joeycannoli; 04-16-2012 at 10:03 AM. |
#118 |
Hydraulic vs. mechanical is the mounting structure that the pulley is attached to and which supplies the pressure to tension the serpentine belt.
Got to get in there on your engine front to tell the difference unless you know what you are looking for. Does this give you a clear idea of the difference? Last edited by Stinger9; 04-16-2012 at 10:27 AM. |
#119 |
Hey guys, im back with a bad news...
Recently I purchases an after market radiator, aluminum alloy at that and I was hoping it would fit my car. Turn out it did fit, but require to purchase an addition slim performance fan! stock e46 assembly fan would not fit with the new 56MM radiator size, it would touch the engine, pulleys and etc... Unfortunately our stock radiator sizes 42MM I suppose?? ![]() Im such a dumb azz!! But luckly for me, atleast they accept return with full refund. ![]() Sent from my HTC Glacier using Bimmer App
![]() IN PROGRESS.... B&G SPRING I ANGEL EYES I M3 REP F. BUMPER I E90 RIMS I AEM COLD AIR INTAKE I |
#120 | |
Oem is good enough for 100k miles and cheap enough not to sweat. And cools totally fine. |
| Tags |
| bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump |
| Rate This Thread | |
