Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 11-10-2013, 03:11 PM   #1581
02'topaz
My Ride: 2002 BMW 325ci
Originally Posted by BaliDawg View Post
Enter the last seven digits of your VIN and you can browse to all the parts for your car. Putting them in the DIY would have been be nice, but they may be different for each car. Or pop on down to the dealer and buy them directly.
Thanks so much! FOund the orings suggested for the cooling system - 11531435808
What system would the trans-oring be listed in? Doesn't seem to be part of transmission nor cooling...
02'topaz is offline   Reply With Quote
Old 11-10-2013, 03:18 PM   #1582
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Look under the Radiator section.
http://realoem.com/bmw/showparts.do?...46&hg=17&fg=05
03 O-ring 14,5X2,5 2 03/2003 17111711987 $1.73
Old 11-10-2013, 04:10 PM   #1583
02'topaz
Thanks so much buddy. Found two different sets listed there in addition to the one I had already mentioned. Thanks a bunch!
Old 11-12-2013, 09:24 PM   #1584
Fatrusty
My Ride: '04 325i
So I finally have the drip and time to do the cooling system. 2004 325i auto with the M56 motor. That seems to be the rub as all of the kits I have found will not fit the M56. The only one I found that says it will fit is Turner and that is an extra $260. What is the difference? The radiator? Would the kits with out the radiator fit? It is interesting because all the kits say M54
Or would I be better off and order the parts individually.
Fatrusty is offline   Reply With Quote
Old 11-13-2013, 10:42 AM   #1585
My Ride: Lexus
You might want to ask Briangl92. He's the M56 guru around here
Old 11-13-2013, 02:09 PM   #1586
Stinger9
My Ride: '04 330Ci
From what I recall (maybe earlier in this very thread) the radiator for SULEV is coated with something to make it compliant. But owners say the reg radiator will fit with no problem. Confirm this with another source before proceeding.
Old 11-13-2013, 02:12 PM   #1587
Fatrusty
My Ride: '04 325i
Thanks for the info. I will check into that!
Old 11-19-2013, 12:52 AM   #1588
Zpzp96
My Ride: BMW E46 330i
* E46 Cooling Guide (Information w/parts list/bleeding) *
My car has replaced thermostat housing around 80k. Is it different from thermostat on the list or is it the same one?
Zpzp96 is offline   Reply With Quote
Old 11-19-2013, 06:55 AM   #1589
ti317
My Ride: 02 330ci coupe 5 spd
Or, get a bigger hammer and MAKE it fit!
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 11-21-2013, 05:08 PM   #1590
lszlszx
My Ride: 1.8T, XC70
I have a leak at the connection between the ET mounting bracket and the radiator.
Does anyone know what size the O ring is, or where I can get it?
Thanks!
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 11-22-2013, 11:17 AM   #1591
gspadez
My Ride: 2003 330i
Re: * E46 Cooling Guide (Information w/parts list/bleeding) *
I hear a hissing sound whenever I run my ac.. any ideas
gspadez is offline   Reply With Quote
Old 11-22-2013, 11:44 AM   #1592
My Ride: Lexus
ya service your ac
Old 11-22-2013, 11:57 AM   #1593
gspadez
My Ride: 2003 330i
As in what kind of service. . Im.hearing the noise in the inside of the car.. havent really did an under hood check
Sent from my SGH-M919 using BimmerApp mobile app
Old 11-22-2013, 11:58 AM   #1594
My Ride: Lexus
professional service
Old 11-22-2013, 12:22 PM   #1595
gspadez
My Ride: 2003 330i
Diagnostic check for starters? Or something like a run through for wellness
Old 11-22-2013, 12:26 PM   #1596
Chaplian
My Ride: M56 SULEV
Take it to a shop. AC units are not something you want to mess with.
Chaplian is offline   Reply With Quote
Old 11-22-2013, 01:07 PM   #1597
gspadez
My Ride: 2003 330i
Ok ill do just that.. these estimatea are free most places anyways thanks
Old 11-22-2013, 02:26 PM   #1598
WDE46
My Ride: '13 128i, '04 330Ci
Thanks!
Just buy a new bracket.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 11-22-2013, 05:56 PM   #1599
Stinger9
My Ride: '04 330Ci
Really? Not for all of us. I installed my own A/C in my car that came without it years ago. Just one simple step after another. Worked fine for many years.
Old 11-22-2013, 06:04 PM   #1600
My Ride: Lexus
Technically, skilled people can do the job assuming they have the right equipment and/or training.
However, the person asking the question is obviously not skilled at this particular task. This is why taking it to a shop is being offered as advice in the context of this question.
Context is extremely important. Never forget it
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
