Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 04-29-2014, 04:27 PM   #1921
WDE46
My Ride: '13 128i, '04 330Ci
The clip will prevent removal, but you can leave it "down" for insertion. It'll act like a spring lock. The hoses have a similar action with their clips. On installation, the clip can be up or down. I prefer down so it clicks loudly when inserted all the way.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-29-2014, 04:32 PM   #1922
Stinger9
My Ride: '04 330Ci
+1
Same for the main rad hoses and CVV hoses.
Old 04-29-2014, 04:36 PM   #1923
ChuckyVee
My Ride: 2000 323i, '99 328is
Ahhh...makes perfect sense...since the end of whatever you're inserting is like a flared barb. One way in, no way out...brilliant!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 04-29-2014, 04:45 PM   #1924
Stinger9
My Ride: '04 330Ci
I had the same exact ah-ha reaction when I first starting working on my car ten years ago and wondered what these ends are all about.
Old 04-30-2014, 09:18 AM   #1925
onaje
My Ride: BMW 323i '99
thanks everyone. I'm not confident that the puny clip will hold (I know it went all the way in but I didn't even want to tug on it to see if it would fall off in hands again). I'll get another clip and replace the ET and thermostat as was suggested.
onaje is offline   Reply With Quote
Old 05-02-2014, 03:34 PM   #1926
onaje
Take a look at this picture again. The center round nozzle...should that be sporting an O Ring as well?
ID:	556670   Click image for larger version
Old 05-02-2014, 03:37 PM   #1927
Stinger9
My Ride: '04 330Ci
Is there a hole in the center of that center protrusion or not?
Could that not be a groove in which a locking clip fits rather than an O-ring channel?
Old 05-06-2014, 05:35 PM   #1928
onaje
yeah you're right, no o ring. no hole in the center since the transmission fluid and coolant doesn't mix.
Old 05-06-2014, 06:22 PM   #1929
WDE46
No that is only for mounting. No Oring there.
Old 05-08-2014, 04:59 PM   #1930
hsdhami
My Ride: 320d
very very high engine temperature
hi guys today i was driving my car... parked it at home to pick up a few things . when i came out to leave the car would not start ! i turned the key and the the only thing that appeared on the dash was the airbag light the engine did not even turn over. So i checked the battery and jumped started it ... weirdly enough it worked fine.
However this was a bit weird as i had driven it about 60 miles before switching it off.
Now there is a new problem .... when i turn the key to position two the engine temperature goes straight to the red line .... on a COLD ENGINE !! also the mpg meter goes straight to zero. When the car is running on a cold start the engine temperature gauge remains at 3pm (red line ) and also the mpg meter stays at zero whilst driving.
Any help would be appreciated, going to take it for a diagnostic tomorrow but a little scared to drive it even though i think it a faulty thermostat.
hsdhami is offline   Reply With Quote
Old 05-08-2014, 05:36 PM   #1931
Stinger9
My Ride: '04 330Ci
Prob not a faulty thermostat since the gauge reads hot on a cold start.
Also two gauges are working incorrectly. Could be a gauge cluster defect.
Try the OBC hidden functions cluster sweep to check it.
Old 05-19-2014, 11:21 AM   #1932
Solo118
My Ride: '17 750i, MDX
Send a message via AIM to Solo118
I am looking to get a 2003 330 with under 75k, perfect timing to do the cooling system as it is still on the stock system.
Does anyone recommend the ECS set, or is it recommended to go with the OEM kit they sell? Also I know it is probably a dumb question, but is the stage 2 kit (link below) a good way to go, or should i go all out with the stage 3? I do not plan on driving this car much, perhaps 2k miles per year.
http://www.ecstuning.com/BMW-E46-330...ing/ES2063861/
Solo118 is offline   Reply With Quote
Old 05-19-2014, 03:16 PM   #1933
Stinger9
My Ride: '04 330Ci
Originally Posted by Solo118 View Post
double post- sorry
Level 2 has plenty all the parts you need.
Not sure if they are all oem parts tho. That is important. Especially pump and ET and two main hoses.
Old 05-19-2014, 11:32 PM   #1934
Solo118
Originally Posted by Stinger9 View Post
Can erase the second post.
Start off with the edit button.
Then use the delete button.
Not sure if they are all oem parts tho. That is important. Especially pump and ET.
ECS has similar parts, but you are correct not all of them are OEM. I prefer the aluminum water pump pulley though.
So I should be OK with stage 2? Or should I go all out on this, even though this car will get light mileage
Old 05-20-2014, 12:51 AM   #1935
Stinger9
My Ride: '04 330Ci
Plenty of examples of fails for poor quality components. And many fail sooner rather than wait for high mileage. Heck, even the oe fails at high mileage!
You can buy components separately. Don't have to buy a kit.
I'd use only oem parts known to us on this board, and I did buy separate Al underdrive pulleys for my own car. So that's how I feel.
Unless you're on a real budget, and really HAVE to just get by.
Have tow insurance?
Old 05-20-2014, 10:02 AM   #1936
Solo118
Have tow insurance?
I was unaware the non-OEM was such bad quality, as some members here have bought the ECS kit without issues.
I will definitely take the advice, and go for OEM parts. The question is should I be going stage 2 or stage 3? Car has 72k on stock cooling system, will not be driving more than 2k miles per year.
Old 05-20-2014, 10:08 AM   #1937
WDE46
Put together your own OEM kit. It doesn't have to be "Genuine BMW" just made by the OEM. It'll come out cheaper than the ECS kit probably.
Old 05-20-2014, 10:20 AM   #1938
Solo118
Thanks, should I be looking at ECS, or from another source?
One item I think definitely needs an upgrade is the water pump pulley, would you agree the aluminum pulley from ECS is the one to go with?
Old 05-20-2014, 10:38 AM   #1939
Stinger9
My Ride: '04 330Ci
To Shop:
Use www.realoem.com to get part numbers.
Then take numbers and go to www.furiousmethod.com to create a list of part prices to see who gives the best deal at that moment.
Already said I like the Al pulley.
Old 05-20-2014, 10:38 AM   #1940
WDE46
I have their pulley. It's a nicely made product and I'd recommend it.
There are many forum sponsors that all have competitive pricing. Mango's first line of the first post in this thread has several...
You can add FCPEuro to that list. If you call them apparently they will match pricing with anyone and they offer a warranty with all the parts they sell.
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
