Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 04-11-2012, 09:57 AM   #101
ccagle
My Ride: 02' 325i
Originally Posted by Wickedly View Post
I'm able to move my screen yet my light from my unit are always on
I can move mine also. If I'm not on the Nav side.... That's our issue..
ccagle is offline   Reply With Quote
Old 04-11-2012, 09:58 AM   #102
ccagle
My Ride: 02' 325i
Originally Posted by Keith Billanti View Post
Doood... free camera? that makes me mad. I'm not even going to install mine....
anyone want a camera who didnt order one???
Where were you and this offer when I ordered?!?!? Haha
Old 04-11-2012, 10:09 AM   #103
atbecstacy
My Ride: 2004 BMW M3 AW 6MT
With that little Easter egg out of the way- we now need to focus on the other minor issues the device has.
1. Volume issue that seems to plague SOME of us, but not others
2. The wheel buttons only scanning by frequency rather than pre-set channel
3. Screen glare
Reserved for the next issue (ha)
so still no word on the volume issue huh?
atbecstacy is offline   Reply With Quote
Old 04-11-2012, 10:17 AM   #104
Keith Billanti
My Ride: TitanSilber//M3
nothing.. we are at the mercy of enco...
Keith Billanti is offline   Reply With Quote
Old 04-11-2012, 11:32 AM   #105
TiAg2247
My Ride: E39 M5
Didn't someone mention the volume issue in HK cars can be fixed with a line out converter?
Imola Red M5 | Imola Red Interior
M-Audio Package, Power Sunshades, GT Exhaust, Custom BC Coilovers
Past:
'01 330Ci Titanium Silver on Coral Red
'96 328i Jet Black on Black
TiAg2247 is offline   Reply With Quote
Old 04-11-2012, 11:42 AM   #106
Keith Billanti
that's a band-aid on a broken leg.
Shouldn't have to dump 50$ more into this for a properly functioning unit. PLUS, if you limit the current to the amp, the rest of the modes would also be limited. Tuner is the only culprit.
My firmware
MCU: HY11.28
DVD: 04.21
HMI: v12.26
Old 04-11-2012, 11:45 AM   #107
mrwhite
My Ride: 325ti SE Compact
yup apparently so
I havent got an HK amp system but noticed volume on radio is very loud, however after a while it seemed to soften and I could take it from "2" to "10-11" without it being a problem
aux in and cd seem fine, its just radio that is a bit odd
mrwhite is offline   Reply With Quote
Old 04-11-2012, 03:02 PM   #108
ccagle
My Ride: 02' 325i
Originally Posted by r2t2 View Post
I wouldn't assume that... Mine was in the same batch as yours... Is the F/W & S/W the same?
Looks like your WinCE version is different than ours... So maybe that's it??? Firmware is the same though??
Anyone with more experience with this should feel free to chime in.. Haha
Old 04-11-2012, 04:10 PM   #109
tyger38
My Ride: 2003 m3 cabrio
Hey guys, I know this question was posed on the original thread, but I don't recall seeing an answer. My gps worked fine for a few days and now I'm getting the "no signal" screen when I press the navi button. I can't get to the nav menu at all. I have removed the unit, changed and relocated antennas but to no avail. I don't have any other issues with the unit. Thoughts?
tyger38 is offline   Reply With Quote
Old 04-11-2012, 04:22 PM   #110
Keith Billanti
None at all. Mine, sometimes will need to find the signal, but generally, it acquires it by the time I am out of the driveway.. or a the end of the road..
Old 04-11-2012, 04:30 PM   #111
tyger38
Would the patch allow me to access navigation without using the gps button? I think something in the firmware may have been switched off somehow.
Old 04-11-2012, 04:31 PM   #112
ccagle
My Ride: 02' 325i
1) Reset the unit
2) get a new SD card
3) reload Nav software on new formatted SD card
4) insert new card and turn on
5) Enjoy having Nav back
Mine did the same. SD card was bad even though it was new from enco. After new SD card, it worked fine.
Old 04-11-2012, 06:41 PM   #113
tyger38
Unfortunately that didn't work, but thanks for advice. If anyone comes across a fix for this, please let me know. Senco employees are at HK Fair so it will be a while before I get a response from them...
Old 04-11-2012, 08:22 PM   #114
bikeaddict
My Ride: e46 330ci
so i have installed igo primo, and have the patch installed, how do I assign the igo primo icon to the program. When i click on it nothing happens but i assume it doesn't know where the program is..
bikeaddict is offline   Reply With Quote
Old 04-11-2012, 08:37 PM   #115
r2t2
My Ride: '01 330i '06 M3
-to add shortcuts to desktop, use the System Tools app from desktop. Select shortcut creator option, then select the exe file you want , then select nwdflash/desktop if you want the shortcut on desktop, or nwdflash/programs... etc if you want it in another menu.
I'm going to assume your directory structure has Primo and Program Files in the root directory.
Double tap the System Tools...
Double tap the Shortcut Creator...
Double tap the Primo directory...
Double tap primo.exe...
Tap OK...
You've now selected what you want to shortcut...
Then double tap you way down from Program Files to the /Program Files/nwdflash/desktop and select OK. Exit out of Shortcut Creator and you'll have Primo on your desktop.
RayK
'01 330i - up for sale soon
'06 M3
'08 Kawasaki Concours C14
r2t2 is offline   Reply With Quote
Old 04-11-2012, 09:22 PM   #116
ccagle
My Ride: 02' 325i
Originally Posted by ccagle View Post
Has anyone tried the ODB interface petrutms mentions in the word doc in his patch download???
"- to use OBD software, you need to install .netcf 3.5 ( run the installer from .netcf 3.5 folder from program files ) and to install ftdi drivers ( read instructions and warnings in ftdi foder from program files ). Please note that installing .netcf 3.5 may cause issues on certain devices and patch may stop working, if that`s the case you need to remove .netcf."
This I'd be interested in. I wonder if it works on our units????? Fingers crossed..
Ok everything for the OBD is installed. However, it seems as if we may need something to connect to the OBD port?? I figured it would be more like our OBC data.
Petrut- can you confirm an external connector is needed for this to function?
THX!!
Old 04-12-2012, 12:49 AM   #117
petrut
My Ride: bmw e46
of course it needs external connector...
petrut is offline   Reply With Quote
Old 04-12-2012, 08:35 AM   #118
bikeaddict
My Ride: e46 330ci
Tap OK...
will the igo primo icon in the iphone area work as well?
Old 04-12-2012, 09:39 AM   #119
ccagle
My Ride: 02' 325i
Just making sure..... I thought it would be more like the dynavin and was hoping it would open up the OBC features. Is that something you could do with a future patch??
Old 04-12-2012, 03:40 PM   #120
r2t2
Beat me... Since I had iGo Primo on the SD card first the WinCE directory is at the same "level" as the Primo. So I simply had the Shortcut Creator look on the storage card for the primo.exe file in the Primo directory. I suppose it would work... Make a backup and try it.
RayK
'06 M3
