Old 04-07-2012, 10:33 PM   #1
mcaltinsoy
My Ride: 04 330ci
Premium Gas or Unleaded for -04 330ci-
Hey everyone, i just bought my 330ci a few days ago. I always had japanese cars before. BMW seems like a different language to me nowadays. My question is it says on my fuel gauge Unleaded gas ... but anyone out there using premium at all?
mcaltinsoy is offline   Reply With Quote
Old 04-07-2012, 10:33 PM   #2
brontosaurus
My Ride: 2002 330i 5mt
Christ dude, only put premium in it.
brontosaurus is offline   Reply With Quote
Old 04-07-2012, 10:34 PM   #3
Perez
My Ride: US
All gas is unleaded...
Perez is offline   Reply With Quote
Old 04-07-2012, 10:35 PM   #4
carcus
My Ride: 2006 BMW M5
ROFLOL!!!!!!!!!!! Just add water
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 04-07-2012, 10:40 PM   #5
katu
My Ride: '04 330ci ZHP
You want Unleaded (which is all they sell as far as I know) and AT LEAST Premium 91+ octane.
katu is offline   Reply With Quote
Old 04-07-2012, 10:41 PM   #6
TitanSl33pr
My Ride: 330ci
¡¡¡LMFAO!!! Classic!!! Welcome to E46Fanatics! My friend, be sure to consult ur manual (and I'm this caseur fuel door) first before asking those kinda ?s smh n still lmfao!!!
Sent from my Samsung Galaxy using Bimmer App
TitanSl33pr is offline   Reply With Quote
Old 04-07-2012, 10:45 PM   #7
carcus
Can you actually run 89 regular unleaded in it though....yes you can. Not the best and altitude plays a part in octane.
Buying a car that you have no idea on what type of gas you need....classic. You might want to check out some threads on what repair bills might cost and what parts you need to replace for PM. Also....check out the oil change requirements. This site will give you what you need if you dig. Try the search button. Please read the manual if there is still one in your car. If not, there is one posted on here somewhere in a thread to download.
Old 04-07-2012, 10:54 PM   #8
NOVAbimmer
My Ride: E60M
You'll be fine running regular unleaded.
If you find any leaded gas, I'm sure the EPA has a bounty out for that kind of thing.
NOVAbimmer is offline   Reply With Quote
Old 04-07-2012, 11:02 PM   #9
rfbmwfan
My Ride: 1999 323i ZSP
You can run with regular unleaded, the car's sensors and engine management computer can adjust for different levels of octane. But it's recommended to use premium. The owner's manual states you might notice decreased performance and less mpg. If you're too cheap to buy premium (which is the recommended fuel for your car) then maybe a BMW isn't for you. Honda's don't require premium, or Hyundai's.
rfbmwfan is offline   Reply With Quote
Old 04-07-2012, 11:06 PM   #10
NOVAbimmer
My Ride: E60M
your butt dyno isn't sensitive enough to miss the 2-3 peak hp loss you may suffer while trolling the streets in your 323.
Cadillacs don't require premium, either. Unless you're buying a V.
Old 04-07-2012, 11:16 PM   #11
Blocked Out
My Ride: Imola 330i M-Sport
It says use 91 octane minimum
Open your owners manual and read.
I
Original BMW Teile ///
IMG_1725
Old 04-07-2012, 11:23 PM   #12
Redline
Redline's Avatar
My Ride: ///M3 Vert
had some girl behind me pumping gas into her e46, i happened to notice she was putting regular in there and i was like you know you're only supposed to put premium in there, she was like oh sh!t and stopped, asked me what will happen and i told her the engine will blow up she was like holy fvck i just got this car 3 days ago
k.
///M
Old 04-07-2012, 11:26 PM   #13
codyfunk
My Ride: 2001 BMW 330ci
classic!
codyfunk is offline   Reply With Quote
Old 04-07-2012, 11:26 PM   #14
NOVAbimmer
My Ride: E60M
OP, here's how to test:
1. Put in regular unleaded.
2. Listen for engine knocking/pinging
3. If no knocking/pinging, you're good.
4. If knocking/pinging, take car to mechanic for diagnosis. Possibly bad knock sensors.
Old 04-07-2012, 11:37 PM   #15
rfbmwfan
Looks like I struck a nerve there..
Anyways, the engineers figured there would be cheap a$$es out there or idiots who don't want to trust (or read their owners manual) what BMW has spent millions and possibly billions into research finding out what their engines run best on.
But, obviously you are smarter than BMW engineers.
Old 04-07-2012, 11:44 PM   #16
MercForHire
My Ride: M235i 6MT
Again 91 octane nazis rule the board.
87 is fine, save your money.
Old 04-08-2012, 01:26 AM   #17
Vigilante
My Ride: 320i - 2.2 L - 170hp
Send a message via MSN to Vigilante
Up till now I always used premium fuel with octane 98 (BP) or 97 (Shell) but with the gas prices these days ($ 2.50 per Liter /$ 9.46 per Gallon ) I have to switch to a cheaper fuel with octane 95 (lowest octane available). With the premium fuel I get better milage, around 405 miles per tank, I once got German premium fuel, it has an octane of 101, that gave me 440 miles per tank
320i Executive Sedan | E46_AV11 | ZF5HP19 S-t | M54B22 | 170hp 210Nm | 09/2000 | 171k | 32.9 MPG
Maintenance
Re-surfaced CH | VC+VCG | CAM/VANOS timing | IMG | NGK-i | BAT+ALT | O2's | GM5 | WP WPP | PSP | DISA | TB ICV MAF | CCV | CAI | OFHG | FP | FF | A/C | FSU | AUC | WSS | BL BD BP | Mango | JFOJ | SB TP IP | springs | Shocks | tires | ASC+ | alignment | E.Flush | Castrol SAF-XJ 75W140 | ZF LGF5 ATF Flush | FCA+FCAB | Struts
Vigilante is offline   Reply With Quote
Old 04-08-2012, 01:32 AM   #18
carcus
And now...on to the gas threads
OP, please read the oil threads and the reset clock thread.
Old 04-08-2012, 01:44 AM   #19
shanneba
My Ride: 2003 330Ci
The Car will adapt to changes in octane AS LONG AS THE Knock Sensors are working. If there is an issue with them the car will default to ignition timing map for 91 RON octane.
Our US Octane ratings are R+M/2 or the average of the Research and Motor octanes. (91 RON is about the same as 87 AKI used in the US)
http://en.wikipedia.org/wiki/Octane_rating
http://www.bmw-planet.com/diagrams/r.../e46/index.htm
Self-diagnosis and emergency operation of the knock control system
Self-diagnosis of the knock control system includes following checks:
Check for sensor signal interference/line break, plug connector defective etc.
Self-test of entire evaluation circuit
Check of basic engine noise level detected by the knock sensor
The knock control system is switched off if a fault is found during the course of one of these checks. The emergency program adopts the task of controlling the ignition timing. At the same time, a defect code is stored in the defect code memory. The emergency program ensures damage-free operation as from minimum RON 91. It depends on the engine load, speed and temperature.
Join BMWCCA
Old 04-08-2012, 01:46 AM   #20
shanneba
My Ride: 2003 330Ci
Welcome to the Forum.
Here is a great link to information on the BMW E46 you just bought:
It will answer many questions you will have about your car.
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
If you didn't get an owner's manual, you can download and read one from here:
http://www.linquist.net/motorsports/bmw/3manuals/
Join BMWCCA
