#21 | ||
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
If someone has so little faith in every component of their e46 and is forced to use 91 out of fear. Then please, sell the German piece of sh1t. Quote:
#22 |
91 isn't even an option in Alaska and I see an awful lot of bmw's here. Apparently they don't spontaneously combust without 91
If you're really concerned about it don't peg the gas pedal while at high elevation on a hot day every time you accelerate and you'll be fine |
#23 | |
Higher air temperatures do raise the octane requirement.
#24 |
Troll?
#25 | |
![]() Oh and you didn't add the part about the 91 RON being equal to US 87 AKI gasoline........
#26 |
Holy fuuck.
#27 |
Just pump any gas in it besides diesel. It will run. Not joking.
BMW Fanatic, Porsche 996..., SCCA XC. Light mods/Fabspeed...restored 2002 coming soon.
#28 | |
Sent from my PG86100 using Bimmer App |
#29 |
Bunch of ****s
#30 | |
Sh1tty Advisor
If a problem affects 10% of all cars, then statistically 10% of users on this forum will also suffer from the problem. Regardless of the percentage of e46 owners who visits this forum. This forum is simply a sample size, like a public survey. But since this knock sensor failure have never been mentioned here. The probability of knock sensor failure must be so rare that we can be sure it never happens to all e46 with 99+% confidence. |
#31 | |
http://forum.e46fanatics.com/showthr...t=knock+sensor http://www.bimmerfest.com/forums/sho...ghlight=knock+ I guess just like anything else man made, they DO fail
#32 |
After running premium on the car doing a run from Chicago to Mpls. I let tank run out to just about zero miles, then filled up with Regular. Started check MPG after about 10 miles to make sure any Premium was out of the lines, I am getting 27.3 MPG instead of 28.6 driving the same roads, same conditions. The 20 cents difference in gas makes it a wash, as far as saving money.
I tried doing this "test" around town, but conditions were too erratic. It makes sense that you would get a little more power out of the engine with premium, I was hoping it would be a little more than .954% though. I am going 77 mph with cruise on. Oddly enough, dropping the top has more of an effect on MPG (+) than using premium. I will have wait for a time when it not raining out to do that.
#33 |
Octane content really does not change the amount of energy stored in the fuel. What it does is raises the temperature required to ignite the fuel.
Since most cars (and all e46) come with electronic knock sensors, you are not damaging your car by going below reccomended levels. However you will experience some level of knock which will lead to reduced economy and performance. |
#34 |
I also find it interesting that the BMW ECU and programming includes a data value that indicates to service techs what the RON value of the fuel being used is:
http://www.bmw-planet.com/diagrams/r.../e46/index.htm Open Compete Vehicle, Drive, Engine Management MS43 ...... , symptoms, Complaints, RON Factor for determining Fuel Quality RON factor for determining fuel quality Fuels with a low octane number may be the cause of the following problems. - High fuel consumption - Reduced tractive power - Driving operation malfunctions - Poor start-off characteristics The RON factor serves the purpose of determining the fuel quality used. The reference values refer to the following: RON factor Refueled fuel quality 0 to 0.2 RON 98 0.2 to 0.6 RON 95 0.5 to 1.0 RON 91 These reference values apply at outside temperatures higher than 25 °C. At lower temperatures, knocking occurs at a later point and results in lower RON factors. I generally see this value at 0.1 - 0.2 when running 93 AKI US gas. The next time I have to get 91 octane I'll try to confirm the values I get.
#35 |
why are you cheap bas
k.
#36 | |
My Ride: '94 325iC & '00 323i
The real question is premium or regular, and the correct answer is mid-grade. Your car does not need premium (91, or 93 in some places), and will tolerate regular (87), but it runs the best on mid-grade (89). |
#37 |
#38 |
#39 |
Fuel selection is a function of economics more than anything else. No engine needs higher grades of fuel than is stated by the engineers, and they all will tolerate a lesser grade.
If you ran a test of several tanks of gas (at least 5 of each grade) and kept track of the Cost Per Mile (divide the cost per gallon by the miles per gallon), you would find that the correct grade would actually cost less than the lesser grade. Typically, the cost savings of the more expensive fuel over the course of a year will run to about $150-ish because the car will deliver better mileage, meaning you buy less fuel. The DIFFERENCE in the cost of regular and mid-grade is generally about 10 cents, but the mid-grade gives enough improvement in the performance and fuel economy that the cost per mile is actually lower. If fuel costs $3.50 for regular and delivers 20mpg, then the cost per mile is $0.175, but if the fuel cost is $3.60 and you get 22mpg, then the cost per mile is $0.164, saving you $0.011 per mile, and if you drive 12,000 miles in a year then you would save $132 in fuel costs. If the cheap gas comes in at $0.175 per mile, then multiply the expensive gas by .175 to determine the break even point where you need to see an improved mpg to justify the expense. If the cheap gas is $3.50 and the expensive gas is $3.60, then you need better than 20.6mpg to recover the cost. Anything better than 20.6 for the cost up is fuel savings. Sheesh, do the math. |
#40 | |
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser 2008 YAMAHA YZF-R6 ![]() |
