Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Old 11-27-2013, 12:29 PM   #201
DylloS
My Ride: nothing
Awesome man. hopefully when your squat gets up to your old 3x5 Pr you'll kill it.
DylloS is offline   Reply With Quote
Old 11-27-2013, 12:34 PM   #202
MpoweredM
Wants to be Orange
MpoweredM's Avatar
My Ride: 1098S; RR Sport; CRZ
MpoweredM: Just another progress thread...
Thanks. I watched some "proper form squat vids" and they mention all the components for some one by going up in weight until they fail and see where they start failing first..quads? Back? Hips? Etc
After that I feel I have bad hips. I actually never really thought about it my I OFTEN have my hips tense up. When I'm doing abs, bench, etc my abductors just start to tense and lock up. Does this sound like something that is a major issue do you think? Or is it more something I need to strengthen? I'm sure the ladder of course. Haha
Santa Hats thanks to Scott!
Click for pics of my bikes
Click for pics of my old 335
Click for pics of my old S4 avant
Click for pics of my old M3
Originally Posted by v8 5 View Post
Constatine would of thrown his dildo at the kidnapper and proceed to cry in his closet after said kidnapper escaped.
MpoweredM is offline   Reply With Quote
Old 11-27-2013, 01:11 PM   #203
DylloS
My Ride: nothing
Do your knees tend to cave in a bit when squatting. Mine do and it drives me nuts.
Old 11-27-2013, 01:27 PM   #204
MpoweredM
Wants to be Orange
MpoweredM's Avatar
I wouldn't say they do, however, when my hip begins to give (usually one or the other just depending) I may begin to dip towards that side a bit. With that being said, I'm sure my knee does go in a bit though.
Old 11-28-2013, 10:12 AM   #205
Charlescrs6
My Ride: E46 M3 Convertible
Mine do on the last rep or two of a heavy set. I have to be conscious of it happening and make sure they stay out.
Current: SG/IR E46 M3 Convertible
Past: 2004 Audi A4 USP, 2003 Audi A4
Charlescrs6 is offline   Reply With Quote
Old 11-28-2013, 10:14 AM   #206
dabears
My Ride: 2003 BMW M3
I keep my toes pointed way out and it really seems to help with ensuring knees are pushed out, and also allows me to get maximal depth with my squat
dabears is offline   Reply With Quote
Old 11-28-2013, 10:34 AM   #207
Charlescrs6
I'll have to try that. I usually only slightly point them out.
Old 11-28-2013, 10:56 AM   #208
DylloS
My Ride: nothing
That's not a great idea. Ideally you want the knees to track over the toes.
Old 11-28-2013, 11:05 AM   #209
MpoweredM
Wants to be Orange
MpoweredM's Avatar
Edit. Will post video in high def when I'm on wifi.
Old 11-28-2013, 12:27 PM   #210
MpoweredM
Wants to be Orange
MpoweredM's Avatar
Form check. Set 5 of my 5x5 at 275lbs. Wanted to film my last set instead of my first set when I was as exhausted...
Old 11-28-2013, 01:01 PM   #211
bgsmith
bgsmith's Avatar
My Ride: No longer an e46
Start with the bar on the ground, seems you would be wasting a lot of energy with your initial lift off the rack.
bgsmith is offline   Reply With Quote
Old 11-28-2013, 01:03 PM   #212
z00
Banned User
My Ride: E46 M3 Manual
You have few things to work on:
  • If you're right handed, use an under-grip with right hand. Over-grip with left
  • Make your feet a little closer
  • hands should be right outside the legs, the narrower the less distance you have to move the bar
  • DL is a pull and a push movement, push with your heels, thrust with your hip, once the bar clear your knees pull
  • You tend to lift the bar mostly with your back, you want to engage your hams and hips. It should be a one smooth motion from start to finish. You seem to break it into two moves; before the bar cleans your knees and after. Your back is a little bent forward, you're asking for injury, it should be straight
  • I would perfect the form with a lower weight like 135lbs and then work your way up
  • always start with the bar resting on the ground so you can adjust your form
z00 is offline   Reply With Quote
Old 11-28-2013, 01:17 PM   #213
dabears
Re: MpoweredM: Just another progress thread...
Who says the knees won't track over the toes? I consciously ensure they do
Sent from my SGH-I337M using BimmerApp mobile app
Old 11-28-2013, 01:23 PM   #214
dabears
The two biggest issues I see:
Your weight distribution appears to be almost entirely on your front toes. You should be lifting from your heels, it's almost like you are shifting forward to compensate for the bar being too far from your body
Old 11-28-2013, 01:28 PM   #215
bgsmith
bgsmith's Avatar
You want to use the under grip with your weaker hand, I'm right handed I use over with right, under with left.
Old 11-28-2013, 01:33 PM   #216
bgsmith
bgsmith's Avatar
Also seems like you are dropping your shoulders, keep your chest up and out to ore get this.
Old 11-28-2013, 01:34 PM   #217
MpoweredM
Wants to be Orange
MpoweredM's Avatar
I've always done this too. Under with my weaker...
Old 11-28-2013, 08:10 PM   #218
DylloS
My Ride: nothing
Start from ground is number 1 hence the name "deadlift". There is a lot to work on here though. All easy fixes though.
Hips get too low so you're kind of squatting the weight up. You're doing two different pulls on each lift. One is super low then IMO you get into the correct pulling position. See the pics below. 1 is super low, almost like a clean position and pic 2 is where I think your hips should be when you first begin the lift maybe just a tad lower but not nearly as low as when you start.
The hips too low is a common problem I see so I have people bring them up a bit. Last thing is you seem to go around your knees on the way down. Pull your hips back and this will help.
Deadlifting is a super simple move to explain so I'll do my best here.
-Walk up the the bar with feet about hip /shoulder width apart ( use personal preference) and touch your shins
-bend down and grab the bar right outside your legs
-lower hips until you feel tension in your hamstrings. If you go to low you'll feel nothing and know you went too low
-chest up and keep a neural head position by looking about 3 feet in front of you at the ground.
- take a big breath and hold it in your gut. Pull tension off the barbell and lift up pulling your shoulders back. Make sure that barbell is as close to your body as possible. When approaching the knees pull the hips back and your knees will follow.
If you can take another video in a few days and drop the weight to 185 just so I can see the form again. That will obviously be light but I just want to see if how it goes.
Old 11-28-2013, 08:23 PM   #219
MpoweredM
Wants to be Orange
MpoweredM's Avatar
Thanks! Will do!
Old 11-28-2013, 08:39 PM   #220
DylloS
My Ride: nothing
Thanks! Will do!
Nice man. Hope it helps. Just slow it down a bit and think through the movements
