Sponsored by BimmerWorld
Old 04-09-2012, 02:22 AM   #1
brady5885
My Ride: 330ci
What do i need when dropping
Im looking to drop my car quite a bit on coilovers..... i have seen the coilovers i want.
But what else do i need apart from the actual coilovers?
will i need shorter sway bars? etc and do i need to replace mounting rubbers...
if someone can give me a FULL shopping list of what else i need to order id be very greatful
brady5885 is offline   Reply With Quote
Old 04-09-2012, 09:14 PM   #2
brady5885
My Ride: 330ci
Nobody knows this?
I need to order this stuff in the next couple of days if anyone can advise me plz
Old 04-09-2012, 09:20 PM   #3
323I00
My Ride: E46 323I
Id post In the general section theres more action there.
Functional justification... true. But girls dropping their panties counts for something
BBK on non-supercharged-non-m..... because chasecar
323I00 is offline   Reply With Quote
Old 04-09-2012, 10:44 PM   #4
Blocked Out
My Ride: Imola 330i M-Sport
Most coilovers come with all that you need for the install and then some. Other/cheaper coils dont come with all thats needed.
So, which coilovers do you want to buy ???
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 04-09-2012, 11:31 PM   #5
brady5885
My Ride: 330ci
No the coilovers im looking at are only the shocks and springs... what else will i need?
Old 04-11-2012, 01:22 AM   #6
Mulrich07
My Ride: 2004 325Ci
It would probably help if you said which ones they were. Just sayin.
Mulrich07 is offline   Reply With Quote
Old 04-11-2012, 08:03 AM   #7
brady5885
My Ride: 330ci
Why when it's just shocks and springs?
But they are v-maxx
Old 04-11-2012, 11:34 AM   #8
Logan175
My Ride: E46 320i
Alright it sounds like you need a bit of help.
If you answer some of our questions .
1) How much money do you have to play with? What is your budget?
2) How low do you want to go?
Performance sway bars are usually thicker in diameter and stiff. That will reduce body roll. Tire rack has the best price on Hotchkis front and rear sway bars which are the thickest. I am about to run those because they come with new bushings to accommodate the larger bars where as other kits use the stock ones.
I assume you are looking for better handling, how much comfort do you want to compromise?
1.4 inches front .75 inches rear being a mild drop using lowering springs that are not adjustable however less $$$. Or something more extreme and adjustable like coilovers that will lower you car anyway from 1 inch or more?
Logan175 is offline   Reply With Quote
Old 04-11-2012, 11:35 AM   #9
SeanC
My Ride: 330i
You need adjustable rear camber arms to straighten up the camber when you go low.
You do not need sway bars, but they will help flatten the car up on turns.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
